Walnut & Cherry, new project #1: Startup
Blog entry by bandit571 posted 09-08-2017 04:05 AM 537 reads 0 times favorited 1 comment Add to Favorites Watch
no previous part Part 1 of Walnut & Cherry, new project series Part 2: Out of the clamps.. »
Chest of drawers is done…still have a pile of “leftovers”...
A small stack of Cherry….a 1×4 x7’ plank of walnut, and a few other odds & ends….
Decided to resaw the Cherry a bit, so I planed them to about the same thickness and width. Made a jig for the bandsaw
To see IF it would help with these tall boards.
Meh….
Brought the Walnut plank to the shop….made a few crosscuts…
It had a section that needed to be…gone…..wound up ripping a good section out of it, though
Was trying to match the length of the Cherry panels…..then did a little re-design work. The Cherry would still be panels, but
They would be Raised Panels, and sit in Frames of Walnut…
Used the “new” Stanley #4 to bevel the edges of the panels. Then started making parts out of the Walnut 1×4s…
Needed a few rails made. The Stanley #45 was set up to mill a 3/8” wide groove, 3/8” deep. Then, I also made the end pieces..stiles…
Also with the grooves. Bandsaw was busy. Between the rip cuts for width, and the foot details….
It also helped cut tenons to fit in the grooves…so I could do a couple glue ups..
Side #1 ( Front? Back? We’ll see…)
Side #2…..let these sit overnight….stay tuned…..
1 comment so far
View jeffswildwood's profile
jeffswildwood
2823 posts in 1881 days
#1 posted 09-08-2017 12:10 PM
Nice use of left overs. I’m wanting to see what it becomes! Nice!
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
