Shop storage projects #23: Chisel dresser: final details done
Blog entry by bandit571 posted 02-22-2017 05:44 PM 476 reads 0 times favorited 0 comments Add to Favorites Watch
« Part 22: Frame works, false fronts, and other mishaps..... Part 23 of Shop storage projects series no next part
Just about wrapped this project up. Had to set it up on the bench..
Had to measure for a kicker for the bottom drawer…
Glue and a couple screws to hold it in place. Measured for a plywood back…
Again, glue and screws. Started applying cleats to hold the top in place…
Then added the top…
No glue, just enough screws to hold things still, is all. Couple at each end.
added this cleat ( on the wrong side, at that) to hold the shelf support in place…
Then slid the entire mess into it’s new home…
I had to slide these closed when done..
Project is now completed. Not sure what the next remodel project will be…..yet.
Thanks for looking in!
0 comments so far
