Adirondack Chair Build (part 1)
Blog entry by Woodworker_Collins posted 07-18-2013 07:07 PM 1498 reads 0 times favorited 4 comments Add to Favorites Watch
Here it is guys my first youtube build, i hope you will enjoy, part 2 should be out tomorrow :)
http://www.youtube.com/watch?v=F4kaMRimszA
-- Adam, Ireland, http://www.youtube.com/user/AdamTheWoodworker
4 comments so far
View ScottKaye's profile
ScottKaye
583 posts in 1860 days
#1 posted 07-18-2013 10:16 PM
Keep up´╗┐ the great work Adam. Its amazing what one can get accomplished with out the use of big expensive stationary equipment! Great job bro! as a side note, I love it when people post their bloopers. It makes them seem more real!
-- "Nothing happens until you build it"
View hobby1's profile
hobby1
335 posts in 2205 days
#2 posted 07-18-2013 10:56 PM
You did a nice job on producing the video,
I was thinking the same thing as posted above, it was nice to see someone building a project, using (what I call handyman type machines), you have a very nice setup with your table saw, and power switch, as well as a real nice workshop setup for yourself, and most of all, your doing a great job on this build project,
You have good woodworking talent, and I am looking forward to your next installment.
View stefang's profile
stefang
15784 posts in 3241 days
#3 posted 07-19-2013 12:36 PM
Good start Adam. I would suggest you use a starting pin when routing with your ball bearing bits. This will make routing safer and also avoid digging in at the start of your cut. You can just drill a hole a couple of inches away from your bit opening and insert the pin when you need it. A pin of about 8mm did. is about the right size. When you start a cut, just put the edge of the workpiece against the pin first and keep it there while you move the workpiece into the router bit. That will give you a much safer and smoother start.
View Roger's profile
Roger
20904 posts in 2711 days
#4 posted 07-22-2013 03:37 PM
Comin right along Adam
