This happened to me
Blog entry by Mike posted 07-05-2010 03:46 AM 1673 reads 0 times favorited 14 comments Add to Favorites Watch
A friend of mine stopped by the other day and he we wanted to try out the new raised panel router bit, we were going to try a few light passes before the final pass, the bit is Freud Quadra Bit, nice bit. Well anyways plugged everything after everything was secured, bit was tightened in collet. I then started the router up and all of sudden I heard a noise, went to power off the switch and before you know it the bit had worked itself out of the collet and went flying across the room, bounced on the floor a couple of times, The good news was neither of us got hurt, the bit never touched the fence or the table, just made a small scratch on the inside of the plate. So the next time you tightened those bits down make sure you take a good look.
This was the first time this ever happened to me. It happened so fast, I count my blessings…....
Mike
-- Mike, VT
14 comments so far
13606 posts in 3365 days
#1 posted 07-05-2010 04:07 AM
glad you are OK ,
did you leave an 1/8” of shank up from the bottom when you tightened the collet ?
some collet assemblies don’t close completely if the bit is bottomed out ,
that is the most common slippage problem ,
that and lose wrenches .
View Tim Dahn's profile
Tim Dahn
1567 posts in 3589 days
#2 posted 07-05-2010 04:48 AM
Close call, but no injury so that’s good.
Just purchase an o-ring and slip it on the bit shank to prevent the bit from being inserted too far.
View woodpick's profile
woodpick
13 posts in 3735 days
#3 posted 07-05-2010 05:03 AM
I’ve never had that happen but I did have a brand new Frued bit in my router and when I went to route a piece of maple, the carbide broke off and make a load noise that really scared me. I wasn’t hurt either and thankful that I was wearing my eye protection.
-- Dave, Golf...Woodworking...more Golf, www.woodshopics.com
View Jim Bertelson's profile
Jim Bertelson
4179 posts in 3189 days
#4 posted 07-05-2010 05:35 AM
I have always had an unnatural fear of those router bits. When I put a different one in the collet, and then I first turn them on, I am always in a position that a flying bit or piece can’t hit me (view me ducking below the table). But I never had anything go wrong, and always insert them the correct distance and tighten them well, and recheck.
Now I don’t feel so foolish…............(-:
Alaska Jim
-- Jim, Anchorage Alaska
View longgone's profile
longgone
5688 posts in 3333 days
#5 posted 07-05-2010 06:28 AM
Sounds scary. I never had it happen either but anything is possible. I also buy the 1/2” O rings and slip them on my router bits. they are cheap, easily avaiable and work well. I also tighten the heck out of the collet (hate to have heck in the collet)..I have the Freud quarda cut panel bit set and it is excellent quality..
View tyskkvinna's profile
tyskkvinna
1310 posts in 3010 days
#6 posted 07-05-2010 06:31 AM
Yikes!!! I have had this happen. Nothing will get your heart pumping like something spinning at 20,000 RPM and shooting a pointy, sharp hunk of metal at some random point in the room.
I’m glad nobody was hurt.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3139 days
#7 posted 07-05-2010 07:57 AM
thats one of the reesen I prefeur to work unplugged
glad no one was hurt
Dennis
27250 posts in 3846 days
#8 posted 07-05-2010 02:31 PM
I am sure that did get an adrenaline rush going. I am glad to hear that no one was hurt.
View NBeener's profile
NBeener
4816 posts in 3198 days
#9 posted 07-05-2010 03:41 PM
I DID have this happen once.
Change of shorts was in order.
I’m going to start wearing my kevlar motorcycle riding suit in the shop, I think …..
Glad all are okay. Verrrry scary happening.
-- -- Neil
View uffitze's profile
uffitze
199 posts in 2979 days
#10 posted 07-05-2010 05:00 PM
One of the many reasons to hate/be scared of routers.
View lightweightladylefty's profile
3241 posts in 3737 days
#11 posted 07-05-2010 08:41 PM
If you happen to have kids or grandkids with braces, those tiny rubber bands that the orthodontist uses also work well to keep 1/4” bits from bottoming out.
So glad to hear of the blessing that no one was hurt!
-- Jesus is the ONLY reason for ANY season.
View nmkidd's profile
nmkidd
758 posts in 3197 days
#12 posted 07-06-2010 06:17 AM
glad to hear no one was hit by flying objects…....scary!!!
Timbo…thx for the Oring tip!
-- Doug, New Mexico.......the only stupid question is one that is never asked!........don't fix it, if it ain't broke!
View lanwater's profile
lanwater
3111 posts in 2958 days
#13 posted 07-06-2010 06:29 AM
I had similar thing hapening to me. altough not as dramatic.
I was patern routing with a flush bit. Then I realized that the bearing was now higher than the template.
As I was moving the ruined piece away from the bit, it came out an eat some of my aluminum ring.
I did not tighten the nut well.
-- Abbas, Castro Valley, CA
woodpick
#14 posted 03-24-2011 05:12 PM
Wow! That’s pretty scary! I bought a new Freud rabbeting bit and was trying it for the first time and a piece of carbide broke off the bit and made a racket. It pays to wear those safety glasses.
