Dust Collection for Router Table
Blog entry by Mike posted 01-19-2010 03:04 AM 2929 reads 0 times favorited 8 comments Add to Favorites Watch
I would like to build my own dust collection system for the underside of my router table. Any suggestions drawings pictures of ones that you have built. Also is it better to have the dust port directly underneath the router or to the back like on Norm Abrams table. Also should I stay with 4” or go smaller. I want to capture as much dust as possible.
-- Mike, VT
8 comments so far
View Ger21's profile
Ger21
1075 posts in 3334 days
#1 posted 01-19-2010 03:18 AM
I have a shop vac mounted to a hollow fence. When routing edges, against the fence, it gets 99% of the dust. But, if routing dadoes, it gets 0%. Ideally, Having dust collection in both the fence, and having a sealed cabinet with dust collection below, would be best. But if all your routing is doing edge work, then the fence alone is probably sufficient.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View northwoodsman's profile
northwoodsman
245 posts in 3949 days
#2 posted 01-19-2010 04:27 AM
I split my 4” into 2 – 2 1/2” using a 45ยบ “Y”. One picks up on top of the table through the fence, the other under the router. I cut plywood at compund angles and put them in place under the router and sealed everything with caulk. The cavity is just large enough so the router and lift can operate freely. I estimate that I get 99% of the dust & shavings when the fence is utilized and somewhere around 80% when I take the fence off. It is remarkable how well it works. It took a year or so of trial and error to get it to work this good.
-- NorthWoodsMan
View Mike's profile
Mike
252 posts in 3586 days
#3 posted 01-19-2010 04:49 AM
Do you have any pics or drawings?
-- Mike, VT
View John Gray's profile
John Gray
2370 posts in 4088 days
#4 posted 01-19-2010 07:18 AM
Ditto to what northwoodsman says above.
View mikeberry's profile
mikeberry
59 posts in 3290 days
#5 posted 01-19-2010 07:46 AM
I also had same problem. Last pic shows router mounted to plate for table.
http://lumberjocks.com/projects/25158
-- It's hard to plane a door when you have to use the crack of your ass for a vise
Rick Dennington
6304 posts in 3397 days
#6 posted 01-19-2010 07:00 PM
Greetings Mike: It’s all 6 of 1, and 1/2 dozen of the other. Everybody does it a little differnt , but yet the same. Over, under, behind the table. Just everhow you want it. Both ways…... pick a size…. 2”—4”. None. When you think on it, they’re all the same set-up. Whatever works for you, I’m all for it. Keep on keeping on.
-- " At my age, happy hour is a crap and a nap".....!!
View NBeener's profile
NBeener
4816 posts in 3377 days
#7 posted 01-19-2010 08:29 PM
I have a Kreg PRS2000 table.
I “enclosed” the base by cutting 1/8” hardboard and leaning it against the legs. The suction pulls it in, so there’s no need to affix it … for now.
On the back, I installed a 4” DC port and a 2-into-1 adapter, used some 2 1/2” hose to get from the adapter to the upper router table DC port, and hook my DC into the 4” port on the adapter.
All in all, it works quite well. After a LOT of board feet, I have to vacuum out the base on which the table sits, but … it’s simple and contains the dust just about perfectly.
-- -- Neil
View sIKE's profile
sIKE
1271 posts in 3957 days
#8 posted 01-19-2010 09:18 PM
I built Norm cabinet. When I used with the fence I get a large amount ~85% of the debris flying out. If the bit is buried in the fence and I am taking small amount off it is even better. Most of my mess is when I don’t use the fence (say a round over bit). For that situation I took two pieces of ply about 10” and 6” long by 3” inches tall and tacked a 6”x10” piece of hardboard onto it and put a 2 1/2” port in the top in the corner. It helps allot but still doesn’t catch everything.
