Projects #1: Coffee Table - Second Project
Blog entry by The__Dude posted 02-09-2016 04:25 AM 1246 reads 0 times favorited 7 comments Add to Favorites Watch
no previous part Part 1 of Projects series no next part
I have my first project done, fireplace mantel.
Added a few new tools.
Thickness planer and router.
We planned down some boards to 7/8” thickness.
I clamped in pairs and used my #8 plane to match the ends.
We glued enough boards for the top and a bottom shelf.
Now I need to figure out how to flatten the tops of the joined boards.
Need to read on on this.
I am assuming #8 plane again.
I am thinking of glueing up 3×3 legs.
Not sure about the apron or how to attach the bottom shelf.
7 comments so far
View pintodeluxe's profile
pintodeluxe
5706 posts in 2841 days
#1 posted 02-09-2016 05:11 AM
It might not help you for this project, but what I do is glueups in stages for tops and shelves. Say I have four 6” boards that I will use to make a 24” wide top. I first glue two pairs together, to make two planks. Then I run those planks through the planer to clean up the glue line. Finally I glue the two planks together. That way you only have one glueline to sand.
For me that is a lot more efficient than hand planing the entire surface flat. As always, there are many ways to do the job.
View Andre's profile
Andre
1888 posts in 1833 days
#2 posted 02-09-2016 03:27 PM
Make sure all your grains line up! I made a mistake on my Bench and it caused a lot of grief!
View The__Dude's profile
The__Dude
125 posts in 1090 days
#3 posted 03-21-2016 02:16 AM
I used the #8 to join the boards.
Today I am working on flattening them.
I worked a #5 about 30 degrees from the joints
Then worked #8 30 degree from the joints.
Looks good on a straight edge.
Not sure how I know when it is good enough?
Do I need a scrapper also?
Have to click on image to see it full size
The__Dude
#4 posted 03-26-2016 01:04 PM
I started with my #5 at a diagonal to the glueup.
Then my #8 at a diagonal also, then rotated and did diagonal again.
Then #8 with the grain.
Then #4 with the grain
Then #80 scrapper with the grain.
Straight edge shows it is flat, and it feels really smooth.
Anything else I should do to check it?
The__Dude
#5 posted 04-02-2016 01:30 AM
Cut wood for the skirt and legs.
Planning on glueing three pieces for the legs.
The__Dude
#6 posted 04-02-2016 01:33 AM
Not sure about the skirt and leg connection.
One table I own has mortise and tenon.
The other has a thread with nut and a wedge.
My dining table also has this.
This is what I am thinking of doing.
The__Dude
#7 posted 04-06-2016 01:18 AM
So I have been reading up, and it seems I need to do a mortise and tenon.
So the top skirt will be the tenon into the legs.
The bottom shelf will tie into the bottom skirt on the ends
These will be M&T into the bottom part of the legs.
Am I going in the correct direction?
