Old-Timey Woodworking #7: Quit sanding! Use these card scraper techniques instead!
Blog entry by StumpyNubs posted 05-31-2016 05:48 PM 1998 reads 3 times favorited 4 comments Add to Favorites Watch
« Part 6: Learn to sharpen card scrapers like a pro- You'll be glad you did! Part 7 of Old-Timey Woodworking series no next part
We taught you how to sharpen them, now see how to use card scrapers to eliminate most, if not all of your sanding work and maybe even save your lungs in the process! ALSO- look for part one, which covered scraper sharpening, in the June issue of Stumpy Nubs Woodworking Journal.
View on YouTube
Stumpy Nubs Woodworking Journal is published monthly. Subscriptions are free.
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
4 comments so far
View BurlyBob's profile
BurlyBob
5897 posts in 2384 days
#1 posted 05-31-2016 09:08 PM
Another good instructive video.
View Mean_Dean's profile
Mean_Dean
6859 posts in 3266 days
#2 posted 06-01-2016 12:07 AM
Enjoyed the video, as always!
I’m wondering though, how much of the sanding process the scraper eliminates? Do you use it to just remove tool marks, then finish sand? Or can you apply finish right after using the scraper?
-- Dean -- "Don't give up the ship -- fight her 'till she sinks!" Capt James Lawrence USN
View StumpyNubs's profile
StumpyNubs
7649 posts in 2919 days
#3 posted 06-01-2016 01:06 PM
Dean- It depends. A scraped surface is definitely smooth enough for finish, and many do finish them. However, some people find them to be too smooth if they are putting on a colored dye or stain, so they will actually sand them a bit to leave some scratches for the stain to take hold. Scraping can make a surface slightly out of level since it leaves very slight hollows where you scooped out the fibers. You can either level with a light scraping technique, or a final sanding with a fine grit.
View Desert_Woodworker's profile
Desert_Woodworker
1590 posts in 1333 days
#4 posted 06-01-2016 04:24 PM
Nice presentation- welcome back
-- Desert_Woodworker
