Wall Hung Tool Cabinet #25: Framed, Pt. 2
Blog entry by Smitty_Cabinetshop posted 02-09-2016 09:15 PM 1738 reads 1 time favorited 10 comments Add to Favorites Watch
« Part 24: I've Been Framed! (Pt 1) Part 25 of Wall Hung Tool Cabinet series Part 26: A Sub (Panel) Plot Thickens... »
I haven’t talked about the choice of poplar T&G for the backs of these frames, so let’s revisit the past just a bit. The main carcase of the “Not Wall Hung” has 1/2” T&G poplar for backer boards, and I have more of it left. Where did it come from? I honestly have no idea at this point, but it’s one of those caches of material that I saw and couldn’t pass up at the time, then kept on hand for (possible) future use. I originally thought of using some 1/4” bead board, but once it was planed smooth of some residual glue material there wasn’t much material left to hold the weight of fully loaded tool panels. So, poplar wins. And consistency counts for something, right?
Anyway, here are a couple of pics of the frames laid over the original-concept pine as well as poplar backer boards; I did this to rough out the width and lengths required.
I could place these backers into simple rabbets, but that seems too easy. That, and I’m also concerned about structural resilience; I don’t want to worry about these things holding together once in place. So I decided to create floating panels via table saw and the Venerable #78 Fillister. First the ‘gauge’ that would be used to verify the dado cuts to be made in the frames:
I cut the frames at the table saw (carefully!), then did some fit checks; note there’s chisel work needed to reach the ends of each dado in the frames.
Time for longer panel cuts.
It took a while, but I finally reached Nirvana with these tool panels. Had to rip the top cross pieces (the poplar will be screwed to those at final assembly):
The two frames may look identical, but they’re actually not. The Cherry L frame is narrower by about an inch, to allow clean access to the flush bolt that secures the left door. The Cherry R frame, although wider than the left, also has a bit of hardware to compete with: the cabinet’s lock is in the way. I decided to max out width (and ensure mounting screws could reach door frame material) by creating a mortise of sorts on the backside of the frame assembly.
The result of all this effort is a pair of ‘blank slate’ tool frames, ready for caddies!
Nothing permanently assembled yet. Now to work on tool layouts, so there’s more to come! To see more shop stuff I’m working on, you’re invited to visit my blog. Thanks for looking.
10 comments so far
View Mosquito's profile
Mosquito
9280 posts in 2260 days
#1 posted 02-09-2016 09:21 PM
Loving this series Smitty! I like the beaded T&G boards. I used the same for the back of my saw till too
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View AnthonyReed's profile
AnthonyReed
9668 posts in 2408 days
#2 posted 02-09-2016 09:36 PM
Glad the poplar won out in the end. Things like the mortise customization is the good stuff found when looking over hand made pieces.
Thanks for taking the time to share Smitty.
-- ~Tony
View putty's profile
putty
1185 posts in 1574 days
#3 posted 02-10-2016 12:12 AM
Very nice Smitty, I like the old look, like its been around for a hundred years
-- Putty
View terryR's profile
terryR
7115 posts in 2276 days
#4 posted 02-10-2016 03:13 PM
Wow, I missed the frames going together somehow. Looks superb! The detail at the top of the door frame is very classy.
T&G looks great!
So, is the ‘Not Wall-Hung’ because you don’t plan to actually hang it? Looks fab sitting as is!
-- tr ...see one, do one, teach one...
View duckmilk's profile
duckmilk
2773 posts in 1292 days
#5 posted 02-10-2016 03:31 PM
Very nice Smitty, it looks like it was there when you moved in.
-- "Duck and Bob would be out doin some farming with funny hats on." chrisstef
View 489tad's profile
489tad
3353 posts in 2979 days
#6 posted 02-10-2016 05:57 PM
Smitty that is something. The bead work shows nothing less than skilled.
-- Dan, Naperville IL, I.G.N.
View Pat3's profile
Pat3
105 posts in 1847 days
#7 posted 02-10-2016 06:05 PM
Love it! As usual, your is always spot on.
Smitty_Cabinetshop
15283 posts in 2586 days
#8 posted 02-10-2016 06:13 PM
Thanks for commenting, everyone!
After experimenting with a number of layouts, what I want to do with one door in particular will take a bunch of work. And posting updates while the work is going on will kill the fun of presentation IF I’m able to pull it off at all. So unless I come up with another plan to share glimpses, time to wait for a reveal of sorts.
I do have both CHERRYL and CHERRYR arrangements worked out though, that’s the good news.
View BurlyBob's profile
BurlyBob
5411 posts in 2233 days
#9 posted 02-10-2016 11:16 PM
That is a Jim Dandy! Can’t wait to see wearing it’s full tool outfit. That will be soemthing to see.
View mafe's profile
mafe
11643 posts in 3057 days
#10 posted 03-03-2016 10:19 PM
Wonderful, it really becomes a treasure cabinet.
Best thoughts,
Mads
