Misc. Shop Stuff #52: How to Stretch Table Legs
Blog entry by Smitty_Cabinetshop posted 03-23-2015 03:52 AM 1798 reads 1 time favorited 12 comments Add to Favorites Watch
« Part 51: Too Much Wood? Part 52 of Misc. Shop Stuff series Part 53: Cam Clamps, Anyone? »
1. Start with a pile of legs that are each a couple of inches short.
2. Pull the broken wheels from the bottom of the legs. It’s the hole from those wheels that lead to the fix.
3. Cut a ‘fifth leg’ into 3” lengths. Those are doweled and glued to the squared bottoms.
4. When the glue is set, head to the lathe.
5. Some sanding, then cut excess off before a little rasp work and sanding finishes the process.
These legs will be primed and painted, but vintage walnut legs are definitely better quality and stability than the pine legs sold at the blue box stores today.
12 comments so far
View ShaneA's profile (online now)
ShaneA
7052 posts in 2800 days
#1 posted 03-23-2015 03:56 AM
Is this for the commission project? Resourceful solution.
Smitty_Cabinetshop
15701 posts in 2820 days
#2 posted 03-23-2015 04:04 AM
I made five of them, using one in destructive testing. The glued seam didn’t break, the wood did. We’ve got a winner, so I have four reclaimed for the table and two for the front of the buffet. Very pleased, moving forward.
With the wheels, the legs were the right height when aprons were in place. Remove the wheels, there was a hole in the ends and the aprons were uncomfortably low.
View terryR's profile
terryR
7438 posts in 2510 days
#3 posted 03-23-2015 12:34 PM
Great looking work, Smitty. sure wish I had a lathe that long…
Any problems with getting the old legs centered to re-turn?
-- tr ...see one, do one, teach one...
Smitty_Cabinetshop
#4 posted 03-23-2015 12:46 PM
Top of the legs have three square corners, which solved that end. For the bottoms, it was less exact. I set each in the lathe ‘tight’ at the headstock, and adjusted tailstock location while slowly rotating the piece by hand. Worked very well!
View GrandpaLen's profile
GrandpaLen
1651 posts in 2474 days
#5 posted 03-23-2015 12:55 PM
Reported Sighting of the elusive ‘Board Stretcher’.
Grab a cup of coffee, sit back and digest Smitty’s latest tips on up-cycling reclaimed furniture fixtures, then take a walk out to the shop and …’stretch your Legs’.
As always, great advice, accompanied by a full tutorial.
Thanks for sharing, Smitty.
A ‘Wink and a Nod’ from Mother Nature for re-purposing her products.
Work Safely and have Fun. – Len
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View TerryDowning's profile
TerryDowning
1103 posts in 2319 days
#6 posted 03-23-2015 04:20 PM
And they say you can’t make ‘em grow if you cut too short. Yet another woodworking myth dispelled. Thanks for Sharing Smitty!!
-- - Terry
View ToddJB's profile
ToddJB
8294 posts in 2332 days
#7 posted 03-23-2015 05:14 PM
Awesome, Smitty. Good to hear the deconstruction test went swimmingly.
-- I came - I sawed - I over-built
Smitty_Cabinetshop
#8 posted 03-23-2015 05:22 PM
^ and there’s a higher bar when the stuff is going to leave the shop. I looked into brass feet, ball extensions and entirely new legs… Those seemed inferior to me, especially the look and (lack of density) feel of new. Tight grain? Uhm, no. These sure do. Very hard to plane this end grain. Seriously hard. I’m very confident in the approach, and my name is going on it.
View Slyy's profile
Slyy
2840 posts in 1857 days
#9 posted 03-23-2015 09:27 PM
Awesome Smitty. Hey, gotta be honest here: I spent the previous three days reading back through just about everyone of your blogs. Let me just say THANKS! They are a veritable fount of information and helpful tidbits. Please keep it up!
-- Jake -- "Not only do we live among the stars, the stars live within us." - Neil Degrasse Tyson
Smitty_Cabinetshop
#10 posted 03-23-2015 10:50 PM
Jake, thanks for the comments! That’s a ton of reading at this point, wow. Glad you liked any of them, and if I’m able to help anyone, all the better!
View stefang's profile
stefang
16138 posts in 3536 days
#11 posted 03-24-2015 09:17 AM
They came out great Smitty. You could also cut them in half at a place where you could add a turned element like a bead or bead and cove to hide glue joint, but I can see that it will likely be completely invisible anyway after finishing. Excellent work and a great idea too.
View AnthonyReed's profile
AnthonyReed
10064 posts in 2642 days
#12 posted 03-27-2015 11:28 AM
Ever the wizard.
Thank you Smitty.
-- ~Tony
