DeWalt PowerShop Build #3: More Pieces, More Progress
Blog entry by Smitty_Cabinetshop posted 04-01-2014 12:35 AM 2675 reads 0 times favorited 33 comments Add to Favorites Watch
« Part 2: A Basic Framework Part 3 of DeWalt PowerShop Build series Part 4: Uncertainty and Missteps »
I’ve managed to squeeze a few minutes’ time into the shop, which was long enough to complete a couple of sub-tasks on the PowerShop Bench (PSB). Which also made me think to do a quick update to this blog series. At this point the PSB consists entirely of five ribs and two struts and is structurally able to stand on its own. No glue or screws yet, just dry-fit; as I’ve mentioned, DW102 didn’t come with build instructions or narrative.
When the seven pieces I’ve made thus far are supposed to be fitted and permanently fixed into place, in other words, is unknown. So with that said, what next? I think it’s the two plywood bottom pieces.
I collected a used and slightly abused 5/8” sheet of plywood from inventory and laid out cuts that would avoid an area of blowout on the stock and get me both bottoms. Cuts were made with a circular saw (the Black and Decker Sawcat of the late 80s is an awesome tailed apprentice, BTW) on a pair of horses, with additional trimming done via RAS. Processing sheet goods is not my favorite activity – where have I heard that before- but with the stuff was cut to width, notches had to be cut so the bottoms could trace around each inside rib structure. Those notches were traced against a 1×6 cut-off and completed at the bench via handsaw.
At that point this first, smaller bottom was ready for fitting and it went well!
Repeat the process for the cuts on the larger carcase bottom and I’m good to go, right? Well, in theory, yes. A bunch of measuring had to be done to the elongated carcase bottom shelf in that it’s not on the drawing; that side of my build is essentially twice the width of DW102 but not exactly. The first piece was true to the drawing and progress on that one was quick. Well, the second went quick too, only it was wrong. Shouldn’t be in a hurry to make a mistake, I guess.
A Diversion
At this point, an error surfaced because I used a certain 1x cut-off to mark the notches shown in the previous pics… You see, I’m what some might call a hand tool junkie. I wouldn’t go so far as saying I’m a galoot, because I wouldn’t want to be associated with a group that would consider folks like me for membership. But I do like hand planes and have been known to grab the odd piece of scrap, clamp it up on the leg vise and take a few passes with the jack, jointer or block just to hear the “schhhh-k!” sound it makes. Well, it was just that piece of planed scrap that I used to mark the second of the two cabinet bottoms.
So when I finished the notch cuts and did a test-fit, there was a disconnect. Argh. Unaware of the true cause, I measured the distance between the ribs (front-to-back) and cut the front slot longer. AND, to make matters worse, the front extended beyond the cabinet’s intended face by the amount needed at the back. Argh again.So I pulled the piece, ripped it again and here’s what I’m left with:
I’ll glue and pin nail these before the back of the carcase is put in place; no impact and no one will ever know. Well, except for y’all. And now back to our regular program…
Back on Track
The other piece of progress was on the shelf runners. DW102 spec’d these to be ¾” stock that was cut to length and 1 ¾” wide. Well, that’s too much for shelves (I said) so mine were ripped to 1 ½” and cut to length via bench hook and backsaw as several rib components had been earlier. As a matter of fact, here is the same picture you’ve seen before of those cuts…
Next Time…
What next, then? Glad you asked, because I’ve been wondering that myself. Until then, as always, thanks for looking.
33 comments so far
View GrandpaLen's profile
GrandpaLen
1651 posts in 2513 days
#1 posted 04-01-2014 12:47 AM
To err is human, to recover is fine woodworking.
Work Safely and have Fun. – Len
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View ShaneA's profile
ShaneA
7064 posts in 2839 days
#2 posted 04-01-2014 12:47 AM
You seems to have an endless supply of vintage/repurposed stuff. Feels good to give them a new lease on life. Easier on the wallet too. Sheet goods can add up fast.
View Don W's profile
Don W
19050 posts in 2808 days
#3 posted 04-01-2014 01:18 AM
it’s better then the salvage dawgs!
View 489tad's profile
489tad
3498 posts in 3252 days
#4 posted 04-01-2014 01:50 AM
Good stuff.
-- Dan, Naperville IL, I.G.N.
View stefang's profile
stefang
16219 posts in 3575 days
#5 posted 04-01-2014 09:40 AM
Good work on this Smitty. When I made measuring and/or cutting mistakes in the past I thought I had ruined the piece. Now I expect this to happen (based on much actual experience) and like you I just fix it, like you did here, and move on, without a guilty conscience.
View AnthonyReed's profile
AnthonyReed
10084 posts in 2681 days
#6 posted 04-01-2014 02:32 PM
Your deadman? Where is it?
Spurned, the #203s weep in their cubby….
-- ~Tony
Smitty_Cabinetshop
15822 posts in 2859 days
#7 posted 04-01-2014 03:17 PM
Slipped out of it’s track so I could work the large plywood sheets. You see, my #203s are rather snobbish and don’t appreciate being used to secure processed building products.
I guess they’re spoiled.
(the very bottom corner of the deadman can be seen in the ‘large panel’ cutting pic above, outside the bench leg)
PS: Very nice arrows, Tony!
AnthonyReed
#8 posted 04-01-2014 03:51 PM
Got it.
Glad to hear the 203s have standards, integrity is in short supply nowadays, it seems.
-- ~Tony
View ToddJB's profile
ToddJB
8320 posts in 2371 days
#9 posted 04-01-2014 06:36 PM
Looking good, Smitty. Thanks for the blog.
-- I came - I sawed - I over-built
View Slyy's profile
Slyy
2840 posts in 1896 days
#10 posted 04-01-2014 11:22 PM
What I’ve spent the last 3 days finding the perfect arrow processing software and now I find out someone has a circle maker too!!!!!!
Incidentally, the work continues Smitty. One of the wonderful things I’ve figured out from LJ’s is that mistakes can be hidden. I can only imagine the fine woodworker of lore who earned there craft (and came perhaps) through the ability to hide those mistakes so well, we never even know. Looking forward to part san!! (Stuck some japanese in there!)
-- Jake -- "Not only do we live among the stars, the stars live within us." - Neil Degrasse Tyson
View terryR's profile
terryR
7468 posts in 2549 days
#11 posted 04-02-2014 02:37 PM
Another great blog, Smitty, and excellent work in progress! What mistakes? I don’t see any…
Yeah, I hate cutting sheet material, too. I have a sweet Grizzly TS, but cannot cut a straight line with it! My method for ply goods:jig saw just outside the line, than handplane to the line. S L O W .
+1 to the nice arrows, brother Tony! :)
-- tr ...see one, do one, teach one...
View lysdexic's profile
lysdexic
5270 posts in 2863 days
#12 posted 04-03-2014 01:56 AM
-- "It's only wood. Use it." - Smitty || Instagram - out_of_focus1.618
View Dave's profile
Dave
11429 posts in 3081 days
#13 posted 04-04-2014 01:25 PM
I want that Anvil!!!!!!
Smitty_Cabinetshop
#14 posted 04-04-2014 01:38 PM
Oh, it gets tons of use (not…)
View Dave's profile
Dave
#15 posted 04-04-2014 01:41 PM
OK so go beat it a few time with a hammer so it wont feel left out.
showing 1 through 15 of 33 comments
