Tool Chest Refurb #18: Final Hardware Install
Blog entry by Smitty_Cabinetshop posted 09-30-2013 01:53 AM 2114 reads 0 times favorited 16 comments Add to Favorites Watch
« Part 17: A 'Feature' gets (Re-) Discovered Part 18 of Tool Chest Refurb series Part 19: A Latch!! »
Here’s what I’ve had:
The vertical saw till needed flush ring pulls, and those finally came in this week. Tonight was install time.
First to practice on pine. Traced it with a knife, chisel’d (carefully) and drilled and got the fit right. Lots of chiseling ahead on a much narrower piece of walnut.
Removed the saws and square from the till and set it up on the bench for work.
Chisel’d out the square, marked for the deep, recessed cut needed for the pull. Used the forstner in a suitable brace.
Pre-drilled for the screws (phillips type, but those will be replaced with slotted screws when I get them…)
Done, and Done.
As always, thanks for looking!
16 comments so far
View Airframer's profile
Airframer
3043 posts in 1947 days
#1 posted 09-30-2013 02:12 AM
GASP! Phillips Head Screws in a Smitty build? Dude you are slipping! ;-) Looks great btw :-D
edit – Just noticed you mentioned they will be replaced.. my faith in all that is good has been restored lol.
-- Eric - "I'm getting proficient with these hand jobbers. - BigRedKnothead"
View ShaneA's profile
ShaneA
6928 posts in 2592 days
#2 posted 09-30-2013 02:29 AM
Looking good. When the final installment comes out, I look forward to the before/after photos. I have forgot what shape/condition it was in before the work began.
View WayneC's profile
WayneC
13754 posts in 4091 days
#3 posted 09-30-2013 02:34 AM
Well done.
Smitty_Cabinetshop
15341 posts in 2612 days
#4 posted 09-30-2013 02:44 AM
Project Post!
http://lumberjocks.com/projects/90140
EDIT: Oh, my…
Eric, don’t panic. Phillips will be replaced, just have to find the right size slotted screws. What I bought was too big…
View theoldfart's profile
theoldfart
9694 posts in 2445 days
#5 posted 09-30-2013 03:01 AM
and don’t forget timed! we’re watching
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
Smitty_Cabinetshop
#6 posted 09-30-2013 03:06 AM
Roger that!
theoldfart
#7 posted 09-30-2013 03:11 AM
The forstner bit, a special one for braces or an ordinary DP type?
Smitty_Cabinetshop
#8 posted 09-30-2013 03:21 AM
Ordinary. The brace jaws accepted it pretty readily, worked great.
View Don W's profile
Don W
18707 posts in 2561 days
#9 posted 09-30-2013 12:55 PM
sweet. Your the epitome of galootness!
View AnthonyReed's profile
AnthonyReed
9713 posts in 2434 days
#10 posted 09-30-2013 03:12 PM
Very nice.
-- ~Tony
View Brit's profile
Brit
7373 posts in 2837 days
#11 posted 09-30-2013 10:24 PM
Wow Smitty, not much room for error chiselling that out was there? Did you consider turning it 90 degrees and offsetting it so that when the pull was lifted it pulled in the center of the drawer? Probably wouldn’t look as nice, but would have given you a bit more wood around the outside. Just curious. Looks great.
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View Brit's profile
Brit
#12 posted 09-30-2013 10:30 PM
Just visited the project post and realised that you installed two pulls, not one.
Smitty_Cabinetshop
#13 posted 09-30-2013 10:55 PM
No, Andy, not much margin at all…
I tried turning them, simply didn’t look right. Fortunately went well, just had to take my time that’s all.
View Dave's profile
Dave
11429 posts in 2834 days
#14 posted 10-03-2013 01:13 PM
I love the hardware.
View stefang's profile
stefang
15881 posts in 3328 days
#15 posted 10-06-2013 07:33 AM
Nice hardware and nice work Smitty.
