Misc. Shop Stuff #23: Reworking a Cheap F-Style Clamp
Blog entry by Smitty_Cabinetshop posted 06-14-2013 07:44 PM 1825 reads 0 times favorited 10 comments Add to Favorites Watch
« Part 22: A 'New' Medicine Cabinet Part 23 of Misc. Shop Stuff series Part 24: Things that Arrive in the Shop »
I bought a set of four F-style clamps a decade ago for probably $5 at one of those tool ‘auctions’ of new stuff, the precursor to Harbor Freight (perhaps). Anyway, over the years they’ve lost their ‘grab’ and I can’t tighten them with any certainty, with any significant pressure. But I’ve held off throwing them away.
Anyway,
Today I wanted to clamp through a doghole in my benchtop and reached for one of these bad boys. Ground off the stud at the end so the turnscrew piece would come off, and tried the clamp. Rats, no hold.
I pulled the two flat pieces of sheet stock out of the ‘head’ and took a file to the holes in each, to put a square edge back on them. Well, it worked! With the clamp together, through the bench, it held like crazy.
Now to take apart the other three!
10 comments so far
View Don W's profile
Don W
18559 posts in 2438 days
#1 posted 06-14-2013 08:06 PM
New life!!! Almost like buying new.
View FirehouseWoodworking's profile
703 posts in 3144 days
#2 posted 06-14-2013 08:11 PM
Isn’t that a great technique?! I’ve done the same, however I reversed the clamp. I put the fixed head under the bench and the adjustable head on top.
I found it much easier to adjust the head cams and then tighten the screw handle while stand up at my bench rather than squatting and reaching under (tired old knees and bad back – let alone my belly getting in the way! – but that’s another story.)
I selected the longest clamp that I could slip into the dog holes from underneath the bench and went with them. That allows me to slip on the adjustable clamp head and slide it all the way down.
Well done, sir! And thanks for sharing!
Cheers!
-- Dave; Lansing, Kansas
View Mauricio's profile
Mauricio
7139 posts in 3022 days
#3 posted 06-14-2013 08:22 PM
I have one just like that which also slips. Like you I havent thrown it away yet. I’ll have to try your filling trick.
View stefang's profile
stefang
15701 posts in 3205 days
#4 posted 06-14-2013 10:05 PM
Good one Smitty! I too have used some of my F-clamps by removing the top jaw and just dropping the bar into a hole that goes through my bench top. It works great, but I very seldom have need of it.
View knothead's profile
knothead
163 posts in 3819 days
#5 posted 06-14-2013 11:45 PM
I have done exactly the same thing to three HF clamps for clamping items to the bench! Beats throwing them away
-- So Much Wood - So Little Time! --
View Brit's profile
Brit
7355 posts in 2713 days
#6 posted 06-15-2013 02:38 PM
Nothing worse than a clamp that won’t clamp. Nothing better than putting a tool back to work.
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View Dave's profile
Dave
11426 posts in 2711 days
#7 posted 06-17-2013 03:52 PM
Nice clamp save!
View AnthonyReed's profile
AnthonyReed
9532 posts in 2311 days
#8 posted 06-18-2013 01:58 PM
Your Don-esque ingenuity is is showing…. just a heads-up.
-- ~Tony
View Sylvain's profile
Sylvain
684 posts in 2370 days
#9 posted 06-18-2013 05:04 PM
If filing the hole with a square edge is not enough, there is also the Matthias Wandel trick :
http://woodgears.ca/shop-tricks/clamp-slip.html
It might help if the hole doesn’t keep its edge.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
Smitty_Cabinetshop
14948 posts in 2489 days
#10 posted 06-18-2013 05:28 PM
The clamp above actually had that done to it. It helped for a while, a bit, then went back to it’s slipping ways. I’d guess both procedures done at the same time might be the way to go…
Thanks Sylvain.
