Skill Building #8: A Dovetail Tongue and Groove Plane
Blog entry by Smitty_Cabinetshop posted 03-13-2013 04:30 AM 3042 reads 0 times favorited 65 comments Add to Favorites Watch
« Part 7: An Excellent Tool for Dovetailing Part 8 of Skill Building series Part 9: Oh, my. I'm building the wrong stuff! »
Last time I messed with the Stanley #444, the side walls of groove were pretty ratty. Not that they’d be seen, of course, but the product means the nickers aren’t sufficiently sharp.
A little work on the fine DMT showed it wasn’t flat on the outer surface of either of the two nickers.
I worked each just enough to get the surfaces flat.
Then I carefully worked the primary bevels of each on the fine DMT. They’ve got a ‘camber’ to them already that I don’t think is original, but I’m not removing more material than necessary to get an edge.
A half dozen swipes on the strop had the edges sharp and looking good. The nickers are now the shiniest parts on the plane.
A marking knife made the start line and the plane followed the line pretty well. Kinda like a shoulder plane. And it that regard, I did adjust the iron to get it aligned with the nicker (more out than in, if you know I mean). That adjustment had a big impact on the end result.
The cuts I made here though aren’t the ones needed for a dovetail groove; those require the fence. And that is next time. No, I haven’t successfully made a sliding dovetail joint with this tool yet. It’s clearly Stanley’s most complex hand plane, and I’m humbled by it. Stay tuned.
65 comments so far
View lysdexic's profile
lysdexic
5258 posts in 2857 days
#1 posted 03-13-2013 04:35 AM
“It’s clearly Stanley’s most complex hand plane”
That’s a pretty definitive statement. You really think so?
-- "It's only wood. Use it." - Smitty || Instagram - out_of_focus1.618
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
15794 posts in 2853 days
#2 posted 03-13-2013 04:45 AM
I do. But it’s based on not having used (or seen) a #196 in person, the only other that may be as strange.
EDIT: I also don’t have a #55, and that is a bear to get working just right.
The #444, though, has fences that move on purpose, in use. That in itself makes it pretty unique. Imagine running a shoulder plane with a fence that slides up and down the side of the tool while you use it. Oh, and it pivots around a single set screw, too, while cutting under the start point. And this tool’s reliance on nickers is to the extreme.
But what do I know? Maybe the definitive statement is more like an opinion. Good thing is, it should be a safe one in that most simply do not care about this plane or have interest in it. :-) But I do, and felt like blogging my way through the learning curve. I hope it ends with a sliding dovetail joint, but at this point that outcome isn’t certain at all.
View RGtools's profile
RGtools
3372 posts in 2889 days
#3 posted 03-13-2013 12:31 PM
If it is that crazy and odd in use. Will you do a video when you figure it out? I can’t seem to wrap my brain around the way this works.
-- Make furniture that lasts as long as the tree - Ryan
View Don W's profile
Don W
19034 posts in 2802 days
#4 posted 03-13-2013 12:47 PM
we’ll be watching.
Smitty_Cabinetshop
#5 posted 03-13-2013 01:47 PM
RG, a video is a good idea and I’ll do it.
Is there a plane in your shop that you’ve spent more than a half hour on without figuring it out / producing results? ie: a smoothing smoother, or jacking jack, or scrub, or rebates with a moving fillister? I’ve logged about three hours with this dovetail plane and have yet to make a joint. It’s not frustrating at all (I like the challenge) but more like fascinating. It’s like starting over…
View Mauricio's profile
Mauricio
7150 posts in 3386 days
#6 posted 03-13-2013 02:00 PM
Pretty cool Smitty. You know this reminds me of something I saw in Toplin’s toolbox book. There is a guy who makes sliding dovetails by first cutting a dado and then making it a dovetail by hand with a side rabbet plane. I dont have a side rabbet plane to try it but it looked like an interesting method.
Smitty_Cabinetshop
#7 posted 03-13-2013 05:00 PM
There simply isn’t a lot of info out there on this plane (that I’ve found, anyway) that includes its use. It’s a collector’s tool, normally. Even a guy on SMC that had three of them didn’t reply to a direct query: Have you used any of them to cut a sliding dovetail joint?
Two different fences, four irons, two rods and two spur blocks on the #444.
Some have decried the woodworking maxim of five ways to do every operation. I suspect a couple of different ways to cut tails with this plane (henceforth referred to as The Beast). It’s clear I need a copy of the dovetail ‘map’ Stanley put inside the lid of the original box, so I’ll search for that tonight. From there it’ll go something like this:
  • Anatomy of a Sliding Dovetail Joint
  • Key Components of the #444
  • Fettling a #444
  • Layout and First Cuts
  • Mates and Finishes
  • Conclusion
All subject to change, of course. But unless someone points it out here, this stuff doesn’t exist out there. Leach did a video that supposedly includes one in use, but I’ve not seen it or heard anyone talk about said video. I guess that’s why I’m finding this such a challenge.
RGtools
#8 posted 03-13-2013 06:50 PM
I thought a rabbet plane was tricky…this is just beyond me.
lysdexic
#9 posted 03-13-2013 07:26 PM
One word…routah
Smitty_Cabinetshop
#10 posted 03-13-2013 07:40 PM
^ Elitist.
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3349 days
#11 posted 03-13-2013 07:42 PM
fun toy….. :-)
enjoy Smitty
Dennis
Smitty_Cabinetshop
#12 posted 03-13-2013 07:44 PM
^ Classy Guy.
Thanks, Dennis! :-)
RGtools
#13 posted 03-13-2013 09:12 PM
Chisel and saw for me…at least until Smitty explains how this contraption works.
Smitty_Cabinetshop
#14 posted 03-13-2013 09:54 PM
^ A fine, Galoot-ish approach.
lysdexic
#15 posted 03-13-2013 11:01 PM
Just bustin’ on ya, as usual. I am with Ryan, I am having a bit of trouble conceptualizing how this plane works.
showing 1 through 15 of 65 comments
