Wall Hung Tool Cabinet #17: Tambour Door Install w/ Video
Blog entry by Smitty_Cabinetshop posted 01-07-2013 03:30 AM 3992 reads 2 times favorited 30 comments Add to Favorites Watch
« Part 16: The Gang of Three (Drawers) Part 17 of Wall Hung Tool Cabinet series Part 18: This Installment is Not About the Tambour... »
EDIT: Updated to eliminate PB BS. Smitty
The wall hung has suffered from extreme neglect, but some progress was made over the Holiday Break. So, an installment! Here’s the cabinet in raw form: No doors, no drawers, no tambour.
Here’s the door to be installed to slide and close the lower left corner opening. It’s been patiently waiting for me to give it any attention, and finally the time came.
I saved the radius turns from the original Hoosier top, and those were used to trace top radius corners as well as the inside turn pieces cut.
The pieces came together and sandwiched the tambour pretty well.
I started the install by placing the top, corner-squared pieces at either end, at the top of the opening (first applying wax because it won’t get easier to wax the parts once in place. I then held the tambour in place and marked the position of the inset radius pieces, predrilled and waxed them, and screwed them into place as well.
The side strips were installed next.
I probably have an anal aversion to the tambour ‘catching’ on hard corners, so I eased the corners where the upper retainers met the strips.. Didn’t need to do that, in hindsight, but it is what it is and there’s no downside.
Both ends done, ready for tambour.
It set right in place, and the bottom fit fine!
At the open position, the corner-squared pieces catch the tambour’s ‘base’ and prevent the door from sliding up and out of sight.
I’m digging this!
EDIT, ADDED VIDEO:
And the whole cabinet looks good, pictured as I stood on top of the assembly table and looked down. I’ve arranged the cherry pieces that define the door openings and panels that are the tasks ahead. I’m not looking forward to the mortise and tenon work required to make these frame and panel doors a reality, though…
That’s it for now, more to come. And thanks for looking!
30 comments so far
View ShaneA's profile
ShaneA
6909 posts in 2562 days
#1 posted 01-07-2013 03:36 AM
The hoosier lives! Now we are talking. Good work on the tambour door, cool little detail. You can bang those doors out easy Smitty… : )
Smitty_Cabinetshop
15280 posts in 2582 days
#2 posted 01-07-2013 04:47 AM
My sawing skills will be much improved when I’m done with these door. Oh, and I need a 1/4” or 3/8” pigsticker… Rats. ;-)
View BenStewart's profile
BenStewart
66 posts in 1948 days
#3 posted 01-07-2013 09:52 AM
Excellent ! Love the post! Good job.
View lysdexic's profile
lysdexic
5254 posts in 2586 days
#4 posted 01-07-2013 01:08 PM
How many times did you open and close the tambour- marveling?
-- "It's only wood. Use it." - Smitty || Instagram - out_of_focus1.618
Smitty_Cabinetshop
#5 posted 01-07-2013 01:13 PM
Still counting, I’ll get back to ya. :-)
View Mauricio's profile
Mauricio
7144 posts in 3115 days
#6 posted 01-07-2013 05:08 PM
Great progress Smitty! The tambour is a really unique touch. I almost expect to see a loaf of bread sitting behind that tambour for some reason.
Why don’t you do bridal joints if you don’t like the M&T. That would be more fun saw work and no mortise chopping if that’s what you’re not looking forward to.
View AnthonyReed's profile
AnthonyReed
9667 posts in 2404 days
#7 posted 01-07-2013 05:57 PM
The hoosier is looking super sexy. I am glad to see it progressing. Thanks Smitty.
-- ~Tony
lysdexic
#8 posted 01-07-2013 06:01 PM
I like bridal joints. I have grown found of joints that are pinned with small multiple pins. In fact that is what paratrooper did for his cabinet.
lysdexic
#9 posted 01-07-2013 06:04 PM
Sorry, my mistake. He did wedged through tenons. But still…..........
ShaneA
#10 posted 01-07-2013 06:05 PM
OK, OK…I will throw it out there, why not just use your TS. Pretty simple set up, and accurate. I know, hand tool cabinet and all, but I wont tell on you.
lysdexic
#11 posted 01-07-2013 06:25 PM
You could always rent a Festool domino and then peg the tenons with hand shaped cherry dowels. LOL
Smitty_Cabinetshop
#12 posted 01-07-2013 07:21 PM
I’m thinking M&T because I will have stuff hanging on the inside of the doors… strenght optimized with that joint vs. laps, is the thought.
Glad you like the tambour. It is totally unique, ‘cept for at least one type of Stanley tool cabinet sold in the 30s having a whole front of tambour. I’ve seen one in pictures… prety cool. That told me it’d be an okay acoutriment on my wall hung.
View Don W's profile
Don W
18685 posts in 2531 days
#13 posted 01-07-2013 11:56 PM
i simply gaze in amazement…..................
View Brit's profile
Brit
7369 posts in 2806 days
#14 posted 01-08-2013 01:26 AM
I’m with you Don. I’m sitting here dazed and agog. The man has skills period.
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View WhoMe's profile
WhoMe
1564 posts in 3207 days
#15 posted 01-08-2013 05:17 AM
Dang smitty. I just stumbled upon this blog and HOLY COW, this is actually amazing to see what you have accomplished. I would love to have HALF the skills (and tools) that you have for this project. I know that when I build a wall tool cabinet, it will not be even close to yours in character or design. I have learned a lot just reading this blog.
It is bookmarked now and will be referred to often when I need inspiration.
Looking forward to the next installment.
-- I'm not clumsy.. It's just the floor hates me, the tables and chairs are bullies, the wall gets in the way AAANNNDDD table saws BITE my fingers!!!.. - Mike -
showing 1 through 15 of 30 comments
