Refurb, Antique Walnut Table #1: The Problem
Blog entry by Smitty_Cabinetshop posted 12-30-2012 08:14 AM 2770 reads 0 times favorited 23 comments Add to Favorites Watch
no previous part Part 1 of Refurb, Antique Walnut Table series Part 2: From the Bottom Up, Perhaps? »
The long and short of it can be presented in two words: Cracked Tabletop. But the table is old. Not a family heirloom of mine, maybe someone else’s at one time, but I only came by said table a couple weeks ago with one easy payment of $60 cash at a local auction. I recognized it as being made of walnut; it’s also what’s called a hall table, with a single drawer at one end. Drop leaf too. Couldn’t do without it, apparently, because I brought it home. So a few glamor shots.
Here’s a picture of the underside of the table, showing the wooden hinged drop leaf support and the glue block system holding the top to the aprons.
And a closer pic of said blocks, also showing the crack that is the problem that gives this blog entry a name.
From the underside.
From the top.
Lots to explore with this table. The legs have wheels I haven’t seen before. The top’s underside is scalloped; evidence of hand planing. Hand cut tongue and groove work on the drawer. And another construction detail that was a surprise to me. So, there’s exploration of the table as well as a solution to the ‘crack’ in the offing. I know, not a big deal for the pros on this site. But it’s a big deal to me, because I’d like to do a fix that allows the top to move (unlike the ‘glue it in place’ build style that didn’t figure for wood movement).If you’re interested, follow along. If not, no problem. Thanks for looking, more to come!
23 comments so far
View Brit's profile
Brit
7355 posts in 2716 days
#1 posted 12-30-2012 09:49 AM
So the fact that they used pocket hole joinery and glue blocks to attach the top meant that they didn’t allow for movement and over time it cracked. Looks like you have to:
  1. Mark the location of each hinge so that you can re-assemble them correctly, then remove the leaves.
  2. Remove the drawer and unscrew the runners so you can get to all the screws securing the top.
  3. Tease off the glue blocks.
  4. Unscrew and remove the top.
  5. Joint, glue and clamp the top, taking care not to damage the rule joints.
  6. Re-align and clamp the top in position on the legs.
  7. Forget the original pocket screws and glue blocks and use L-shaped metal brackets with slots to allow for top movement across the grain.
  8. Re-attach the leaves in their correct locations.
  9. Give it all a good clean and polish and call it done.
Estimated time = 1 day.
Alternatively if the table is structurally sound, you could just throw a cloth over it and call it done. Just sayin’.
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View Jamie Speirs's profile
Jamie Speirs
4167 posts in 2730 days
#2 posted 12-30-2012 12:17 PM
Smitty follow I will
This is a great project that will make it an heirloom
for your family.
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View Don W's profile
Don W
18562 posts in 2441 days
#3 posted 12-30-2012 01:04 PM
Hey Smit.
Another interesting restore. See if you can pop the blocks off the top(leaving then glued to the apron) maybe even use a flexible saw or saw all, just on one side.
glue the crack from the underside. Use air or a vac to get the glue through. Clamp using culls.
drill over size holes in the blocks. Screw with washers.
You can add some L brackets as Andy mentioned if you feel they are needed or the blocks split. You can also make some new wood blocks if you want to be more authentic.
View Brit's profile
Brit
#4 posted 12-30-2012 01:35 PM
Of course if it was me, I would have to re-finish the whole table, but you already know that about me by now I guess. LOL.
View Brit's profile
Brit
#5 posted 12-30-2012 01:40 PM
Looks like you’ll get some more turning experience too, making a new knob for the drawer. In fact you might as well make two, then you won’t have to worry about getting the new one to match the old one.
View terryR's profile
terryR
7057 posts in 2182 days
#6 posted 12-30-2012 02:40 PM
$60, huh? walnut…
I’ll give ya $80 for it as is! After YOU repair it, the Worth will be over my head. :)
Looking forward to the re-build…
-- tr ...see one, do one, teach one...
View poopiekat's profile
poopiekat
4322 posts in 3608 days
#7 posted 12-30-2012 04:29 PM
Was this a single-board top, Smitty?
It might be easier to section-out the cracked areas, then reassemble. I’ve done two tables like this in the past, with identical problems. In both of mine, the apron to leg m&t joints were bad, so after losing the inch across the top by sectioning out the top crack, I re-cut the aprons to match. Result was a pair of nice antiques, which I sold right off the truck at an antiques show.
View Bluepine38's profile
Bluepine38
3377 posts in 2959 days
#8 posted 12-30-2012 04:43 PM
Nice find, now do you put a contrasting piece of wood in the crack, put in a matching piece of wood to allow
the table to retain its original dimensions, or just narrow the top by gluing it back together. Lots of nice choices
on this table. Those look like the original wood wheels, no plastic available then, do you keep them, modernize
them, or eliminate them. You could put a matching drawer in the other end or not. Will wait patiently while
you decide and follow your preference. Those that do not like your choices could just build their own version
from scratch. Please keep up posted, thank you for sharing.
Jamie Speirs
#9 posted 12-30-2012 05:58 PM
Andy I think the broken knob is a feature unless
it is unstable
Nice new Avatar
jamie
View Brit's profile
Brit
#10 posted 12-30-2012 06:08 PM
Jamie – I know it would be a feature in Smitty’s eyes, I just don’t know if Mrs Smitty shares his appreciation of the ‘lived in’ look. :o)
Glad you like the new avatar. I was fed up looking at my ugly mug. Now I’m anonimous, I can be even more crazy when the mood takes me. [Andy laughs his evil laugh]
Don W
#11 posted 12-30-2012 06:28 PM
The jokes on us Andy. Every time I see your new Avatar I still see your ugly mug.
Just kidding of course.
Smitty_Cabinetshop
14959 posts in 2492 days
#12 posted 12-30-2012 06:46 PM
Lots of questions, but I only have my phone and the time to address one: the knobs are mortised into the face of the drawer / won’t budge. I’ve tried. So the chip off one knob base is a feature unless I get radical…
View Brit's profile
Brit
#13 posted 12-30-2012 07:38 PM
Don I spent ages this morning looking for a response I wrote to a comment someone posted on my saw talk blog. I scrolled from the beginning to the end of the comments looking for my old avatar before I realised I’d just changed it. Anyhow, here is something to remember me by.
Smitty_Cabinetshop
#14 posted 12-30-2012 09:51 PM
“Estimated time = 1 day.”
Funny guy.
Where’s the fun in hurrying glue to dry? :-)
View Dave's profile
Dave
11426 posts in 2714 days
#15 posted 12-31-2012 01:20 AM
I was all good with this blog til I scrolled down to comment and THE EYE FOLLOWED ME!
AHHHHHHHHHHHHHHHHHHH!
OK
I have composure now.
Smitty I love ole furniture restores. Can we have close up pictures of the hardware when you disassemble.
Great price and I am sure it will be a wonderful save.
showing 1 through 15 of 23 comments
