Ornate carving, not seen it before. Medallion is Warranted Superior, not sure it’s original. Repairs will be done, but I’m hoping for a pic of an original. Suggestions? Thanks!
EDIT: The saw’s ID is clear, refurb steps captured below. This saw will be resurrected one way or another…
Here’s the repaired handle.
EDIT #2:
Donor blade ID’d:
Cut, drilled and fit (broken orig. alongside):
EDIT: Done, see below.
-- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive
39 comments so far
Brandon
home | projects | blog
3774 posts in 1124 days
#1 posted 176 days ago
Wow, what a beautiful handle, Smitty. Are you hoping to salvage that one, or use it as a model for a new one? Sorry, I don’t have anything constructive to offer by way of identification.
-- "hold fast to that which is good"
Smitty_Cabinetshop
6413 posts in 790 days
#2 posted 176 days ago
I intend to repair! I like it alot, the unusual caught my eye. Thanks!
Smitty_Cabinetshop
#3 posted 176 days ago
May have found it on etsy…
Search for ‘floral’ handsaw found this description:
“saw was made by the E. C. Atkins Co. of Indianapolis, Indiana, in the late 1800’s. The rosewood or applewood handle has beautiful floral carvings. The blade measures just over 18”
Smitty_Cabinetshop
#4 posted 176 days ago
Good handle picture from ebay listing…
bandit571
3667 posts in 855 days
#5 posted 176 days ago
Hmmm, close. Yours MIGHT be a later edition. Note the heel of the plate, these two have a cure to them, while yours is dead-ass straight down. I’d say first ebay pix would the “Type #1” second pix would be a “Type #2” and yours MIGHT be a “Type #3”. Note the carvings, as well. One seems to be carved in, the other two seem raised up. (shadows, maybe?) I do know that some companies pressed a pattern onto the tote. Stanley ones went into the wood, ala the Keystone brand. Yours being a WS, might have been “pressed” into service.
Otherwise, looks like a match to me…
bandit571
#6 posted 176 days ago
A WS saw, full size at 26” long, on the left. Tote look close. Cleaned up into an Atkins saw
My “other” Atkins saw ( the one I kept for the shop) plate went right down to a sharp point. Was sharpened so many times, by several people, that there wasn’t much left. Wound up cutting about 3-4” off the toe, now its a good “toolbox saw”.
Now, IF you should see this guy about and about ( WS &M 28” long) let me know, I sold this little guy for about $30 last summer, after buying it for a buck….
bluekingfisher
809 posts in 1152 days
#7 posted 176 days ago
I hope you repair it, I would be very interested to see how you could make good with so many cracks and much of the original handle missing.
Good luck with it Smitty
-- No one plans to fail, they just, just fail to plan
Boatman53
420 posts in 369 days
#8 posted 175 days ago
Hi Smitty,
How does this compare? I got this over the summer. Still need to clean it up.
If you want somle measurements let me know. I’m still trying to decide if the handle carving is a carving or stamped in. It looks stamped to me.
Jim
-- Jim, Long Island, NY Ancorayachtservice.com home of the chain leg vise
Smitty_Cabinetshop
#9 posted 175 days ago
Jim, that is a BEAUTY! Thanks for the pic, it’ll help me shape the upper horn on my refurb (such that it is).
FWIW, I think it’s stamped, too.
Mine’s missing an original medallion, unfortunately. I have a 26” blade to retrofit to the finished handle, and that’s what text I’ve seen says the saw shipped with.
Thanks again!
Boatman53
#10 posted 175 days ago
Smitty…. Would you like me to trace the handle for you, or photograph with a rule so you can scale it?
Jim
Smitty_Cabinetshop
#11 posted 175 days ago
I’m close…. (!)
Don W
9973 posts in 740 days
#12 posted 175 days ago
I can’t believe how much better it looks already. I wasn’t sure it was salvageable, but you’ve made me a believer.
Smitty_Cabinetshop
#13 posted 175 days ago
Tools of the trade…
Smitty_Cabinetshop
#14 posted 175 days ago
Progress. Time for breakfast…
Smitty_Cabinetshop
#15 posted 175 days ago
Need to fix the piece missing at the medallion, but the horn is looking good at this point.
View all comments »
showing 1 through 15 of 39 comments
