Wall Hung Tool Cabinet #14: Milling Cherry for the Cabinet Face
Blog entry by Smitty_Cabinetshop posted 06-22-2012 02:56 AM 8143 reads 0 times favorited 27 comments Add to Favorites Watch
« Part 13: Making Boards and Sourcing Inside Drawer Parts Part 14 of Wall Hung Tool Cabinet series Part 15: Material Prep for Panel Doors »
EDIT: Updated to eliminate PB BS. Smitty
Pictures tonight, but precious little dialogue.
Lunchbox planer was out with a bad switch, but it came back this weekend. So the boards went through multiple passes then were each given the #4 smoother treatment.
I did move to the #4 1/2 after awhile, and the mass was very welcome.
I ripped a thicker board then did the re-saw of those boards on the old Craftsman bandsaw. When the night was over, the cabinet was covered with the fruits of the evening’s labor.
Let the joinery of the doors and facade begin! :-)
27 comments so far
View lysdexic's profile
lysdexic
5255 posts in 2651 days
#1 posted 06-22-2012 03:04 AM
Very nice Smitty. I really respect how you re purpose wood and tools.
-- "It's only wood. Use it." - Smitty || Instagram - out_of_focus1.618
Smitty_Cabinetshop
15369 posts in 2646 days
#2 posted 06-22-2012 03:13 AM
It’s getting there. I’m anxious to get panel doors made and work on another ‘trick’ I have in mind for the jack plane till.
View Robsshop's profile
Robsshop
907 posts in 3003 days
#3 posted 06-22-2012 03:22 AM
That is some BEAUTIFUL looking lumber there Smitty ! That will POP when You get to the finishing aspect of your “labor of love”, nice progress.
-- Rob,Gaithersburg,MD,One mans trash is another mans wood shop treasure ! ;-)
Smitty_Cabinetshop
#4 posted 06-22-2012 03:28 AM
Rob- thanks! Cherry is new to me but I’m figuring it out. Next with the #48 and #45 to do panels and such. Finishing should be a treat too. I’ll need suggestions there, as I’m decidedly a novice at creative finishes!
Robsshop
#5 posted 06-22-2012 04:21 AM
I believe that some kind of natural oil finish for something like Your tool cabinet would be fitting,but having little experience with Cherry as well, I am just basing my opinion on some of the projects found here on L J’s . I have read that Cherry can be difficult to finish(blotching),but not exactly sure if that applies to all or some finishes or perhaps it’s staining Cherry that is the issue ? Any ways probably a good idea to consult some experts on the subject as I am positive that You will. Looking forward to Your progress,and keep up with the updates ! ROB
View ShaneA's profile
ShaneA
6956 posts in 2626 days
#6 posted 06-22-2012 04:23 AM
Good to see some progress. Cant be long now. Thanks for the update.
Smitty_Cabinetshop
#7 posted 06-22-2012 11:29 AM
Rob- I agree to all you said! Blotch on this thing would be sad indeed…
Thanks, Shane and Scott for the encouragement!
View Don W's profile
Don W
18754 posts in 2595 days
#8 posted 06-22-2012 12:07 PM
i’ve don’t think I’ve ever stained cherry (maybe, its something my brain would filter anyhow), but I find finishing cherry kind of nice. Oil, poly or wax all works well on cherry. Take away the fact it burns just by staring at it, it pretty easy to work with.
I especially like how cherry ages. I actually don’t care for the light color when its first milled, but it darken very nice in a relatively short period of time. Also if you use oil, I like the way handling it ages it. So on a door piece it will pick up the oil from your hands where you open the door. That for me is a nice patina. For some its a reason to use poly and wipe it clean. Its all in your preference.
I made this for my wife out of cherry
Click for details
if i had it to do over again I would finish it with oil instead of poly. (Live and learn)
Smitty_Cabinetshop
#9 posted 06-22-2012 12:17 PM
No poly or stain, that’s for sure. Danish oil, you think?
Don W
#10 posted 06-22-2012 12:28 PM
natural Danish, or something with color? Test it, but I think it should work well.
Smitty_Cabinetshop
#11 posted 06-22-2012 12:30 PM
I’m thinking natural. 3+ coats is the key, I read.
Don W
#12 posted 06-22-2012 12:38 PM
I always do 3+ coats of any kind of finish on anything. Of course part of that may be because I suck at finishing so it takes 3 coats to be sure everything is covered once.
Smitty_Cabinetshop
#13 posted 06-22-2012 12:39 PM
Sounds like me, too…
Smitty_Cabinetshop
#14 posted 06-22-2012 02:15 PM
Don, that is a nice finish on the Cherry Hoosier above. Wipe on poly is more of a mixture of oils that poly, I think, and I used it on my nightstand. A good there that does not have that plastic look.
As long as it doesn’t splotch, I’m good with it. Deeper the ‘luster,’ the better, too.
But I’m getting ahead of myself. Many steps to go before it gets mounted and filled with tools.
View carguy460's profile
carguy460
802 posts in 2363 days
#15 posted 06-22-2012 03:30 PM
Smitty, I’m getting excited about this project, and I rarely say that about anything! I’m curious to see how you tackle the finish…I’ve just been “commissioned” by my wife to build a cradle type thing, and I think I want to use cherry. I’m fairly new to all this woodworking stuff, so I’ve never used cherry before, but it seems like its pretty nice to work with…is that true?
Great blog series by the way, thanks for taking us along for the ride!
-- Jason K
showing 1 through 15 of 27 comments
