Top joins the sides with half-blinds, so let’s clamp up and get started.
Mark and cut the tails. No dovetail jigs… It’s for strength, doesn’t have to be perfect as a shop joint.
Chop the waste.
Gauge setting for the ‘inset’ of the pinboard, then balance the tail board to tranfer tail lines:
I did place a straightedge alongside the setup to ensure the layoit ot the two pieces stayed ‘square.’
Sawing pins with the DE backsaw, then chopping waste:
Test fit from the saw.
Repeated for the other top corner, and I now have an “assembly!” :-)
A couple of horizontals towards the bottom for dado’ing, so joinery not done yet on this carcase. More to come!
-- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive
18 comments so far
ShaneA
home | projects | blog
3956 posts in 764 days
#1 posted 412 days ago
Nice job Smitty. You do a good job with your pics. Looking forward to more, and the finished project.
Smitty_Cabinetshop
6374 posts in 784 days
#2 posted 412 days ago
Thank you, Shane. Pic taking has almost become second nature in the shop anymore.
JL7
3571 posts in 1130 days
#3 posted 412 days ago
Man – those are some mighty fine dovetails…....very nice!
-- Jeff - I have not failed. I've just found 10,000 ways that won't work.
Smitty_Cabinetshop
#4 posted 412 days ago
Thanks for reading, Jeff!
Dave
9143 posts in 1005 days
#5 posted 412 days ago
Smitty those blind’s are sum nice woodwork. I love a dovetail. And you sir do them justice. Looks as the project is moving right along.
Smitty_Cabinetshop
#6 posted 412 days ago
Super, Most appreciated! Lots to do before tools can get stored inside the cabinet, but it’s the journey right?
Dave
#7 posted 412 days ago
You know it. Its a journey through your imagination, into your hands, passed from your tools to shape the wood.
Jorge G.
1311 posts in 641 days
#8 posted 412 days ago
Nice work on the dovetails, I have a question though, why did you decide to use half blind dovetails? From a design point of view the sides will be the weight bearing elements of the cabinet, I would have used through dovetails to add strength to the sides.
-- Just because you’ve always done it that way doesn’t mean it’s not incredibly stupid.
Smitty_Cabinetshop
#9 posted 412 days ago
JGM- First answer, half blinds come from the inspiration piece that’s been around over 120 years. Second part is much more thoughtful, because this cabinet will get weighted down in the doors themselves, and that’s not the case for the original.
“Sides will be the weight bearing” is true, and sides -to-top joinery is most critical depending also on how this thing gets mounted to the wall as well. When it’s full of tools, doors open wide, there will be outward pressure at the tops of the doors, at the upper hinge. These half-blinds should be as effective as fulls there. So mounting is next. And I do see how full-tailed side boards would be preferred. I’ve thought alot about the hanging stresses that will be present in a cabinet like this, and how best to address them during the build, specifically as the back meets top and sides. Still working through that, actually, but don’t think I’ve bought the farm yet. Also for consideration, there will be a type of corner bracket used underneath, a pair, actually, as extra support when it’s on the wall.
I’ll be sure and talk more about this as the build progresses. Thanks for the comment!
Don W
9932 posts in 733 days
#10 posted 412 days ago
Smitty, those dovetails look great.
Smitty_Cabinetshop
#11 posted 412 days ago
Thanks, Don, very much. Cutting dovetails is one of my favorite activities in the shop, I think.
Brit
4183 posts in 1008 days
#12 posted 412 days ago
Smitty – You’re so honest in your answer to JGM. I would have just said that I couldn’t cut the tails in the side piece because of that stonking great knot right near the top. You’re right though, there will be a huge amount of outward force at the top due to the weight of the doors and there are other ways to counter the downward force on the joinery. Looking good bro’.
-- Andy -- Old Chinese proverb say: If you think something can't be done, don't interrupt man who is doing it.
Smitty_Cabinetshop
#13 posted 412 days ago
Good news, Brit, is it’s getting painted on the outside. So pine is a good material choice for this, knots and all.
AnthonyReed
1332 posts in 606 days
#14 posted 412 days ago
Nice work Smitty! I am really enjoying this, thanks for bringing us along.
-- ~Tony
Smitty_Cabinetshop
#15 posted 412 days ago
Tony, that’s appreciated!
View all comments »
showing 1 through 15 of 18 comments
