Skill Building #4: Raised Panels with the Stanley #78
Blog entry by Smitty_Cabinetshop posted 07-23-2011 06:30 AM 4950 reads 5 times favorited 11 comments Add to Favorites Watch
« Part 3: Mitered Dovetails - Part Three of Three Part 4 of Skill Building series Part 5: More Fun with the #78 and Other hand Planes »
Did a search on LJs for anyone using the venerable Stanley #78 and found nothing. Tonight in the shop I staged a bit of a dry run with the plane, making a ‘raised panel’ drawer bottom, and took some pictures along the way.
First step was to check the iron. I bought the plane probably more than a year ago and my sharpening skills have improved since then, so it was a natural place to start because “sharp fixes everything” and I’m going to be cutting across the grain… The back had to be flattened, but fortunately for me it was concave in the right way. A bit of work through the DMTs had it looking a bit weird, but good.
Did a primary surface sharpening, no secondary bevel or back bevel, by working through all the stones then finishing up with some polishing rouge. Hard to show a good edge with a camera phone, but the reflection shows on this one. We’re ready to get cutting.
To cut a raised panel is to mark the work for the end product. I jointed the edges of the panel stock w/ the #6, then scored lines on the edges and face to mark the extent of the cuts.
Set the fence of the #78 so the iron runs out as far as you want it on the face. For me it was totally subjective; I wanted a wide bevel so set it that way.
Then it’s time to cut. First across the grain,
Then along the sides.
The work itself is straightforward. Angle the tool and work down to the lines along the edge of the panel as well as face, trying to get to both of them at the same time for a most uniform bevel. This would be a drawer bottom, though, so however it comes together is pretty much good. Some finished shots, from removing it from the hold downs to views of the face and edges.
The #78 did the job well, I’d say. Thanks for reading!
11 comments so far
View lysdexic's profile
lysdexic
5255 posts in 2651 days
#1 posted 07-23-2011 06:38 AM
I may have missed it in a previous blog but what wood are you using? Also, did you find it difficult to maintain a consistent angle?
-- "It's only wood. Use it." - Smitty || Instagram - out_of_focus1.618
Smitty_Cabinetshop
15369 posts in 2646 days
#2 posted 07-23-2011 06:40 AM
It’s the Rodney Dangerfield of moving fillisters. :-)
Smitty_Cabinetshop
#3 posted 07-23-2011 06:42 AM
Scott – I’m cutting on 1/2” clear pine, scrap from the drawer sides material I’m using on the Roubo Cabinet. Angle isn’t a big deal, just cut until you reach the scored lines; the ones on the edges are the finished thickness in the rails, stiles and/or drawer side dados, depending on where the panel is going. A big key is having a sharp blade, for sure…
View Don W's profile
Don W
18755 posts in 2596 days
#4 posted 07-23-2011 02:19 PM
great post. I don’t have a 78 yet but its been on my list for a while. I wonder how it would work if you set the fence to make the lip close to the edge (the part that slides into the groove)?
Smitty_Cabinetshop
#5 posted 07-23-2011 04:01 PM
Thanks, Don. I don’t think it’d be a problem to change the size of the bevel or make a cut more rabbet-like, it’s whatever the user wants to do. Set your lines, and start working; it took less than five minutes to complete this sample drawer bottom.
The most commonly raised issue w/ the 78 is it’s fence, and the fact that it rides on one rod when higher end tools use two. On hardwoods, it may be that the fence is hard to keep in place. I’ve done rabbets and now a raised panel with the tool, but always in pine. Fence didn’t budge / was totally a non-issue.
View WayneC's profile
WayneC
13754 posts in 4125 days
#6 posted 07-23-2011 05:34 PM
Looks good. I do not think I would have tried it with a #78. I’ve always considered the #78 more of a tool for rough work. One of the early LumberJocks made a panel raising plane to do this. I went back and found a photo of it…
http://philsville.blogspot.com/2007/06/taa-daa.html
Smitty_Cabinetshop
#7 posted 07-25-2011 04:48 AM
Oo, that is a pretty nice plane. Much easier on the eyes than a #78, for sure.
I see the step part you were talking about earlier. The quick and dirty I demo’d obviously doesn’t do that, so in a nutshell that’s the difference between a bonafide panel plane and a #78 playing at being a panel raiser!
Great picture indeed. Don’t know which I like the most, the plane or all those pretty shaving or the raised panel profile!
WayneC
#8 posted 07-25-2011 04:52 AM
Phil makes some nice stuff… His LJ projects are here… He has not been all that active here for a while.
http://lumberjocks.com/philsville/projects
View rfusca's profile
rfusca
155 posts in 1871 days
#9 posted 07-30-2013 12:00 AM
The pics don’t seem to shoe here for me anymore.
-- Chris S., North Atlanta, GA - woodworker,DBA, cook, photographer
Smitty_Cabinetshop
#10 posted 07-30-2013 03:38 AM
Pictures should re-appear within a day or so (stupid photobucket…)
View Buckethead's profile
Buckethead
3194 posts in 1897 days
#11 posted 06-08-2014 07:24 PM
Smitty… You da man. Thanks for linking to this, Don. We relative noobs missed much.
Raised panels…. Frikkin cool stuff.
-- Support woodworking hand models. Buy me a sawstop.
