Vintage Wall (Tool) Cabinet - Reclaim!
Blog entry by Smitty_Cabinetshop posted 06-17-2011 10:50 PM 4424 reads 0 times favorited 22 comments Add to Favorites Watch
Saw a mid-sized cabinet at a local auction last month, and wanted it. Not because I knew exactly what I’d do with it (isn’t that the way it often is??) but because of it’s age and the way it was constructed. In case bidding didn’t go according to plan, I took a some pictures just to capture the essence of it.
There were a couple of yellow pine battens nailed to the back so it could be nailed to the wall (in the barn?):
Doors looked good, even with baby-turd-brown paint:
But the inside, with some fancy scrollwork edging tall partitions, showed an eye for detail.
The top definitely says it was a one-and-done: hand-cut (kinda ratty) half-blind dovetails:
The cabinet has a bunch of pigeon / cubby holes inside with labels alongside that are legal terms. Including words like Summons, Probation and even Execution. Plus the name of a local newspaper that hasn’t been published since 1893. So the puppy is old! I cleaned it up, removed broken moulding and glued / re-applied it, and otherwise gave it the once-over. The doors and carcase are walnut, with dadoed shelves and pigeon hole cubbies. Decided to follow Dennis’ advise and hang it left of the window, near my workbench, to store hand tools.
Here it is from further back. I love it! A good $20 investment for sure.
UPDATE, Oct 2016: This cabinet served as the Inspiration Piece for my Not-Wall-Hung tool cabinet build and the two sit side by side. The NWH looks awesome, and the turd brown Inspiration Piece didn’t look so go in comparison. So I applied chemical stripper this weekend and got the cabinet all cleaned up.
Doors removed:
Stripper applied:
Mess being made:
Final result is some nice looking walnut!
22 comments so far
View venicewoodworker's profile
venicewoodworker
100 posts in 2504 days
#1 posted 06-17-2011 11:05 PM
Nice cabinet and a nice buy.
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
14970 posts in 2494 days
#2 posted 06-17-2011 11:17 PM
@Venice – I do like saving things like this from (possibly) the scrap pile, especially nice because of it’s age and the fact that the cubbies are right-sized for quite a few things… Top row on the left, for example, holds smaller bench planes perfectly! “Someday” I may strip the paint so the walnut shows…
View EEngineer's profile
EEngineer
1089 posts in 3489 days
#3 posted 06-18-2011 03:03 AM
Very nice save.
Laws are like sausages, it is better not to see them being made.
Otto von Bismarck
Those that respect the law and love sausage should watch neither being made.
Mark Twain
venicewoodworker
#4 posted 06-18-2011 03:55 AM
Smitty, did you see the chest I scored? Check it out under my Antique tool chest blog.
Smitty_Cabinetshop
#5 posted 06-18-2011 02:13 PM
@E- I’ve seen both of those and a number of other discussions of the quote that led me to go with Unattributed. It’s not clear that either were really the original source.
@Venice- I did, and love it! Maybe someday the tool gods will smile on me like that… :-)
View spunwood's profile
spunwood
1198 posts in 2711 days
#6 posted 06-20-2011 02:56 AM
That is a really good find and I’m glad it could be repurposed
-- I came, I was conquered, I was born again. ἵνα ὦσιν ἓν
Smitty_Cabinetshop
#7 posted 06-20-2011 08:44 PM
@Spunwood – Sometimes things fall into place better than expected. Other times, things like this end up being great ideas that ‘devolve’ to projects that never come into being. The sizes being right is the luckiest part of it all; but for that it would have been a ‘gotta tear it apart inside to get it right,’ and likely would have sat for months if not longer. And then wouldn’t have been original, which is important to me, anyway. Thanks for reading!
View Dave's profile
Dave
11426 posts in 2715 days
#8 posted 06-23-2011 02:43 AM
Man Smitty that is one great find. To me its almost as good as building it yourself. Great stuff..
Smitty_Cabinetshop
#9 posted 06-23-2011 07:27 PM
@Super – Thanks, I agree wholeheartedly about build vs. find. Sometimes it’s just fate, I think.
One quirk about the cabinet is the knob; the machine bolt runs through a keyhole in the cabinet door and must have been a very early replacement. I say this because the paint shows wear from contact and the other door, which still has a hook and loop catch to keep it stationary, has no strike plate on it for the lock. And there are no wear marks at all where the lock would have come across it.
The lock was surface mounted on the inside of the cabinet door; you can see in the third picture above all that remains is the plate (no guts). If I can find a good old lock that fits just right, I’ll put it on the cabinet and use it that way. So the hunt is on!
View RGtools's profile
RGtools
3372 posts in 2530 days
#10 posted 06-26-2011 04:39 PM
nice addition
-- Make furniture that lasts as long as the tree - Ryan
View BarbS's profile
BarbS
2434 posts in 3961 days
#11 posted 06-26-2011 05:57 PM
Oh wow, what a great find. And it works Wonderfully in your shop. How great!
-- http://barbsid.blogspot.com/
Smitty_Cabinetshop
#12 posted 06-29-2011 02:54 PM
Thanks, Barb and RG!
View Bertha's profile
Bertha
13495 posts in 2568 days
#13 posted 06-29-2011 02:56 PM
That’s great, Smit. I’m intrigued by the back design!
Smitty_Cabinetshop
#14 posted 06-29-2011 03:02 PM
@Al – the back is simply a number of 1/2”-ish boards set into rabbets cut into each side and nailed into place. Not half lapped or matched / nothing fancy. I made the brackets and cleat to set it on when mounting to the wall ; so therr’d be enough strength to hold when fully loaded…
Bertha
#15 posted 06-29-2011 03:04 PM
Smit, where am I seeing those largish finger-joint type joints? Oh, you just told me! I was looking at the top, confusing it for the back. Let me rephrase, “I’m intrigued by the TOP design”!
showing 1 through 15 of 22 comments
