Misc. Shop Stuff #70: Another Simple Cabinet
Blog entry by Smitty_Cabinetshop posted 01-11-2019 03:39 PM 1339 reads 0 times favorited 54 comments Add to Favorites Watch
« Part 69: A Simple Cabinet Part 70 of Misc. Shop Stuff series no next part
It begins anew…
For background, check here. And new build stuff could be on the OP (here) or below, so stay alert. ;-)
First, find some pine. Never mind the one piece had a huge stress crack in it; cut it out, joint the edges and make a good board out of it.
Those were gonna be the sides, then the second board needed attention.
Then the first one had issues…
So, new stock was chosen.
Marked and cut corners for face frame pieces.
Sized and jointed those face pieces, pulling the No. 9 mitre plane into service.
Add some square nails.
And we’re making progress!
The back of these cabinets has 1/4” T&G, so a rabbet is needed. Press the No. 78!
And celebrate the Humble #205 Clamp along the way.
Work the top and bottom plates, getting length right for the inserts before marking to proper width.
Rip pieces for door panel, rails and stiles, via RAS…
then groove w/ Stanley No.48 T&G plane.
Found the stock to be made into the upper and lower moulding.
Grain is tight and straight, as it should be.
54 comments so far
View Mauricio's profile
Mauricio
7150 posts in 3392 days
#1 posted 01-11-2019 04:25 PM
That’s coming along nicely! Nice to see your still cranking out beautiful hand work in the shop.
Smitty_Cabinetshop
15822 posts in 2859 days
#2 posted 01-11-2019 04:29 PM
Hi Mauricio! Thanks, and good to see you!
View theoldfart's profile (online now)
theoldfart
10309 posts in 2691 days
#3 posted 01-11-2019 04:59 PM
Maur, the operative term here is crank. The man’s a machine. And good to see you as well.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
Mauricio
#4 posted 01-11-2019 05:43 PM
Good to see you to OF
View Don W's profile
Don W
19050 posts in 2808 days
#5 posted 01-11-2019 10:40 PM
You’re on a roll. Glad to see somebody is getting some shop time. This weather suchs!!
Smitty_Cabinetshop
#6 posted 01-12-2019 03:40 AM
Got the mended board out of clamps, flattened the face a bit.
Used a winding stick from BYo to check edge.
Jointer: the Original H&H
Ripped both boards to width, a problem with the other one: funky face split.
Glue and clamps, keep moving.
Why do I aggravate myself, right?
theoldfart
#7 posted 01-12-2019 07:13 AM
But you do do it with style dude! :-)
BTW, nice Colt clamps.
View stefang's profile
stefang
16219 posts in 3574 days
#8 posted 01-12-2019 12:32 PM
Enjoying your handwork posts as usual Smitty. Makes me wish I were in better shape to do something similar. Quite a difference from using loud and dusty machinery, not to mention the advantage of not requiring a large space to accommodate all the tools.
Smitty_Cabinetshop
#9 posted 01-12-2019 06:45 PM
Progress.
Some detail later.
Smitty_Cabinetshop
#10 posted 01-12-2019 09:27 PM
Had to abandon one board and find a replacement, as I missed this curve.
View AnthonyReed's profile
AnthonyReed
10084 posts in 2681 days
#11 posted 01-12-2019 10:04 PM
I was shocked to see that a stick eventually came along that you didn’t bend to your will. You’re a force to be reckoned with.
-- ~Tony
View Brit's profile
Brit
7609 posts in 3083 days
#12 posted 01-13-2019 12:52 AM
That’s some good honest graft right there Smitty. The shavings on the floor say it all. My shop is in the same state. I got a full day in there today and it was great.
-- Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
theoldfart
#13 posted 01-13-2019 03:03 AM
Andy, your point of view is diametrically opposed to my middle grandchild! I was informed today that my shop is messy and I had better get it clean. We had just made a heart cut out using a turning saw.
Smitty_Cabinetshop
#14 posted 01-13-2019 05:59 AM
Need shop pics, Andy! And, more added above.
Smitty_Cabinetshop
#15 posted 01-13-2019 06:28 PM
Okay, all caught up with posting pics and progress above.
showing 1 through 15 of 54 comments
