Indexing on a Wood Lathe #1: Setting up a 36 and 72 Degree Index
Blog entry by Jim Jakosh posted 07-04-2015 06:03 PM 2390 reads 1 time favorited 12 comments Add to Favorites Watch
no previous part Part 1 of Indexing on a Wood Lathe series no next part
I have a locking index wheel built into my Craftsman lathe and it works well but it is set at every 15 degrees. In an effort to make 5 or 10 equal divisions, I found I needed another index wheel so I decided to add it to back of the lathe chuck. I used aluminum but hardwood or steel would have worked too. I was wondering what I had in my shop that was accurate for setting degrees and pulled the Wixie box(Grizzly version). I mounted a steel bar on the plate for the back of the chuck so the Wixie would hold there.
I mounted the plate in an indexing head I made for the mill and used the Wixie to set it in the right position.
Then I made a stand out of some steel pipe and a nylon sleeve that was threaded for a locating pin to go into the index holes and had a slot to go around the wheel to counter the torque.
The knob is made of jarrah and I got to use my wood knurling tool to add a grip surface.
With the wheel locked in place, I center drill holes for the pattern at 72 degrees apart.
Then I turned a sample piece to see how close it came to what I wanted. I checked the hole spacing and 2 were .020” out for the worst error.
This is what it looks like in action. You just focus on the center pattern
And this is the finished piece made from 1/2” x 8” plywood and painted flat black. It is best to use hardwood because the plywood fuzzes a lot.
Cheers, Jim
12 comments so far
View Joe Lyddon's profile
Joe Lyddon
10097 posts in 4050 days
#1 posted 07-04-2015 06:15 PM
WOW!
SUPER COOL!
Almost looks like a fan!
View stefang's profile
stefang
15881 posts in 3332 days
#2 posted 07-04-2015 06:21 PM
Great set up Jim. Your project looks wonderful too.
View Arlin Eastman's profile
Arlin Eastman
4216 posts in 2559 days
#3 posted 07-04-2015 07:16 PM
Jim
I am lucky I have one build in on my lathe. What is the bolt’s purpose?
-- It is always the right time, to do the right thing.
View peteg's profile
peteg
4284 posts in 2821 days
#4 posted 07-04-2015 09:36 PM
Super cool Jim, boy you’ve got some great gear in that shop of yours, I see you managed to score a second banjo for the indexer set up.
You could almost market these as a retro unit for most existing lathes.
Nice design & engineering Mate
cheers
pete
View Jim Jakosh's profile
Jim Jakosh
20482 posts in 3103 days
#5 posted 07-04-2015 09:38 PM
Thanks Joe, Mike and Arlin.
Hi Arlin. I have a good one built in my lathe too, but it is only by every 15 degrees. I can’t make 36 or 72 degrees with it for 5 or 10 equal divisions, hence this project.
The bolt with the red handle is turned down to 1/4” on the end and is the locator for each position. It goes into the holes in the index wheel.
The other 1/2” bolt holds the wheel on the fixture while I drilled it in the mill.
View doubleDD's profile
doubleDD
7383 posts in 2041 days
#6 posted 07-05-2015 08:53 PM
Well done Jim. Great idea. I haven’t used my indexing spindle yet, but great to know when the time comes.
Arlin Eastman
#7 posted 07-05-2015 09:07 PM
Thanks Jim
I am thinking your way might be easier then mine. I will have to check on the how many holes it has. I thought I had 24 and that would come up to 15 degrees so I will have to make sure.
I do know there is one out there that has 360 holes in it for indexing and that might be nice too.
Jim Jakosh
#8 posted 07-06-2015 02:26 AM
Thanks , Dave
Hi Arlin. That would be nice to have a hole at every degree but the wheel would have to be very big and the holes very small…. Or maybe 2 or 3 rows of holes. My 2 craftsman lathes have 24 hole indexes on them but one does not lock, the index pin is 1/16” out of line with the holes It will take a bit of dis assembly to get in there to correct it so I use the one that works for index work.
Cheers, Jim
Jim Jakosh
#9 posted 07-10-2015 03:45 AM
Well I almost had my first project with 5 rings. I used 1/2” x 7 1/2” corian and held it on the spigot for turning the first side with all the big rings. I don’t know what happened first but the corian broke loose from the spigot and it took a little chip out of the 3rd ring I had in it. Luckily had the tailstock center up against it with a nylon cap on it for stabilizing it so it did not fly out at me. Not giving up. I found the center , drilled a hole and mounted it on a 5/16 bolt and all was going well.
Corian sure makes a mess!!
Right after these photos, the tool bit caught, broke in two and took out a half of one of the rings with it. I was in 1/4” deep at the time. You wont’ see any more corian trivets tried this way from me!!
Cheers, Jim
peteg
#10 posted 07-10-2015 07:29 AM
Sometimes we just learn the hard way Jim, tough outcome mate, I guess it’s all just part of the fun & it’s what keeps us coming back for the next round of the good game :)
cheers
pete
Jim Jakosh
#11 posted 07-10-2015 12:13 PM
That’s right, Pete . I try anything once and twice if it works!! I have an idea that one of the welds broke on the tool when the spigot came off and I never saw it. It just took one more catch to finish the job. I’m going to try to stick to 3/8” stock for any of these just so those tiny bits don’t have to go so deep. Any of the corian I get is 1/2” and I may still make round trivets with it, but not these see-through ones, My wife wants an oval one for long dishes and that presents more challenges but I’m working on it!! I like to make things people actually need at the time. These trivets are just fun stuff….............ain’t that what retirement is supposed to be about??
Cheers, Jim
View John Stegall's profile
John Stegall
505 posts in 3514 days
#12 posted 12-01-2015 12:04 AM
Jim, is there a way to make two and then join them? Or use a router? Yours look so good that there must be a way to make that long one.
-- jstegall
