Turning a Wooden Scoop #1: How I turn a sccop on the lathe
Blog entry by Jim Jakosh posted 06-27-2015 08:55 PM 3741 reads 11 times favorited 25 comments Add to Favorites Watch
no previous part Part 1 of Turning a Wooden Scoop series no next part
Candy, this blog’s for you!!!!!!!!!!!
This is the process I use to turn a scoop from a wood blank on the lathe.
I start by defining the volume needed in the the scoop. The formula is Pi x R squared x depth
I planned on a 1/2 cup scoop and the volume of 4 oz is 7.218 cubic inches and I want the inside to be 2 5/8”
So the formula is 3.1416 x ( 1.312) squared x depth = 7.218. The depth figures out to be 1.33”
I start by drawing it out and then adding scrap wood in the areas for holding the part in the process. That will give me my overall blank size.
I chose this old Juniper log to cut it out of and start it on the band saw .
I layout the pattern on the block including the scrap areas and rough out the shape.
I put in the center holes for the turning axes and then take it to the lathe.
I start by turning the bottom to establish the outside finished diameter and add the spigot on for holding in a later step.
While turning it I discovered cracks near the base of the handle and wanted to repair them right away so I mixed up epoxy and sanding dust from the juniper to fill the cracked area. The moral of the story is don’t include the pith in a project like this if you can help it.
I turn that flush and then load it to turn the handle. The finished diameter has to be established before you turn the handle so you know where to stop the handle so it blends into the side of the scoop,
Then you use that spigot on the bottom to hold it to bore the inside. I drill it just short of the 1.33 depth and than remove all the material with a 3/8” bedan to get a square corner and flat bottom. Almost no sanding needed.
When the inside is done, I mount it on a jam chuck with white shelf liner material in between the parts and turn the bottom off and add some decorative grooves .
Now that the turning is done, the scrap has to be removed and the scoop needs to be sanded to shape.
A coat of salad bowl finish and it is ready to use.
Cheers, Jim
25 comments so far
View lew's profile
lew
12060 posts in 3754 days
#1 posted 06-27-2015 09:04 PM
Nice!
I’m always afraid I’ll beat my knuckles to death making one of these!
View Jim Jakosh's profile
Jim Jakosh
20483 posts in 3104 days
#2 posted 06-27-2015 09:17 PM
Hi Lew. You have to keep your wits about you when that thing is flying around. I moved the steady rest into the handle once when turning the bottom off. .I just heard the ticking and stopped it before it hit it too hard. The game would have been over then!!
Cheers, Jim
View John Stegall's profile
John Stegall
505 posts in 3515 days
#3 posted 06-27-2015 10:03 PM
Thanks for blogging this Jim. I am also going to tackle your trivet.
-- jstegall
View CFrye's profile
CFrye
10192 posts in 1838 days
#4 posted 06-27-2015 10:17 PM
Thanks for revealing your ‘secrets’, Jim! For now I’ll stick to the 2 piece construction (yes, I am a coward)!
-- God bless, Candy
View JoeinGa's profile
JoeinGa
7736 posts in 2006 days
#5 posted 06-27-2015 10:40 PM
Thanks Jim. Cool little scoop. A bit scary for a newbie, but I just might be brave (or stupid) enough to try it ! :-)
Jim Jakosh
#6 posted 06-27-2015 11:22 PM
Thanks for looking!!Aw come on Candy, it is no big thing to make one. You just work on what is in front of you and let the rest of it fly in the back ground. I just looked on U tube and there are a lot of videos on making them but none use my method. This way takes no special tools- just use centers and chuck
Hi John. I can’t wait to see your trivet!
Hi Joe, you can do it . Just keep in front of the spinning background stuff and watch the tools support before turning on the lathe. That is the biggest concern for me. I kissed the handle once with my support!.
cheers, Jim
View luv2learn's profile
luv2learn
2763 posts in 2301 days
#7 posted 06-27-2015 11:40 PM
Awesome tutorial Jim. I will have to give this a go.
-- Lee - Northern idaho~"If the women don't find you handsome, at least they ought to find you handy"~ Red Green
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1175 days
#8 posted 06-28-2015 12:03 AM
As others have said, Thanks.
23928 posts in 3850 days
#9 posted 06-28-2015 12:45 AM
Great blog Jim and a nice job on the scoop.
View BobWemm's profile
BobWemm
2450 posts in 1925 days
#10 posted 06-28-2015 02:44 AM
That makes it look so simple.
Excellent info Jim.
-- Bob, Western Australia, The Sun came up this morning, what a great start to the day. Now it's up to me to make it even better. I've cut this piece of wood 4 times and it's still too damn short.
View doubleDD's profile
doubleDD
7383 posts in 2042 days
#11 posted 06-28-2015 03:00 AM
Thanks Jim. I see the trick of leaving on the extra wood on the cup portion for the center, then cutting it off later.
Great show and tell.
Jim Jakosh
#12 posted 06-28-2015 03:48 AM
Thank you all for the nice comments. I hope this helps clear up any mystery to making these. You just do one part at a time. It did not take long once it was on the lathe. I was turning a taper on the Southbend lathe with the power feed on while making this one.
Cheers, Jim
View Rustic's profile
Rustic
3253 posts in 3595 days
#13 posted 06-28-2015 04:30 AM
nice blog this would be a nice demo at the guild
View bushmaster's profile
bushmaster
3068 posts in 2281 days
#14 posted 06-28-2015 04:48 AM
interesting procedure every well done
-- Brian - Hazelton, British Columbia
View stefang's profile
stefang
15881 posts in 3333 days
#15 posted 06-28-2015 07:16 AM
Great looking scoop Jim and a very well done tutorial, you should do more of them!
showing 1 through 15 of 25 comments
