Wine bottle balancers #1: How to bore the balancer hole for a level bottle
Blog entry by Jim Jakosh posted 190 days ago 1864 reads 16 times favorited 14 comments Add to Favorites Watch
no previous part Part 1 of Wine bottle balancers series no next part
Today I modified my balancer drill fixture in many ways. It was originally built to bore a 1 5/16” hole at 45 degrees through the wine bottle balancer, but it had a few problems. first, the Forstner bit would twist and lock up before it got through the board. The bit got smoking hot and expanded in the hole and did not retract easily. And the bottle did not balance level!
First I milled out the bottom of the fixture 1” deep for a sacrificial piece of wood so the drill is always cutting on all sides until it is through the piece. It just happened that as we were visiting our plywood guy, they had some crates out in the free bin and we picked up one. I broke it up and cut the boards into my sacrificial blocks. That crate will make about 70 of them. They were just about the right thickness too!!
Thanks to my friend , Kent Ball , from Idaho I found that spraying the bit with silicone helps tremendously in reduction of heat from friction on a Forstner bit. I sprayed the bit in my scrap barrel so it did not get around in the shop. Silicone can play havoc with finishing material!!
Then I modified the angle on the fixture to drill at 35 degrees with two little feet mounted on the front. I made a new guild bock for the new angle , too.
After drilling, I just knock the little bock out and insert a new one and it is ready to go again
One after another, the bottles, empty or full , balance much closer to level
The hole location is 8” from the base and the base is cut at 50 degrees.
Some of these will have the wine bottle inlaid and some will be lasered in.
I’ll post all the balancers when I get the group finished.
.............Jim
-- Jim Jakosh.....Practical Wood Products...........Learn something new every day!!
14 comments so far
View MShort's profile
MShort
1379 posts in 1590 days
#1 posted 190 days ago
Jim,
You have been qutie busy lately. Thanks for the blog tutorial. I will have to give this a try sometime.
-- Mike, Missouri --- “A positive life can not happen with a negative mind.” ---
View Bob Collins's profile
Bob Collins
1128 posts in 1855 days
#2 posted 190 days ago
Nice blog Jim, thanks for sharing.
-- Bob C, Australia. I love sharing as long as it is not my tools
View sedcokid's profile
sedcokid
2508 posts in 1770 days
#3 posted 189 days ago
Great blog Jim,
Thanks for sharing
-- Chuck Emery, Michigan,
View JoeyG's profile
JoeyG
1161 posts in 797 days
#4 posted 189 days ago
Thanks for the blog. I have two of these that will be going with a box and while I understand the concept, I have never made a bottle balancer. It’s nice to have your right up as a reference if I need it.
Thanks,
Joey
-- JoeyG ~~~ http://www.facebook.com/JHGWoodWorks
View Roger's profile
Roger
9192 posts in 976 days
#5 posted 189 days ago
Looks like a winner Jim
View mafe's profile
mafe
8057 posts in 1261 days
#6 posted 125 days ago
Clever Jim!!
There is a reason all you make is so crisp!
Best thoughts from the owner of the coolest awl in Denmark,
Mads
-- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking.
View Jim Jakosh's profile
Jim Jakosh
7332 posts in 1277 days
#7 posted 120 days ago
Thanks, Mads. I’m glad you like the awl and hope you use it a lot!!
I have not posted much lately. We are building a wood shop here in the park and have been scrounging material and tools from every where. We now have a Craftsman table saw, Makita sliding miter saw.a Grizzly 14” band saw, a HF 4” belt sander, a HF 6” tool grinder, two Skill saws, 3 routers and a bunch of hand tools …......Jim
View mafe's profile
mafe
#8 posted 119 days ago
Hmmmm sounds good!
Building here in the park? What does that mean?
best thoughts, Mads
Jim Jakosh
#9 posted 114 days ago
We stay in an RV park in our motor home in the winter. We now have an enclosed wood shop that we just bought the last door and locks for today. We looked a a drill press today but it was too much for it.
This shop is 19’X36’ and I’ll post some before and after pictures when we get it done. It is not real pretty but pretty functional!!..........Jim
View mafe's profile
mafe
#10 posted 113 days ago
Look forward to see this.
Also a picture of the motor home pls.
Best thoughts my friend,
Mads
Jim Jakosh
#11 posted 113 days ago
Hi Mads. I sent you an E mail with pictures of the motor home and the original look of our new shop before we did the framing!.............Jim
View mafe's profile
mafe
#12 posted 113 days ago
Got it!
View BNE's profile
BNE
1 post in 15 days
#13 posted 15 days ago
Jim – nice work. Would you be willing to share a more detailed plan for the jig? Let m eknow as I really like this idea. Thanks.
Jim Jakosh
#14 posted 15 days ago
Hi BNE…........first of all WELCOME TO LUMBERJOCKS!!!!!!!!!!!
Let me know what details you want in a p.m. and I’ll try to fill you in.
The object of the jig is to hold the balancer and the guide within the fixture so it stays centered. Then with you drilling down, all the force is down toward the corner so both pieces stay in place pretty good. I found that if you come through a piece with any drill, the drill wants to walk toward the side where there is no resistance, so I put a scrap block in the bottom so the drilling is always balanced all the way through the part
Jim
