Cutting a Triangular Obelsik
Blog entry by Jim Jakosh posted 09-14-2012 01:31 PM 2078 reads 1 time favorited 4 comments Add to Favorites Watch
Lizzardhead, this one’s for you!!
Dave once asked me if I could make a 3 sided obelisk. I have been thinking about it and I cut a scrap of spalted beech cut to a triangular shape and set it under the bench while I thought about how to hold it. I came up with this method to safely cut the triangular piece to the center point. I made an L shaped support from scraps and then fastened the bottom of the triangle to it with 2 screws.
I first marked off the center of the triangle on the top and the bottom of the piece. Then I drew a line from the bottom corner of the first side to cut to the center of the top.
I mounted the triangle to the L block with one screw and spotted the second hole location when the side to cut was truly vertical.
Then I cut it on the band saw from the center of the top to the bottom outer edge.
I repeated that process for the the other two sides to draw the line to the top center from the base and had to use a piece of scrap under the part to support it during the cut. I cut though it in the process, but that’s okay.
The last cut was the tricky part because the center is no longer at the top of the piece because I cut that away. So I used a square to transfer the center from the bottom to the top and mark it and draw a line to the base for the last cut.
I found that you lose about 30% of the length in this last cut so you have to plan for that for your final height of the piece. On a 4 sided obelisk, the start height is the final height.
This was not a project but a just a test to see how it worked and it cut very easily and safely in this way.
Here is the final obelisk with 2 coats of Clear Matte spray:
4 comments so far
View chrisstef's profile
chrisstef
17104 posts in 2877 days
#1 posted 09-14-2012 01:44 PM
Jim … i treied cutting one of these when i was doing my lombardi trophy replica … it melted my brain trying to figure it out. Youre a smart fella i say! I will use this, thank you.
View wiswood2's profile
wiswood2
1138 posts in 3567 days
#2 posted 09-14-2012 04:02 PM
Great job.
Chuck
-- Chuck, wiswood2 www.wisconsinwoodchuck.com
View Jim Jakosh's profile
Jim Jakosh
19957 posts in 2976 days
#3 posted 09-14-2012 05:22 PM
I’m glad someone will get some use of this,Chrisstef. I knew I could do it, but it took a while to find out how.
The important part is that the side you are cutting is vertical and held that way through the cut. I tried holding it on a spacer block and it would roll from side do side. You will need to start with a longer than you need block for the loss on top and some off the bottom if you don’t want any holes in it. Like if you want a 10” high obelisk, I’d start with a 14” blank. Good luck…...........Jim
View gfadvm's profile
gfadvm
14940 posts in 2561 days
#4 posted 09-15-2012 01:57 AM
That is very a impressive solution. I got a pounding headache just trying to follow along! If I ever need one of these, I’m gonna hire you to cut it.
