Wood Lathe Router Guide #1: Wood Lathe Router Guide
Blog entry by Jim Jakosh posted 09-12-2012 03:36 AM 12604 reads 14 times favorited 17 comments Add to Favorites Watch
no previous part Part 1 of Wood Lathe Router Guide series no next part
I’ll take you through the steps I used to build my router guide for my wood lathe. It is essentially a box with adjustable sides and top which has a slot to guide the router bushing. It is made from 5/8” plywood, clear Lexan, Steel and aluminum.
I started with a 11.5×11.5 bottom and cut rabbets on both sides on the table saw and made a cut out for the tail stock. The sides were glued in place held square by a couple scrap blocks. They had T nuts installed for the adjustment screws
The I glued in 4 gussets to hold the box square.
I then centered the bottom guide for the ways in the lathe. It was doweled in place after being set to exactly in the center.
The sides were slotted for the vertical adjustment but I did not have a shot of the radial slots I routed in with my router radius guide. They are shown with the sides in place.
The Lexan top was cut on the table saw and jointer and then had the aluminum blocks added for the threads for the top and the tilt adjustment. The holes were spotted from the upper sides and power tapped on the drill press.
After checking the centering of the fixture to the lathe, I rough cut the slot in the top on the scroll saw to remove the bulk of the material.
The top was then mounted in the mill and the edge was indicated for straightness to the machine and the .625” router bushing slot was cut on center.
It was now ready to try out in the lathe. I first had to make a maple pointer for the index wheel on the back of the lathe. I painted it black and made a silver tip on it.
One of the build criteria was that it needed to be adjustable both ways without turning it around in the lathe. That was done by adding the radial slots and threaded adjustment screw thread in the top.
It can tilt left or right up to 30 degrees for fluting surfaces at an angle. You just take out two of the top wing screws and re locate them in the radial slots and it will swing down.
Now for cutting with the plunge router. I used a scrap piece that was already turned round and a 3/8” bit that was in there from the radial slotting.
Now it is just waiting for its first real job!!
I knew I needed stops for the router and I will make some that sit on top with slots in them and that go around the router to be set to stop the base. I was going to make them sit in the groove to stop the bushing, but I think the ones on top will be more effective and easier to adjust while they are out of the chips.
.....................................................Jim…........... 9 11/2012
17 comments so far
View woodworkerscott's profile
woodworkerscott
361 posts in 2842 days
#1 posted 09-12-2012 03:49 AM
A lot of good designing and planning made for a great router jig for the lathe. I am getting ready to make a router jig for the lathe for tapering purposes.
Glad to see this post. Nicely done! Thanks for the pics and info.
-- " 'woodworker'.....it's a good word, an honest word." - Sam Maloof
View peteg's profile
peteg
4299 posts in 2851 days
#2 posted 09-12-2012 04:09 AM
Wow Jim this is a serious sort of jig, looks like it’ll handel almost anything between centres
Goin to save this one and study it a bit further, thanks for the info very well done Mate:))
pete
View Joe Lyddon's profile
Joe Lyddon
10123 posts in 4080 days
#3 posted 09-12-2012 04:39 AM
Looks like some of Harry’s work is rubbing-off…
Looking good!
Simple way of cutting for sliding Dovetails isn’t it?
View rance's profile
rance
4258 posts in 3189 days
#4 posted 09-12-2012 04:42 AM
Fabulous work there Jim. I could see this in use with both the indexing on the lathe as well as with the lathe running. Very well done. Thank you for sharing your engineering.
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2884 days
#5 posted 09-12-2012 07:12 AM
Jim you are a Wizard in disguise
The is a very well thought out
and built jig
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View Bob Collins's profile
Bob Collins
2520 posts in 3712 days
#6 posted 09-12-2012 09:19 AM
Great piece of engineering Jim, I can see where you re going with this one. Will store this away for later.
Thanks for sharing.
-- Bob C, Australia. Your best teacher is your last mistake.
View sedcokid's profile
sedcokid
2733 posts in 3627 days
#7 posted 09-12-2012 11:41 AM
Jim, You amaze me, with all that you do. And now I get to see your engineering abilities!! Can’t wait to see this produce your first real project!!
Thanks for Sharing
-- Chuck Emery, Michigan,
View harry1's profile
harry1
524 posts in 2313 days
#8 posted 09-12-2012 01:28 PM
I was hoping to improve on what you came up with Jim.,but WOW, you are one very serious jig maker, I reckon that jig will be copied by turners around the world.
-- Harry, Western Australia
View Jim Jakosh's profile
Jim Jakosh
20600 posts in 3134 days
#9 posted 09-12-2012 02:07 PM
Thank you all for all the nice comments!
G’day,Harry, you were my inspiration on this one!! Thank you!!
I remember talking to you about the tilt portion and this was the best I could do within that box to miss the vertical slots.
I hope it gets copied. I love to share ideas with everyone!
It helps to have a milling machine and this great plywood!
......Jim
View Julian's profile
Julian
1348 posts in 2718 days
#10 posted 09-12-2012 02:57 PM
Great jig. I need to eventually make something similar.
-- Julian
View lanwater's profile
lanwater
3111 posts in 2962 days
#11 posted 09-12-2012 04:35 PM
Thanks for the details Jim. The pictures convey the building steps quite nicely.
Great Jig.
-- Abbas, Castro Valley, CA
23997 posts in 3879 days
#12 posted 09-13-2012 02:56 AM
Excellent jig Jim. It’s in my favorites box for further reference.
View mafe's profile
mafe
11730 posts in 3117 days
#13 posted 09-13-2012 08:38 PM
Jim this is so cool.
Thank you!
The jig is as all you do full of details and good thinking and the blog documents it so weel.
Best thoughts my friend,
Mads
View Roger's profile
Roger
20929 posts in 2832 days
#14 posted 09-14-2012 01:53 AM
Wow! Jim! Way kool! How, or do you lock the piece from spinning. Thnx in advance
Jim Jakosh
#15 posted 09-14-2012 02:22 AM
Hi Roger. I have to have the piece in a chuck or with a driver buried in it to hold it to the machine. Then in the back where my indexing wheel is, there is a red lever that pushes a pin into the indexing ring and locks ‘er up to keep the spindle from turning during the cut….............Jim
If you right mouse on the 12th photo and click on view image, it will show you the whole picture and then you can see that red lever by the pulley. I don’t know why these photos pulled in with photobucket don’t come out full size right away.
