Stabilizing punky and end grain wood
Blog entry by Jim Jakosh posted 365 days ago 1691 reads 6 times favorited 12 comments Add to Favorites Watch
At our last guild meeting we had a meeting in my shop until almost midnight and I learned something new before the day ended from a couple of experienced turners. When you have end grain that will not stop tearing out in the lathe or real punky wood that may crumble when you hit it, you can stabilize it using Minwax Pre-Stain Wood Conditioner. You rough turn the bowl to a 1” or less wall . Then submerge the bowl in it for an hour or fill the inside of it and wait until you see it come all the way through to the outside. It takes a quart or more to do it but you can use over what did not soak in. Then let the bowl dry for at least a week before finish turning. I have often tried to fill bad areas with epoxy but wind up turning it all away to no advantage. This way the wood is stable all the way through .
I have two bowls in it right now and will prove it out in a week!......................Jim
-- Jim Jakosh.....Practical Wood Products...........Learn something new every day!!
12 comments so far
View tyskkvinna's profile
tyskkvinna
1294 posts in 1154 days
#1 posted 365 days ago
I have used that stuff before.. with good luck!
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View Jim Jakosh's profile
Jim Jakosh
7257 posts in 1273 days
#2 posted 365 days ago
That is good to know, Lis. You are the third supporter!!
I did the two bowls and used less than a half pint!
............Jim
View ShopTinker's profile
ShopTinker
862 posts in 936 days
#3 posted 365 days ago
That sounds like what I need to treat my 100+ year old wood screw vice. The wood threads are really soft so I don”t use it much and when I do it’s done gently. Thanks for the tip.
-- Dan - Valparaiso, Indiana, "A smart man changes his mind, a fool never does."
View TurnTurnTurn's profile
TurnTurnTurn
414 posts in 1277 days
#4 posted 365 days ago
Let us know the results. Thx for sharing.
-- TurnTurnTurn
View sedcokid's profile
sedcokid
2506 posts in 1766 days
#5 posted 365 days ago
Jim, Sounds like a great tip. Will be interesting to see and hear your findings.
Thanks for sharing!
-- Chuck Emery, Michigan,
View Roger's profile
Roger
9191 posts in 972 days
#6 posted 365 days ago
Gr8 information. Thnx for the tip
View Woodstock's profile
Woodstock
187 posts in 1456 days
#7 posted 364 days ago
Good timing for posting this as I am i the middle of cutting up two pickup loads of silver maple that was harvested last season that already had a lot of spalting / punky wood before it was removed from someones front yard and eventually will be cut up into turning blanks.
This sounds promising, but in doing a bit of research online I have a additional question.
Which one? The local borg lists a oil base (red label) and a water base (cream color label) pre-stain conditioner by Minwax. I’m guessing the water based version would be absorbed deeper. Does anyone know?
-Dave
-- I'm not old. Just "well seasoned".
Jim Jakosh
#8 posted 364 days ago
I was told to use the oil based stabilizer. I poured in in the bowl and filled it to the brim. In less than an hour it was to the outside of the bowl with a 3/4” wall. It goes all the way through if you soak it. I can turn it on the 27th…...............Jim
View mafe's profile
mafe
8055 posts in 1257 days
#9 posted 356 days ago
This can be great for restore, you got me thinking.
Best thoughts,
Mads
-- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking.
Jim Jakosh
#10 posted 349 days ago
Well I tried 2 of the bowls and the pre stain conditioner did help clean up the turning of the end grain. The punky stuff still was wide open and I took it off and filled it with 5 minute epoxy and sawdust. I heard this week end at the art festival that black CA glue works good for filling cracks and voids. I will try that too so I can save this piece of great spalted beechwood I have yet to finish. You can get that CA glue at Woodcraft.
..............Jim
View Joe Lyddon's profile
Joe Lyddon
6390 posts in 2220 days
#11 posted 349 days ago
Jim,
Here is The Best place to get CA glue, in my experience.
They are good! Quality… Prices… Delivery… 2nd to none… The Best! IMHO
I have used the Thin to treat the end grain… prior to routing the edge…
... has worked beautifully!
I hope this helps you… You have sure helped US!
Thank you.
Jim Jakosh
#12 posted 348 days ago
Thanks, Joe. I ‘ll be getting some there! Prices are right!!
Thanks, Jim
