The following pictures show how I made the hinged obelisk.
I started with a plan for a shelf size where the obelisk was to be cut in half so it would be big enough for the 1 1/4” hole for the candle and the two brass pins. It was supposed to be 2” square which meant about a 4×4x8 block. the wood was so chewed up by ants that the biggest block I could get was 3 5/8” square x 8”. I laid out the cut lines and that left a shelf size of 1 7/8” square which was going to have to do.
I made the first cut on the back:
I leveled the surface on the jointer and then set it up level in the mill and cut the hinge pocket:
then I cut it in half at the designated level:
I used the scrap from the first cut to cut out the hinge pieces:
I sawed it into a hinge on the scroll saw:
Then I split the hinge so I could put in blind holes into the sides. I drilled the center section through and then spotted the centers to the sides with a small spotting pin.
I put in a 1/8” steel pin and glued it together and then glued it into the milled opening after fitting it so the pivot was exactly on the center of the split:
then I laid out the center of the brass bushings and the 1 1/4 candle hole and spotted them to the top section. I drilled all the holes:
With the pins in place to hold the alignment, I finished the next
three cuts to make the obelisk:
Here it is put together and opened:
-- Jim Jakosh.....Practical Wood Products...........Learn something new every day!!
10 comments so far
Dan'um Style
home | projects | blog
10754 posts in 2148 days
#1 posted 509 days ago
nice blog … fun read
-- keeping myself entertained
degoose
6588 posts in 1520 days
#2 posted 509 days ago
Swell blog…
sedcokid
2500 posts in 1764 days
#3 posted 509 days ago
Excellent Blog…... Another thing you are good at!!
Thanks for sharing
-- Chuck Emery, Michigan,
Bob Collins
1122 posts in 1849 days
#4 posted 509 days ago
Nice clear to read and understand. Thanks for sharing Jim. You are getting to be a master at these.
-- Bob C, Australia. I love sharing as long as it is not my tools
rance
3854 posts in 1326 days
#5 posted 509 days ago
Only one thing to say:
Obelisk Navidad
lanwater
2417 posts in 1099 days
#6 posted 509 days ago
very nice blog Jim.
Love the detailed pictures. thanks for sharing.
sras
3222 posts in 1294 days
#7 posted 509 days ago
Very clear description on an interesting project. Thanks for sharing!
mafe
8055 posts in 1254 days
#8 posted 508 days ago
Really a nice tour.
You sure are a man of precission, I like the idea of the spotting pin, I use these for dowels.
Nice detail whith the metal plate in the lid it must reflect the candle light really fine.
Best thoughts,
Mads
-- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking.
peteg
2259 posts in 988 days
#9 posted 470 days ago
Great post Jim, : ))
Pete
Jim Jakosh
7238 posts in 1271 days
#10 posted 443 days ago
Thanks for the nice comments. Glad you all enjoyed it.
Mads, you gave me an idea when you mentioned the reflector. The next one will have a round mirror in it!
Thanks,Jim
