Obelisks #1: Cutting Process
Blog entry by Jim Jakosh posted 12-11-2011 10:06 PM 5001 reads 9 times favorited 10 comments Add to Favorites Watch
no previous part Part 1 of Obelisks series Part 2: Making an obelisk incense burner »
Obelisks are fun and easy to make and great use of wood from a project that would otherwise be discarded. I made a few and have had some LJ’s ask how I do it, so I thought I’ll take a few pictures and save a few thousand words. I start with a rectangular block with a square base. I find the center on one end and draw line from that center to the corners at the other end.
I bandsaw down the lines being careful to always stay outside the line. It is better for finish sanding than an undercut condition. You have to take off too much material on all sides then.
On one of the cut sides, I do the same layout from the center to the points of the opposite end.. I use a piece of scrap from the first cut to support the piece in the bandsaw so the base is perpendicular to the table and the cuts will be centered.
This gives a pointed obelisk that I sand on a belt sander to remove all the saw marks. Sometimes I bore a hole in one of the sides and insert a photo disc and I have plans for putting a candle inside the next one.
They are just fun to look at to show the beauty of the wood.
Enjoy!
10 comments so far
View degoose's profile
degoose
7227 posts in 3229 days
#1 posted 12-11-2011 10:19 PM
Great tutorial and great bit of spalted….
View jumbojack's profile
jumbojack
1673 posts in 2498 days
#2 posted 12-12-2011 12:17 AM
Unique use of spectacular wood. It almost looks like a map. If you have more you could turn it, if the spalting isn’t too punky. It would look like a world globe.
View sedcokid's profile
sedcokid
2729 posts in 3473 days
#3 posted 12-12-2011 04:42 AM
Jim,
This a very good tutorial, the wood is gorgeous and the project is a good one.
Thanks for sharing
-- Chuck Emery, Michigan,
View Bob Collins's profile
Bob Collins
2484 posts in 3558 days
#4 posted 12-12-2011 01:07 PM
Thanks Jim, easy to follow, will try putting a clock in one, I have some clocks about the same size as the photo frames you use.
-- Bob C, Australia. Your best teacher is your last mistake.
View Sodabowski's profile
Sodabowski
2370 posts in 2707 days
#5 posted 12-13-2011 01:08 AM
Indeed a good way to show off a piece of wood for its inner beauty, definately going to do that too.
By the way, you can still use the leftover bits from this one to make small buttons for drawers.
I made a bunch of blanks for drawer buttons with small leftover parts from a Rhus rootball last summer.
-- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes...
Sodabowski
#6 posted 12-13-2011 01:20 AM
(oopsie, posted twice!)
116813 posts in 3451 days
#7 posted 12-13-2011 01:37 AM
I get your point :)) thanks for the info.
View Dan'um Style's profile
Dan'um Style
14171 posts in 3857 days
#8 posted 12-16-2011 01:43 AM
very well done Bud! enjoyed reading about the and no doubt make one for myself soon.
Regards
DAN
View ugoboy's profile
ugoboy
104 posts in 2908 days
#9 posted 05-05-2012 01:46 PM
Thanks for the detail and pictures. Is there a particular angle that is best suited for this shape?
-- ~ Guy Woodward, Pflugerville Texas
View Jim Jakosh's profile
Jim Jakosh
19966 posts in 2980 days
#10 posted 05-06-2012 03:47 AM
Hi Guy. I don’t think there is anything specified anywhere. I just like the look of a slim angle but I find it comes out to whatever the piece of wood will yield. it is best to start with a square piece so the sideslook the same from all directiions.
................Jim
