Unorthodox Bandsaw Box #1: Box making steps
Blog entry by Jim Jakosh posted 12-11-2011 09:42 PM 9519 reads 38 times favorited 28 comments Add to Favorites Watch
no previous part Part 1 of Unorthodox Bandsaw Box series no next part
My wife asked me when I was going to make her a box to keep our business cards in when we travel. I had made a few boxes but never one upon request- especially from her. So I wanted this to be special. I went about making a bandsaw box in an unconventional way and I was having a problem with the hinge design. One night I had a dream of how to do it and wrote it down right away in the morning. Here are the steps I used to make the box using mainly the bandsaw and the scroll saw for one tough part.
I forgot to mention one thing. If you can’t see the complete picture- right mouse on it and click view image.
I had these two very figured pieces of spalted beech on my bench and had planned to make bandsaw boxes one day. Here is what I started with:
I cut it to make an interior of 2 1/4×2 1/4×3 5/8 with 5/8” on top, front and both sides and 1/4” bottom and 5/16” back.
Then I cut off the top and bottom:
Then I cut out the inside by making straight cuts to remove the back and mitered cuts to remove the front.This was so there was no seam showing on the front when I put it back together. I saved the inside block for another project:
I drilled the back for the hinge pins before I cut it apart:
Then I had to use the scroll saw to create the hidden integral hinge:
The scroll saw was the thinnest blade I had but it did leave a space that I had to shim with some .017” washers to remove any side play for the lid.I punched out two of them using some aluminum flashing materila and cut two 1/8” steel pins for the hinges:
With a little sanding for clearance, the hinge works:
the back, front and sides were then glued together with a block to hold the back parts straight. I sanded the inside of these parts except in the area where I cut them apart. They mated great there.
The top and bottom were glued on and I did a final cut on the jointer and miter saw to make sure the assembly was square.
I don’t have any more pictures of the next operations, but I next cut the top loose along the hinge line all the way around and began shaping the block by cutting a radius on the top, then the front and then the sides and I blended all the surface together on the belt sander and orbital sander.
I had this rectangular block left from the center and it was so pretty, I made an obelisk out of it and will post a short blog on how I do them next.
l
28 comments so far
View SPalm's profile
SPalm
5320 posts in 3932 days
#1 posted 12-11-2011 10:28 PM
Very very nice job.
Wonderful wood too.
Steve
-- -- I'm no rocket surgeon
View degoose's profile
degoose
7237 posts in 3405 days
#2 posted 12-11-2011 10:32 PM
Sneaky… this will have to wait till I have a scrollsaw…
View omextreme's profile
omextreme
49 posts in 2427 days
#3 posted 12-11-2011 10:50 PM
As soon as I can unpack the new bandsaw I will have to try this!
View rance's profile
rance
4259 posts in 3210 days
#4 posted 12-11-2011 11:59 PM
Yeah, never waste any wood. Especially any Rotten wood that looks like THAT! That is one very very nice box there Jim. The technique almost reminds me of an Andy box. Thanks for sharing.
Edit: Oh, you say you “cut the top loose along the hinge line all the way around”. With what saw? I’m guessing a very thin Japanese pull saw.
View RussInMichigan's profile
RussInMichigan
600 posts in 2830 days
#5 posted 12-12-2011 01:29 AM
Good job, Jim.
View robert triplett's profile
robert triplett
1566 posts in 3155 days
#6 posted 12-12-2011 02:19 AM
Nicely done Jim. You have reminded me that I bought a slab of
spalted maple in Oregon this summer. That would be a good use for a bit of it. Thanks for the details of your build.
-- Robert, so much inspiration here, and now time to work!!!
24031 posts in 3901 days
#7 posted 12-12-2011 02:30 AM
Well done Jim. Thanks for showing.
View SASmith               's profile
SASmith
1850 posts in 3037 days
#8 posted 12-12-2011 02:57 AM
Unique process.
Love the end result.
Thanks for sharing the way.
-- Scott Smith, Southern Illinois
View DamnYankee's profile
DamnYankee
3301 posts in 2612 days
#9 posted 12-12-2011 03:05 AM
Very cool looking box!
-- Shameless - Winner of two Stumpy Nubs Awards
View gfadvm's profile
gfadvm
14940 posts in 2740 days
#10 posted 12-12-2011 04:42 AM
I love the way you hinged it. I’m going to steal this idea. I think this hinge will work great for a bigger box and it looks like it will stop just past vertical?
View sedcokid's profile
sedcokid
2733 posts in 3648 days
#11 posted 12-12-2011 04:57 AM
nicely done Jim!!
Thanks for sharing
-- Chuck Emery, Michigan,
View bobasaurus's profile
bobasaurus
3497 posts in 3234 days
#12 posted 12-12-2011 05:53 AM
You must be a wizard, with your box making powers. I want to try this now. Are the miters also cut on the band saw? Also, did you use the band saw to cut free the top after the glueup, or some thinner-kerf scroll saw, etc?
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View Bob Collins's profile
Bob Collins
2522 posts in 3734 days
#13 posted 12-12-2011 01:13 PM
Great JIm, easy to follow and a must do project for next year.
-- Bob C, Australia. Your best teacher is your last mistake.
View Sodabowski's profile
Sodabowski
2374 posts in 2883 days
#14 posted 12-13-2011 01:04 AM
From now on, we will all refer to that style of integral hinge as a ”Jim hinge”.
Really good idea and a perfectly well planned box.
Thanks so much for sharing the process! :)
-- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes...
View Roger's profile
Roger
20929 posts in 2854 days
#15 posted 12-13-2011 01:53 AM
sweet! nice tutorial Jim
showing 1 through 15 of 28 comments
