Technique for installing solid edging on a top
Blog entry by Jim Jakosh posted 10-21-2011 03:50 PM 3190 reads 1 time favorited 12 comments Add to Favorites Watch
When I put a picture frame together with 4 mitered corners I use a clamping fixture with 4 v-blocks and a draw bolt in the center. But when I put hardwood trim on the outer edges of a top it is always a challenge getting them all to stay together to clamp up properly. I cannot use the frame fixture because there is no space in the center. I used to air nail the pieces on but then that left holes to fill.
So I tried this and it worked pretty good so I thought I’d share it with everyone.
I make sure the center part is square and put it face down on the bench and then cut all the trim pieces to fit precisely without gaps.
Then I glue the perimeter of the center piece and the mitered surfaces of the edge trim. I place the pieces against center section and put one clamp to keep them from moving while I contain all the trim with a double bungee cord.
I let it sit for a bit and then flip it over so I can see how flush the trim is to the surface and add clamps in all the critical areas until the glue is dry.
After is is dry, I just sand the top to make sure the center and trims are flush before finish routing the edges.
There are probably a lot of ways to do this but I found this saved me a lot of grief over the old way I used to do it. The bulk bungee cord I bought at a flea market for another project and it really worked out good because it maintained pressure on all 4 corners. I usually dry fit it with the bungee cord on it to make sure the miters are all correct. They are a lot easier to recut without glue on them!!
.........................Jim
12 comments so far
View Cher's profile (online now)
Cher
954 posts in 2995 days
#1 posted 10-21-2011 04:58 PM
Hi Jim, I have wondered if this type of method could work.
Thanks for sharing this hand hint Jim
View jack1's profile
jack1
2099 posts in 3928 days
#2 posted 10-21-2011 06:39 PM
Cool method. I’ll try it sometime. THanks
View Gary's profile
Gary
9289 posts in 3334 days
#3 posted 10-21-2011 06:41 PM
Jim, Veritas makes a “4 way speed clamp” that does what you are doing. Much easier. I use them for most all of my miter cut clamping
http://www.leevalley.com/US/wood/page.aspx?p=31162&cat=1,43838
Check it out
View Jim Jakosh's profile
Jim Jakosh
20060 posts in 3007 days
#4 posted 10-21-2011 07:43 PM
Thanks, Gary. Those are some slick clamps.I think I’ll just order a couple sets of the quick nuts for $10 a set and make two pair of them. Those nuts may have other uses in the shop. Thanks for the tip!!!.......Jim
Clamp & Extension Set
05F01.20 Instruction sheet $36.50
A. 4-Way Speed Clamp 05F01.01 Additional views Technical Information $29.95
B. Extension Set 05F01.02 $9.40
Extra Speed Nuts, set of 4
05F01.03 $9.95
View Gary's profile
Gary
#5 posted 10-21-2011 08:55 PM
I thought about doing the same but, I’m so slow. I think I’m the vice president of the “Procrastinators Club of America”. Not too sure cause I haven’t opened the letter yet.
View Earlextech's profile
Earlextech
1160 posts in 2592 days
#6 posted 10-21-2011 10:37 PM
Masking tape has worked for me for over 25 years!
Jim Jakosh
#7 posted 10-21-2011 11:46 PM
Hi Sam. I figured there are lot of other methods. Do you use clamps after taping the trims together?
View sedcokid's profile
sedcokid
2729 posts in 3500 days
#8 posted 10-22-2011 04:31 AM
What a cool technique will try it on my next frame.
Thanks for sharing
-- Chuck Emery, Michigan,
View mafe's profile
mafe
11631 posts in 2990 days
#9 posted 10-22-2011 12:55 PM
Clever Jim,
I will add some bungee to my clamp rack.
Best thoughts,
Mads
23531 posts in 3752 days
#10 posted 10-23-2011 03:31 AM
Good thinking Jim. Ratchet straps work well also.
View Drew - Rock-n H Woodshop's profile
644 posts in 2592 days
#11 posted 11-22-2011 07:47 PM
Hey Jim, that is a great method to use for trim. I will have to add that to my arsenal.
One thing I thought I should mention is to be careful glueing your end grain with you edge piece. When you have two different grains going in two different directions and you lock them in place with glue, you will experience splitting and your miters will come apart. However with plywood it will not matter. Hard to tell on your pic if you are using ply. One thing I have done is glue the miter and not the edge of the end grain plus add a spline in the miters to hold them together, plus it adds a nice touch to each joint.
-- Drew -- "I cut it twice and it's still too short!"- Rock-n H Woodshop - Moore, OK
Jim Jakosh
#12 posted 11-22-2011 10:54 PM
Hi Drew. I have made a ton of tables this way- gluing the corers with the side solid pieces and have not had one split or come apart in any way. I usually use plywood for the center, but in this case I scrapped the plywood and used solid wood. This was cabinet grade plywood that I had left over from a job I finished and the customer bought the wood at the Home Despot. It had such a thin outer ply that I could have sanded through it before I knew it. Time will tell on these if the expansion of the sold does break the corner. I’ll keep an eye on them during seasonal changes. I have not done any spline joints yet but have been thinking about….............Jim
