Coloring Bondo Black
Blog entry by Jim Jakosh posted 08-25-2011 03:18 AM 19832 reads 0 times favorited 14 comments Add to Favorites Watch
Does anyone know of a colorant to color Bondo ( body filler) black? I can only find blue and red hardener and the best I can do is a gray color. I want to color it black to fill some large voids in a piece of mesquite for a lamp base. I don’t want to use Epoxy because it would take a tub full. It is a polyester resin so I don’t thing black oil based paint would mix well with it. Any suggestions?..............Thanks ,Jim
14 comments so far
View cutmantom's profile
cutmantom
405 posts in 3091 days
#1 posted 08-25-2011 03:40 AM
epoxy is the only thing that ive seen for this done on the NYW, you could try charcoal powder but i think it could interfere with the bonding, wouldn’t hurt to experiment though on scrap
View rance's profile
rance
4259 posts in 3217 days
#2 posted 08-25-2011 04:02 AM
Black Laser printer toner? Wear a mask though, and DON’T SNEEZE. It also comes in a sorta yellow, blue, and magenta.
View Rob_n_Wood's profile
Rob_n_Wood
109 posts in 3405 days
#3 posted 08-25-2011 04:12 AM
I would try a product called lamp black that is a pigment dye for paints I was able to buy a pint of it years ago
when I did stained glass and used it in my putty to darken it. I have used it in a variety of different things
epoxy, putty, I think that I even used it in bondo come to think of it
-- "I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them." Thomas Jefferson
View ptweedy's profile
ptweedy
75 posts in 3450 days
#4 posted 08-25-2011 04:16 AM
Go down to woodcraft and get a small bottle of transfast black water soluble dye. It should wook like a champ. phil
View HalDougherty's profile
HalDougherty
1820 posts in 3293 days
#5 posted 08-25-2011 04:44 AM
I’d try Ritt Dye. You can get a 4oz package at the grocery store for about $2 a package. When I use it to dye wood, I mix the powder in denatured alcohol and then filter it through a coffee filter to remove the solids that didn’t go in solution. I’ve got several bottles of Trans-Tint from Woodcraft, but I can’t tell which glass jar of brown liquid is TransTint and which is Ritt dye after a few days. They both look the same. Try mixing the powder with the bondo before you add the hardner. You are only out $2 if it doesn’t make the dark black color you need.
-- Hal, Tennessee http://www.first285.com
View tyskkvinna's profile
tyskkvinna
1310 posts in 3042 days
#6 posted 08-25-2011 05:19 AM
I also came in here to say printer toner. I’ve done that before with wild success.
I imagine Rit Dye would work great, too..! I’ve dyed wood putty with it before and it came out pretty true to the colour.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
HalDougherty
#7 posted 08-25-2011 12:21 PM
Jim,
Don’t color the bondo… When you pack it into the voids, leave about 1/4” to the wood surface and after the bondo has hardened, fill the space that’s left with black epoxy.
View SgtSnafu's profile
SgtSnafu
960 posts in 3328 days
#8 posted 08-25-2011 03:32 PM
I see many good answers here, but ran across this which may help too..
Link
-- Scotty - aka... SgtSnafu - Randleman NC
View Jim Jakosh's profile
Jim Jakosh
20781 posts in 3162 days
#9 posted 08-25-2011 03:32 PM
Thank you for all the excellent leads. I think I’ll get the RIT dye first and let you all know if it worked out. I have lots of Bondo from car repair jobs. I did have some lamp black years ago when I built a brick fireplace and used it to color the mortar black. It worked great for that, but I could not find it. It was very messy like the Iron Oxide sounds.. Thank you all for the help. I’ll report back soon!..............Jim
View Joe Weaver's profile
Joe Weaver
517 posts in 3743 days
#10 posted 08-25-2011 03:52 PM
How about clear epoxy with sawdust. You might have some sawdust from the wood you are working with.
-- Joe, Ga
View Woodbutcher3's profile
Woodbutcher3
416 posts in 2943 days
#11 posted 08-28-2011 02:15 PM
I came to make a suggestion or two, but thet were already here. What a fantastic forum when people bring all their hints and techniques at a moments notice to help a fellow woodworker. All y’all are great. Thanks for being members and thanks for sharing! Ya make me proud to be part of this group.
Chips a’ flyin’
-- Rod ~ There's never enough time to finish a project, but there's always time to start another one.
Jim Jakosh
#12 posted 07-15-2012 01:44 AM
well. I have been looking at that big slab of mesquite and that Rit dye box too long. I mixed up a batch of body filler and put the black Rit dye in it. Not Good! It did not change the blue color of the filler at all. Instead it dried like sand particles in it. I should have tried it on a scrap piece. Now I have this lamp base with all this blue filler in it. I wish it would have been a shade of turquoise. that wold look okay with the mesquite. Oh, well, that is not a priority project. I’ll keep looking for some black hardener! I think it will actually take a liquid colorant.
...............Jim
Jim Jakosh
#13 posted 07-15-2012 01:49 AM
Scotty, I just sent a note to Marson asking if they had a colorant for their body filler…........thanks, Jim
Jim Jakosh
#14 posted 10-02-2013 12:36 PM
I found the colorant. It is Testers model paint! It works great for epoxy and Bondo because it is oil based not water soluble like Rit dye. it dries at the same rate as Bondo or epoxy too!
Someone told me to try this at one of our guild meetings when we were kicking the subject around!!
Thanks for all you input!!..............Jim
