So I got the Mast-R-Lift in place and did some tweaking of the leveler screws to get it flush with the top.
Next I needed to think about the fence. I know that I will be able to use my TS fence, but I have this Rockler fence floating around from my old drill press table. As far as I can tell, this is the same as their router table fence just a little smaller. I think it will work fine for my purposes and I can always modify it later if need be. Here I routed the channel for the T bolts that mount the fence.
Normally I would rout a larger channel on the bottom to not allow the T bolt to turn. But once I laid out the lines I realized that it is close enough to the edge so that the side piece will trap the T bolts. This was great and allowed me to just rout one channel in a few passes and I was set to go.
Finally, I attached the dust collection to the fence from the drill press set up. I mounted the router and made a few test cuts and I think this fence will serve my needs very well. This is a major step up from my old table as I had one of those Router Workshop set ups.
I have drawn up some preliminary plans for a “cabinet” of sorts that will allow me minimal bit storage but mostly it will enclose my router and allow for some dust collection. I will probably build in some angle supports for extra support so that there is not so much weight on the TS rails.
-- The Hand Tool School is Open for Business! Check out my blog and podcast "The Renaissance Woodworker" at www.renaissancewoodworker.com
3 comments so far
teenagewoodworker
home | projects | blog
2727 posts in 1933 days
#1 posted 1802 days ago
looking good. i think that some storage underneath would be a good idea. even just enough for some gear, bits and table saw inserts and the like should be good enough. thanks for the post.
Grant Davis
594 posts in 2073 days
#2 posted 1801 days ago
Very nice addition. How do you like the Rockler adjustable plate?
-- Grant...."GO BUCKEYES"
GaryK
10263 posts in 2153 days
#3 posted 1800 days ago
I had an older Mast-R-Lift with a belt. I got rid of it because the belt skipped teeth.
Nice job on the table.
