Alrighty then! The Cross inlay is done! My theory on flipping the template to cut the inlay piece worked.
Here are the photos of the process….
With the template clamped in place, I cut the female part of the inlay with a Delta Inlay kit. I cut the outside of the area with the 1/8 inch bit in the kit and used a 3/8 inch bit with a 1 inch bushing to finish cutting the waste. I did cut the outside deeper. I did this to make sure the inlay would lay flat in the space.
I did flip the template and cut the inlay using the 1/8 inch bit. I did make the cut in three passes. Making sure when I cut the corners in the middle that I slowed the feed rate and held the bushing tight again the template. It worked and I was able to cut the inlay in one attempt.
Here are the pieces laid out ready to fit. I did have to lightly sand the edges of the inlay pieces, round the corners, and bevel the bottom of the inlay pieces so they would fit easier in the space in the table.
And a close up of the pieces.
I dry fit the pieces to make sure of the fit and then used the holes I drilled in the space and a dowel to gently persuade the inlay out of the space.
I used yellow glue to glue the inlay in the table but I used Gorilla Glue on the miters in the center of the cross. I just applied the Gorilla Glue to the joining edges and NOT to the bottom of the inlay piece because I was afraid that the GG would expand and push the inlay out of the table.
Here is a close up of the center of the cross. Hope you can see the mitered intersection. I think this came out very well.
After using a No. 4 smoothing plane and random-orbital sander, the cross inlay is flush to the table top and the walnut is beautiful. I was very careful to make sure the grainlines in the inlay matched up. Thanks for reading my blog. Now, it’s time sand and sand again before using paste wood filler to fill the open grain, staining and top coating.
Here’s the completed inlay.
-- Makin' Sawdust!!!
5 comments so far
trifern
home | projects | blog
7897 posts in 667 days
posted 430 days ago
Looking good, thanks for the update.
DAN
6468 posts in 883 days
posted 430 days ago
nice work. looking forward to finished piece of work
Grant Davis
481 posts in 808 days
posted 429 days ago
Very nice work.
-- Grant...."GO BUCKEYES"
Chris Davis
558 posts in 882 days
posted 429 days ago
Man, that is great. Thanks for the info. I don’t do much inlay, but that make me what to try it out. Good post and great work.
-- Watch live video from our shop. http://wwbeds.com/live.htm
Dick, & Barb Cain
7050 posts in 1199 days
posted 429 days ago
Thank you for sharing this beautiful project, great craftsmanship.
