Easy Wood Tools / Midi Lathe Duplicator #3: Final Testing and Some Adjustments
Blog entry by Sawdustonmyshoulder posted 02-20-2015 01:29 AM 6124 reads 3 times favorited 0 comments Add to Favorites Watch
« Part 2: Turned the Finials. Part 3 of Easy Wood Tools / Midi Lathe Duplicator series no next part
I found in my testing that I need to offset the EWT Finisher from the blank about 1/16 inch. I made a new ‘follower’ using a 1/2 inch washer. This washer offset the cutter all the way around.
Using the EWT Detailer that is set to cut equal to the pattern, I make the final pass on the finial.
Here are some images of the testing on a finial project.
Check out my blog on a great finishing helper using a DVD container.
I also have a project with a step by step of the turning process.
-- The more skilled you are at something, the worse you are at it when someone is watching.
0 comments so far
