The PC 4216 came in last week. I was able to open it up yesterday and get started.
Looks like everything is here. Seems to be very well made…. like all of my PC equipment.
In about 20 minutes, I had it ready to make my first joint. I decided to attempt a half blind dovetail joint. This unit as an adjustable side stop and this allows you to get that classic half pin on each end of the joint on any size drawer side.
Well, the first attempt was way too tight… in fact, I could not get the joint to join. The second attempt was too loose. I was closing in on the fit. (if you didn’t know, to adjust a half-blind dovetail joint you move the bit up and down) The third and forth attempt was dealing with the depth of the pieces.
So the fifth attempt, BINGO! The joint is really tight and perfectly centered with half pins on each end. I was testing with finger-jointed pine and it cupped a little but I think with a little glue and clamp pressure, it would join up nicely. The jig has a depth stop integrated into the template and once you dial in that perfect fit, it is very easy to repeat.
Next I tried the through dovetail. I set up the jig just as described in the manual. My first attempt turned out perfect. I set the bit just a small amount lower than the thickness of the wood so that I would get a joint with tails and pins extending out of the joint. I would plane or sand this excess wood to make a flush joint.
I am really impressed with this dovetail jig!! I would highly recommend it for anyone wanting to make dovetail joints. (and who among us doesn’t?)
I found on Porter Cable’s website a Supplemental Manual that has some very interesting way to use this jig to make advanced joints. Here is the link: Supplemental Manual for PC 4200
I hope to try out some of these advanced joints, but first, kitchen drawers for the wife’s new kitchen.
-- Makin' Sawdust!!!
5 comments so far
Randy Sharp
home | projects | blog
318 posts in 1842 days
#1 posted 289 days ago
Nice review there, Marty Boy! Try out the plans for the jig station and storage unit. You’ll like it!
-- Randy, Tupelo, MS ~ A man who honors his wife will have children who honor their father.
bearcat
10 posts in 309 days
#2 posted 289 days ago
Great review. Does this jig require a special PC router bit?
-- Abhijeet -- Auburn,AL
Sawdustonmyshoulder
232 posts in 1798 days
#3 posted 289 days ago
It came with PC bits. They are great bits. The straight bit is something like 13/32”. I haven’t seen one of these before.
NiteWalker
1473 posts in 746 days
#4 posted 289 days ago
Nice job!
I grabbed the advanced manual too; some interesting things in there.
Whiteside makes replacement bits for the jig;
Dovetail Bit
Straight Bit
Also, you can use a different dovetail bit, sold by rockler, for deeper 14 degree half blind dt’s. It was outlined in a couple of threads not too long ago.
Thread 1
Thread 2
Brady Garrett
8 posts in 455 days
#5 posted 287 days ago
Great presentation tonight Marty. I enjoyed seeing your jigs and learning how they work. It’s nice to meet another local Lumberjock.
-- Brady Garrett, Mississippi
