Loose Tenon Mortising Jig #2: SketchUp Model Drawn
Blog entry by Sawdustonmyshoulder posted 01-24-2011 05:41 AM 8805 reads 12 times favorited 13 comments Add to Favorites Watch
« Part 1: Video Part 2 of Loose Tenon Mortising Jig series no next part
Well, I finally have the SketchUp drawing started. I still have to put dimensions on the drawings and will need to write the instructions. Just wanted to whet your appetite.
Here are a couple of views of the 3D drawing:
-- The more skilled you are at something, the worse you are at it when someone is watching.
13 comments so far
View PurpLev's profile
PurpLev
8539 posts in 3705 days
#1 posted 01-24-2011 05:43 AM
looks versatile and convenient at first look. nicely done!
View tdv's profile
tdv
1188 posts in 3127 days
#2 posted 01-25-2011 02:00 AM
Neat, wish I could get to grips with sketchup. There’s a lot to learn on it & all the demo’s I’ve watched move too fast for me. I just wish computers were made of wood then I’d understand ‘em better
Thanks for the drawing though I’ve had some requests for info on my version so I pointed our friends to yours It will help a lot of Jocks to build their own jig
-- God created wood that we may create. Trevor East Yorkshire UK
View rogerw's profile
rogerw
262 posts in 2746 days
#3 posted 01-26-2011 05:31 PM
Very nice. I am patiently waiting for the dimensions.
I do have a question, however. I watched the videos you posted setting up and using the jig. You are a good teacher. Why is the miter slot rail not just screwed down to the cutting board? I am not seeing an obvious reason of having knobs to make what it appears adjustable. Am I missing something?
I do like the idea of using a plastic cutting board. That one took me by surprise. Never thought of that one!
Roger
-- >> my shop teacher used to say "do the best at everything you make for your mom because you're going to see it for the rest of your life!" <<
View tdv's profile
tdv
#4 posted 01-27-2011 02:35 AM
Roger you need the mitre slot rail to be adjustable so the the position of the router plate(cutting board) can be adjusted to accomodate different mortice positions in different thicknesses of timber. That is why the hold down at the back is also adjustable by the same amount to make sure it is always over lapping the router plate(cutting board)
Cheers
Trevor
View Sawdustonmyshoulder's profile
Sawdustonmyshoulder
475 posts in 3685 days
#5 posted 01-27-2011 03:51 AM
rogerw,
Thanks for the kudos on the video. I really had a good time making it. Did you catch the train horn at the end of video 3? By the time is got to the end, I was tired and ready to edit.
tdv, is right. the adjustments on the router plate allows you to vary the position of the bit on the stock.
Also, the stops are positioned on the rail. The rail is a double rail. Miter slot in the from and a t-track in the back.
I got a start on the dimensions last night and should have them ready soon.
rogerw
#6 posted 01-27-2011 07:51 AM
sawdust- yes i did catch that train horn in the background :-) and thanx for answering that Q. u2 trevor
i guess that will make more sense once i got one in front of me. (still a little foggy)
roger
View tdv's profile
tdv
#7 posted 01-27-2011 11:33 AM
With the stops I had a few offcuts of Kreg tee track so I mounted them toward the front of the jig & since I posted I have inlaid a strip into the front hold down bar to take the Kreg hold down clamps. Every time I use this jig I say thanks to Sawdust it’s a real pleasure to use.
Trevor
View CAHillard's profile
CAHillard
3 posts in 2926 days
#8 posted 02-08-2011 07:58 PM
After watching your videos several times, and searching online for other variations of this jig… I await with the others for your measurements to be able to nearly duplicate this jig… it is the best that I have seen for it’s purpose – and I see no reason to totally re-invent the wheel here. thanks
View mcgriffith's profile
mcgriffith
87 posts in 2454 days
#9 posted 11-22-2011 08:26 PM
I am quite impressed. I will be making something like this. I would like to be able to cut the tennon part as part of the rail, but will have to experiment with that when I get to that point. So far I am just getting ready to build a new workbench. Actually, I am aware it would be helpful to have this jig to work on that too. So many ideas and projects just to do projects.
Thanks.
-- Michael TX, Not even my wife understands my sense of humor.
View Max's profile
Max
1 post in 2387 days
#10 posted 01-09-2012 03:53 AM
I have build a prototype of your jig just using the video as a guide. I love it’s promise. I had one question, now I see this on Lumber jocks I have more.
Where are the dimensions? It’s been some time since your last post on it. Is that you that suffered from the storm? If so, I understand why they haven’t been posted yet. How did you get that oak support/clamp to stay in place when you loosen it?
If you have any plans or new info on this jig I would really appreciate you sharing it.
Thanks,
MaxD
-- MaxD_NY
View pmbard's profile
pmbard
2 posts in 2865 days
#11 posted 01-30-2012 07:37 AM
Is it possible to download this plan? Thanks.
View Jim Crockett (USN Retired)'s profile
852 posts in 3790 days
#12 posted 06-05-2012 01:24 AM
I, also, would very much like to see the drawings with dimensions. After watching the videos, I’d really like to make this jig. You have a very nice design here, I think, that would be very useful.
-- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life".
View iminmyshop's profile
iminmyshop
284 posts in 2051 days
#13 posted 09-02-2017 12:48 PM
Hi. Thanks a ton for your posts. Did you ever post the final Sketchup drawings of the loose tenon jig?
-- http://www.alansfinewoodworking.com/
