Loose Tenon Mortising Jig #1: Video
Blog entry by Sawdustonmyshoulder posted 03-15-2010 02:51 AM 11968 reads 35 times favorited 19 comments Add to Favorites Watch
no previous part Part 1 of Loose Tenon Mortising Jig series Part 2: SketchUp Model Drawn »
This is a video on how to set up and use the Loose Tenon and Mortise Jig I developed over the past few weeks.
It is in three pieces.
Part One
Part Two
Part Three
I made two project entries: First One - pre-tested and the Second One - post-tested
-- The more skilled you are at something, the worse you are at it when someone is watching.
19 comments so far
View rbterhune's profile
rbterhune
176 posts in 3275 days
#1 posted 03-15-2010 03:44 AM
Great stuff, great jig. I’d like to make a jig similar to that at some point. I’d love to see some more detail about the jig itself.
rbterhune
#2 posted 03-15-2010 03:44 AM
Never mind…missed the project posts
View dannymac's profile
dannymac
144 posts in 3069 days
#3 posted 03-15-2010 05:43 AM
the only thing i could say is THANK YOU
-- dannymac
View loupitou06's profile
loupitou06
137 posts in 3379 days
#4 posted 03-15-2010 06:11 AM
Excellent Jig and great videos, thanks a lot
Pierre
-- 100 fois sur le metier remettez votre ouvrage
View Viking's profile
Viking
880 posts in 3249 days
#5 posted 03-15-2010 06:32 AM
Thanks for the lesson. I learn something from LJ every day!
Excellent!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View Randy Sharp's profile
Randy Sharp
363 posts in 3726 days
#6 posted 03-15-2010 06:50 PM
Inserting the photos for a close-up view on certain parts of the set-up was an exceptional and helpful addition. Great videos!
-- Randy, Tupelo, MS ~ A man who honors his wife will have children who honor their father.
View TNwoodchuck's profile
TNwoodchuck
102 posts in 3829 days
#7 posted 03-15-2010 07:22 PM
Your fixture, your photos, and your videos are top notch. I think I can duplicate from what you have shared already, but I’ll check back for your plans too. Thanks for taking the time to share your obvious expertise. I might add that your voice and very slight accent make you easy to listen to.
-- Chuck near Nashville - “All you are unable to give possesses you” (Andre Gide)
Viking
#8 posted 03-15-2010 11:47 PM
Do you make you own tenons or is there a ready source for them? I have several projects that would most likely use 3/8” and 1/2” and possibly 1/4” tenons.
I am also anxious to see your plans.
Thanks
View Sawdustonmyshoulder's profile
Sawdustonmyshoulder
475 posts in 3682 days
#9 posted 03-16-2010 02:05 AM
Viking, I make my own tenon stock out of what some call scrap and some call unassigned wood laying around the shop. It helps that I have a drum sander that sands in 1/128th of inch passes so that I can dial it just at the right fit. I round the corners with either a quarter round router bit or a appropriate sized bullnose router bit in my router table.
If I didn’t have the drum sander, I guess I could use the table saw to cut the tenons close and use sandpaper to fine tune the fit. I find that you don’t want the tenons too tight because the glue will swell the walls of the mortise and also the tenon. I am also going to add a saw kerf to the tenons to allow air to escape the mortise and not blow the glue out.
This ability to make your own tenon is really a great feature of loose tenon joinery because you don’t have to spend money on tenon stock or use expensive project wood to make tenons. Over the life of a project like I am working on now with almost 450 tenons at about 1 1/2 inch in stock length per traditional tenon equals about 25 board feet of lumber. And all of the tenons will be made from the stock that is cut off and headed to the trash.
I have some work to do on the chairs tonight but I will start on the SketchUp plans later in the week. I don’t work in the shop on Wednesdays (that’s the wife’s night with me) so I will do some “inside work” on the plans.
Thanks all for the kind comments!
View david9951's profile
david9951
39 posts in 3214 days
#10 posted 03-17-2010 03:56 AM
viking, lee valley sells loose tenon stock
View Skylark53's profile
Skylark53
2671 posts in 3114 days
#11 posted 03-17-2010 06:53 AM
Great job on the jig and the video. Thanks for sharing.
-- Rick, Tennessee, John 3:16
Viking
#12 posted 03-17-2010 12:55 PM
Sawdust / David;
Thanks for the info on tenon stock. Will probably buy some to get started then make my own from the scrap pile.
Good Luck!
View bgee's profile
bgee
1 post in 3868 days
#13 posted 03-18-2010 03:28 AM
Great video and nice jig
-- Bgee from Dublin, Ohio
View woody57's profile
woody57
650 posts in 3481 days
#14 posted 03-22-2010 03:49 AM
that’s a great jig
thanks for posting
-- Emmett, from Georgia
TopamaxSurvivor
18311 posts in 3729 days
#15 posted 01-14-2011 09:11 AM
nice video, great explanation, thanks.
