I found some more time to work on the bench. I glued up the base stretchers. I used the draw pin mortise technique where the dowel pin holes through the mortises were slightly forward of the holes through the mortises. When I tapped the dowels through, they pulled the stretchers tight against the posts. One of the nicest things about this is no clamps while the glue is drying.
I was working alone on the top, so I was unable to do the “glue up three and send a batch through the planer technique”. I just kept gluing one 4×4 to the next, waiting a half hour, and continuing. The only way to smooth it at the end was with a hand plane. It went way better than expected, probably because the plane arrived pre-sharpened.
I was just playing around with the face boards and clicked a pic. That is maple for the front and walnut for the end cap. I believe they will be trimmed to about 5 inches in width.
Making a mess using a router for the tongue for the end cap. Clamped a straight edge and routed from the top, flipped it over and repeated for the bottom side.
The new top after some clean up.
Take care,
Steve
15 comments so far
dalec
home | projects | blog
581 posts in 780 days
posted 544 days ago
A very sturdy and attractive work bench.
How did you attach the top to the cross piece at the two ends of the table?
Dalec
20546 posts in 714 days
posted 544 days ago
This is one hefty looking bench. But it is looking pretty good so far.
Woodhacker
1145 posts in 615 days
posted 544 days ago
You’re making good progress Steve. I had to go back and look at Part 1.
It looks great. Seeing all these great benches on this site makes me want to try one.
-- Martin, Kansas
mikeH
75 posts in 1183 days
posted 544 days ago
Beautiful top, i really like the wood. so planning the top was not to hard to do, i am planning on making one some day and leveling the top was one of my concerns
-- mjhaines
25794 posts in 1292 days
posted 544 days ago
Good looking Steve. It starting to look like a bench now.
Betsy
2388 posts in 788 days
posted 544 days ago
Looks great Steve. I’m interested to know the offset on the draw bore. On a small project I’m working on I’m using a 1/16th” but something this large, what would you use?
Todd A. Clippinger
5632 posts in 991 days
posted 544 days ago
I gotta say that is a nice looking bench you’re building!
bobdurnell
197 posts in 789 days
posted 544 days ago
Nice bench, I couldn’t help noticing but is your top vertical grain douglas fir? If so, I used it once on my bench. Was a lovely top, come to think of it my bench base is vg douglas fir also. Made it when I was 14 years old to young to drive so my mother drove me to the lumber yard and I picked out the wood I wanted. Got the wood home and my dad was furious about the choice of lumber. He was a wholesale softwood salesman and he knew the cost of vg douglas fir. I guess I knew good wood when I saw it. Can’t wait to see the end cap completed.
-- bobdurnell, Santa Ana California.
Beginningwoodworker
4101 posts in 565 days
posted 544 days ago
very nice looking bench Steve.
-- CJIII Future cabinetmaker
SPalm
944 posts in 774 days
posted 544 days ago
Thanks people. This thing is a bit more work than I anticipated. I thought I would just bang it together. I guess the size of it has me a bit intimidated.
I plan to lag bolt the top to the base, so I can remove it later if needed. It is just sitting on it right now.
It was fun to plane, but anytime you have that much vertical grain, it makes it a lot easier.
I used 1/8 inch offset for the draw pins. They were a bit of tapping to get them in. Also the softwood compresses a lot more than a hardwood would. (Woodchuck would?)
It is Douglas Fir bought at Home Depot. Straight, pretty, and cheap (but really soft and it does splinter a bit).
Steve
TomK
503 posts in 766 days
posted 544 days ago
Looking very attractive and solid, Steve. I used draw-bored tenons on my base too. Pounding them in was a rewarding feeling, like something from another era.
-- If you think healthcare is expensive now, wait until it's free! PJ O'Rourke
jcees
553 posts in 691 days
posted 543 days ago
Great progress, bravo!
always,
J.C.
-- "Imagination is more important than knowledge" -- Albert Einstein
GaryK
9521 posts in 880 days
posted 543 days ago
Great looking job so far! The is going to be one beefy bench.
MichaelW
30 posts in 640 days
posted 542 days ago
Looks great Steve, I am considering this same type of joinery for my stretchers out of Doug Fir, I was thinking 1/32 for the dimension to pull the joint together, but it sound like from your experience you are suggesting 1/8 worked pretty well with this wood?
-- Michael, Seattle, WA
SPalm
posted 542 days ago
Hey Michael, it worked for me. It is pretty soft wood. I would suggest doing a prototype or two. I used a drill press to do all the holes, but even then they tended to wander a bit, with some splintering and all. I don’t know if I could hold that kind of tolerance with this wood. I am hoping that DF will be OK for the top, I have crushed it a couple of times with clamps. But what the heck, it’s a workbench, and maybe it is better to have a softer top so it will absorb the dings rather than a future work piece. Just go for it.
