Homebuilt CNC Router #3: Routing Large Mortises
Blog entry by SPalm posted 586 days ago 3146 reads 3 times favorited 12 comments Add to Favorites Watch
« Part 2: Simpler, Stronger, Prettier Part 3 of Homebuilt CNC Router series no next part
OK, I had 8 rather large mortises to cut for the feet and top of the trestles for a new workbench and thought my little tool would come in handy. It did a handsome job, so I thought I would share. I also did my first video, just the camera on a tripod, 5 minutes of routing. Boring unless you like this sort of thing.
I thought this would be a good time to explain some of the things that need to be decided, even for something this simple. Unlike hand routing, you actually have to state how fast and how deep to plunge, what the step-over or overlap is, and whether to climb or conventional cut.
So I chose: 1 inch per second feed rate, 1/2 inch per second plunge rate, 1/3 inch plunge per pass, 2 inch final depth, 40% step-over, and conventional. So routing a 2”x2.5”x2” mortise takes about 2.5 minutes each. I could push it faster, but it is actually removing quite a bit of wood even at this rate.
This is called Pocket routing, as opposed to Raster (carving), VCarve (signs), or Profile (cutting out) routing. I took off the dust skirt so you could see it work and hand held the vacuum.
Steve
12 comments so far
View gator9t9's profile
gator9t9
295 posts in 596 days
posted 586 days ago
Pretty Darn neat …..oh yes ….
Mike Bonney Lake
-- Mike in Bonney Lake " If you are real real real good your whole life, You 'll be buried in a curly maple coffin when you die."
View GaryK's profile
GaryK
9521 posts in 880 days
posted 586 days ago
Very cool!
View motthunter's profile
motthunter
2079 posts in 691 days
posted 586 days ago
extremely cool
-- making sawdust....
View Damian Penney's profile
Damian Penney
1030 posts in 883 days
posted 586 days ago
:) Cool
View Max's profile
Max
14347 posts in 1165 days
posted 586 days ago
That is really slick…..
teenagewoodworker
2479 posts in 660 days
posted 586 days ago
wow that is amazing. fantastic job!!!!
20538 posts in 714 days
posted 586 days ago
Steve,
This is great. You have done well with this.
Thanks for sharing.
View jm82435's profile
jm82435
508 posts in 634 days
posted 586 days ago
Like staring into a fire, there is something mesmerizing about watching a CNC run. You have two motors driving your Y axis. Is this for rigidity? Does each require its own stepper controller? Where did you get your leadscrews and ant-backlash nuts? You are obviously a Vcarve Pro user now, have you used other Cam Software? Bobcad for example? We use EdgeCam at work ($$$), my buddy uses Bobcad. I am just getting my feet wet with my router (the 3 axis are moving- no spindle yet (I have a sharpie road runner ha ha)(still working up to a spiro-graph speaking of cool software)). For the capability and price points Vectric looks like a great deal. I can’t wait to try them out (the different Vectric flavors – Photo looks really cool). I love your design, I especially like the vertical vise on the end.
-- A thing of beauty is a joy forever...
25794 posts in 1292 days
posted 585 days ago
Great job. Cool video.
View greener's profile
greener
5 posts in 536 days
posted 478 days ago
I knew that I recognized that name (spalm) from the cnczone. Great machine, thanks for sharing. I got mine finished and I’ve been playing with alot of the same sort of things. I’ll have to add some blog post of things that I’ve been playing with.
Nice to know that your here as well.
Brian
View jm540's profile
jm540
133 posts in 311 days
posted 268 days ago
I have been watching a guy I found googling build your own cnc router is this the same machine
-- jay Rambling on and on again
View Matt's profile
Matt
178 posts in 264 days
posted 262 days ago
I imagine he’s using 2 steppers on the Y-axis to avoid racking. My machine has belt drives and two motors on the Y. Fast, fast. Good job. Want to trade notes some time? I’m still a rookie at the CNC.
-- Matt - My Websites - http://www.bestinwood.com - Hand Tools :: http://www.workshopgarage.com - Small Shops
