Steve's 2x4 Challenge #2: It takes shape
Blog entry by SPalm posted 665 days ago 520 reads 0 times favorited 14 comments Add to Favorites Watch
« Part 1: Prototype Part 2 of Steve's 2x4 Challenge series no next part
Getting much closer. The finally assembly takes shape. It is a Krenov type cabinet. Maybe a disservice to the Master trying to build one out of a 2×4, but I wanted the largest piece of furniture that I could build, and this is what appeared. It has been fun.
I am trying to figure out how to complete it. The door is not attached. It is about an eighth of an inch thick. The plan was to glue a block to the inside top and bottom of the door and use finishing nails as hinge pins. The door was also supposed to have long iris type leaves jig sawn into it, but that is not going to happen. In fact, the door may just turn into a shelf do to time. In fact, it looks pretty good with out the door, and a shelf would be cool. Any suggestions?
So off to a final sanding, figure out the door/shelf dilemma, and then a few coats of oil.
Good to be back in the shop,
Steve
14 comments so far
View GaryK's profile
GaryK
9521 posts in 881 days
posted 665 days ago
Great looking job, Steve!
One of the best I’ve seen so far.
A shelf would be nice looking.
View toyguy's profile
toyguy
715 posts in 730 days
posted 665 days ago
well that is impressive… 2×4 you say…
25793 posts in 1293 days
posted 665 days ago
Fantastic. It’s starting to get hard to make a decision.
View rikkor's profile
rikkor
11335 posts in 767 days
posted 665 days ago
Man alive, this contest has really stretched the bounds of creativity.
View mot's profile
mot
4901 posts in 929 days
posted 665 days ago
Wow! That’s a heck of a piece from one 2×4. Awesome!
View Artesano's profile
Artesano
20 posts in 677 days
posted 665 days ago
Awesome, I wont look at 2X4 the same way again…
-- Artesano Taino
View Miket's profile
Miket
265 posts in 665 days
posted 665 days ago
I have been look at these 2×4 projects, and they are amazing. This is one heck of a project.
-- It's better to have people think you're stupid rather than open your mouth and remove all doubt.
14914 posts in 744 days
posted 665 days ago
2×4, just as well it wasn’t a 4×2. imagine what you do with that.
View Russel's profile
Russel
2054 posts in 832 days
posted 664 days ago
Wow. Is there no end to the creativity? That’s quite a pretty piece and would look good with either a door or a shelf. Downright impressive.
View shaun's profile
shaun
360 posts in 798 days
posted 664 days ago
Steve, this is mind boggleing. Excellent work! You all certainly know how to make a guy feel inadequate. LOL
-- I've cut that board three times and it's still too short!
14156 posts in 1053 days
posted 664 days ago
ok.. how on earth am I supposed to select my favourites from all these AMAZING creations???
It’s going to be a sleepless night or two as I struggle to make my voting decision.
This is awesome.
a 2×4. huh.
View Mario's profile
Mario
882 posts in 944 days
posted 664 days ago
WOW that is awesome. I can’t beleive that it used to be a 2X4. WOW.
-- Hope Never fails
View Mark Mazzo's profile
Mark Mazzo
343 posts in 805 days
posted 664 days ago
Steve,
Very impressive! I really like the design. How the heck did you get that out of a 2×4? I’m guessing that my perspective is a bit off because of the photos – what are the dimensions? Really well done.
View SPalm's profile
SPalm
945 posts in 775 days
posted 664 days ago
Hey, thanks everyone for the comments. I plan on going with the shelf and nixing the door. This is just for fun anyway. My daughter says she wants it, and she wants a shelf. (I will have to add some leg stretchers closer to the ground after the contest, as it is not the strongest piece of furniture.)
My whole premise was to make it seem bigger than it is. The leg placement, the frame and panel, and the uplifting curves seem to have pulled it off. The actual box is three 2×4s (about 10.5”) wide by two 2×4s (about 7”) deep by 16 inches tall. The legs are about 2.5 feet long.
The 2×4 was cut into sections and then resawed for various purposes:
Two 17” sections sliced into ten .25” sheets for the vertical panels (3 front and back, and 2 for each side).
One 17” section was sliced into six .75” x .75” sticks that became the four stiles and the eight rails on the sides. These actually became a bit thinner, but because of the way they are used, the thickness was not important, they just had to be the same.
One 8” section was sliced into six .2” sheets for the top and bottom panels.
The remaining section of about 32” was sliced into the four 1” x .75” x 30” legs interlocking each other and into the four 1.25” x 12” rails for the front and back.
Steve
