CNC Routed Salt Box #1: Creating the Top
Blog entry by SPalm posted 582 days ago 5717 reads 5 times favorited 33 comments Add to Favorites Watch
no previous part Part 1 of CNC Routed Salt Box series Part 2: New Vacuum Clamp & Ooops »
I will try to describe how I created the design for the Salt Box, and how I told my homemade CNC to cut it out. Here is a picture of the box, and the top. Let’s start with the top.
Remember this is just a router. Almost all the things that the CNC can do may be done by hand routing, maybe with a template or a fancy router table. But for this project, I picked a couple of things that would be quite difficult without the machine control.
Background: In my mind, there are four types of routing that you can have the machine do.
Profile: Cutting on a line. You have it cut on a line, outside of the line, or inside of the line. Different bits can be used to get different effects. These would include a straight bit, a V-bit, and a rounded core box bit. You can also tell the machine how deep to go and whether to go flat horizontal or gradually change the height as it routes.
Pocket: Cutting out a pocket (or mortise). Typically here you select a closed drawing and tell the machine how deep to route it out. The two main bits here are the straight bit and the bowl cutting bit with its slightly curved sides. Typically the bit is plunged to a certain depth in the center of the pocket, and then moved about to complete that depth. Lower the depth and repeat.
Raster: Cutting out a “3D” design. Typically here the router is started at the upper left hand corner and then move straight to the right using a very small bit. The bit depth is constantly changed as it moves. This is repeated hundreds if not thousands of times until the design appears. It takes a long time, and you need a really nice machine to pull off a nice result.
V-Carve: Cutting with a V-bit while gracefully changing the height. This produces basically the same thing as Chip Carving by hand. The design must be carefully chosen to never allow the bit to route too deep. The way it works is the software sees a drawing object (called a closed vector) and will tell the machine to lower the V-bit into the center of it until the depth is such that the sides of the V touch the sides of the closed vector. Then it will instruct the machine to move and raise the bit to keep the V always touching the sides of the vector. A lot of signs are made this way as font characters are closed vectors.
I will cover Profile and Pocketing in another blog. I don’t do Raster. And that leaves me with V-Carve for now.
Here is a picture of the objects presented to the software which creates the design. This should be recognizable to someone who has done Chip Carving. I started with a bunch of overlapping circles. I then trimmed the lines (called vectors) until I had what is shown. Next I used layers in the drawing editor to copy certain elements of the design to end up with 4 sets of closed vectors. I then selected all the little parts and stretched them into an oval. Also pictured is the profile of the design and where the drill hole goes.
And here is a video of it being cut. I edited it down to two minutes. It is worth a look, as I think this is the most magical part of a design. Maybe you should hit the mute button, as you probably are not wearing ear protection right now.
Take care,
Steve
-- -- I'm no rocket surgeon
33 comments so far
View jim C's profile
jim C
1400 posts in 1270 days
#1 posted 582 days ago
Great explanation Steve
Thanks
-- Government does not solve problems; it subsidizes them.
View sras's profile
sras
3248 posts in 1300 days
#2 posted 582 days ago
Love the video! Thanks for sharing.
View Bob Kollman's profile
Bob Kollman
1779 posts in 1362 days
#3 posted 582 days ago
I turn with cnc lathe, your home made machine cuts just as gracefully as any of our fadal mills.
An amazing achivment on so many levels for a home wood work shop. Great Video, I would
have liked to seen it all.
-- Bob Kenosha Wi.
View leanne's profile
leanne
45 posts in 583 days
#4 posted 582 days ago
loved the video, look forward to more.
-- Leanne, Australia, http://www.sawdustartonline.com
View Northwest29's profile
Northwest29
230 posts in 661 days
#5 posted 582 days ago
Now that’s just too cool! Thanks for sharing the video.
Ron
-- Ron, Eugene, OR, "Curiosity is a terrible thing to waste."
View blackcherry's profile
blackcherry
2905 posts in 1994 days
#6 posted 582 days ago
Now Steve this is right out not playing fair 15 yard infraction for not using your hand tools…lol Nice work on the video the CNC cuts like butter…BC
View CartersWhittling's profile
CartersWhittling
444 posts in 845 days
#7 posted 581 days ago
Thanks for the video.
-- And whatsoever ye do, do it heartily, as to the Lord... Colossians 3:23
View fernandoindia's profile
fernandoindia
1002 posts in 1115 days
#8 posted 581 days ago
Steve, that’s just too cool! Thanks
THough it may it not be rocket science, it is very close to it. Great job
-- Back home. Fernando
View lanwater's profile
lanwater
2422 posts in 1105 days
#9 posted 581 days ago
Great video Steve.
Your CNC cuts through the wood like butter with excellent precision.
View MShort's profile
MShort
1378 posts in 1589 days
#10 posted 581 days ago
Thanks for the video Steve… What a great toy (tool) to have !!!!
-- Mike, Missouri --- “A positive life can not happen with a negative mind.” ---
View shipwright's profile
shipwright
3400 posts in 969 days
#11 posted 581 days ago
OK Steve, it’s been suggested several times but I think it’s time to abbreviate your signature.
Steve, rocket surgeon …....................... has a certain je ne sais quoi and would look quite appropriate on your posts.
All those in favor say Aye.
Good video
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/
View degoose's profile (online now)
degoose
6598 posts in 1526 days
#12 posted 581 days ago
Brain Scientist… nah… I like Rocket Surgeon… awesome… meaning I am full of AWE… great video too
View Joe Lyddon's profile
Joe Lyddon
6396 posts in 2223 days
#13 posted 581 days ago
That Video is SO COOL!
Just awesome how it can do that!
Thank you for showing…
How did you define your 3D source?
View GaryK's profile
GaryK
10263 posts in 2159 days
#14 posted 581 days ago
Great looking video!
What kind of wood is that?
View SPalm's profile (online now)
SPalm
4118 posts in 2053 days
#15 posted 581 days ago
Thanks everyone.
That V-Carve stuff always captivates me. Just when I think it screwed up, it fixes it. Like Steve Jobs said “It’s magical”. Of course when things go wrong, it can draw all over the place – with a very sharp and scary tool on expensive wood.
That video is 90% of what happens, and it is running at normal speed. Things get slower when I am hogging out a larger design. I guess that is a duh. Also I took the dust vacuum skirt off for the video.
It is Cherry wood. And there is some double sticky 3M tape underneath because I do not have any tabs. If I did not use the tape, the part would take off flying just after the final profile. And then the drill would just drill into the air. Don’t ask me how I know.
Steve
showing 1 through 15 of 33 comments
