The next and final version.
I needed to address some of the problems that I noticed from before. Complexity needed to be reduced. Some of the racking and shifting needed to be addressed. I wanted to remove the concept of keeping all the skate bearings so tightly pressed against the rails. And it needed a face lift. So I came up with a new (is anything new?) design.
I kept the leadscrew and motor combination along with the torsion boxes. I got rid of the box below the gantry to let the bed lay flat on the table top. The sides were to lose the stiffeners by using a different strengthening technique. The wrap-around Y carriage was to turn into a flat plate. And I went with V-bearings for the linear rails. These bearings are actually fancier than they look. They have two rows of ball-bearings to be able to take both lateral and radial pressure.
They were to ride on angle iron as the official V-rails were beyond my pocket book.
I spent a fair amount of time trying to find a way to make the gantry wall stronger. I actually tested various plys and MDF combinations. I found out that 3/4 inch MDF skinned with laminate on both sides yielded a very strong panel. I also found that yellow glue was better than contact cement at holding it all tight. This combination actually makes a small torsion box, which is a substrate tightly coupled to skins on both sides. I edge banded them in maple to keep out moisture.
My gantry now looked like this:
I went with dual motors on the long axis to virtually eliminate any racking and more tightly couple the drive mechanism to the bearings. I used wooden standoffs to attach the motors.
The leadscrews where coupled to the anti-backlash nuts with wooden holders on each side of the gantry.
I attached the Y leadscrew to the carriage underneath the Y torsion box to get it out of the way.
I used the removable Z from the last machine and mounted it on this one.
And then added dust collection. A must needed addition.
It was all working pretty darn alright. But there were a few things that I decided to upgrade. The V-bearings for the Y carriage were digging into the edge of the angle iron. I solved this by adding a few wooden strips and mounted the angle iron with the angle facing up. This vastly improved its ride. I had also noticed that sometimes the steel rods and brass bushings for the Z were sticking, so I switched them over to V-bearings as well.
And finally I cut the plate across the front of the machine and added an end vise for vertical board routing.
To those who are still hanging in there: On a different note, before I had the money to buy a CAM program, I needed something to use for test cutting. So I wrote SpiroCNC. I think alcohol was also involved. It would generate G-code for spirographs and other geometric designs. It was kind of stupid fun and is still used a bit by people in that same situation. I did also use it to generate some rosettes.
Take care,
Steve
31 comments so far
Dadoo
home | projects | blog
1726 posts in 962 days
posted 840 days ago
Man, you really impress the hell out of me. Wow. I am humbled. Keep it up.
woodgizmo
42 posts in 875 days
posted 840 days ago
What an incredible design.
-- Hard work spotlights the character of people; some turn up their sleeves, some turn up their noses, and some don't turn up at all!
GaryK
9820 posts in 959 days
posted 840 days ago
Great project!
Looks like you are using steppers and not servos. Do you have encoders on them?
What are you using for a controller?
Gary
-- Gary - Never pass up the opportunity to make a mistake look like you planned it that way & "We are what we repeatedly do, excellence then is not an act, but a habit" -Aristotle
SPalm
1155 posts in 853 days
posted 840 days ago
Thanks guys.
Gary, they are stepper motors so there is no feedback or encoders. Servos are a bit too much for me to handle. The machine is not allowed to miss a step, and it doesn’t. Those motors are really strong. I can barely hold back the gantry when it is moving. They have about 300 oz/inch of torque and 200 steps per revolution. I am micro-stepping them with 16 pulses per step. Each revolution is 1/4 inch (4 tpi), so that is 12,800 pulses per inch. I am still amazed that it all works. The controller is a kit from HobbyCNC.com.
Steve
gbvinc
572 posts in 918 days
posted 840 days ago
Nice! With this setup, how many inches per minute is the cutter moving? (avg)
Thos. Angle
4062 posts in 934 days
posted 840 days ago
Good heavens this is fasinating. I just wish I wasn’t so old, I try to figure it all out. But I’m paying attention and learning.
-- Thos. Angle
SPalm
posted 840 days ago
Thanks,
My rapids are set at 150 ipm, or 2.5 inches per second. This is the rate that I can move the router around when I’m not cutting anything. The cutting rate is set by the CAM software depending on what conditions are; depth of cut, type of wood, bit RPM, diameter of the bit, etc. Just like hand routing. I am pretty chicken about pushing it, but I could take it up to the rapid rate if I wanted. Doing something like a mortise at 60 ipm or 1 inch/sec is still impressive to watch, for me. I cut something like that with successive cuts, dropping the Z about 3/8 inch per pass. So the simple answer is about as fast as you would cut it by hand.
Steve
gbvinc
posted 840 days ago
Thanks for the quick answer!
What is the max travel on the X/Y and Z axis?
(Can’t wait to start in building mine… it has been on my list for a year now)
GaryK
posted 840 days ago
Steve,
Great website. Thanks for the link. Seriously thinking about this. A few questions.
1. Are you plugging this into your parallel port on your PC, or a USB port with a parallel adapter?
2. Does the CAM software just output g-code and then you use a different program to send the code to the controller?
3. Do you know of any software that can take a dwg or dxf file and use that to create g-code?
Too bad about no encoders. If they were being used by the controller it would allow the steppers to skip and not lose their position. I worked with servos in the automation industry and I guess I an kind of spoiled.
Gary
Sawdust2
1256 posts in 1059 days
posted 840 days ago
”...on my list for a year now” Hmmmmm.
Careful. On an earlier post Steve said he built one version in a weekend.
He’s got the whole thing planned out. You ought to be able to make if before breakfast on Saturday.
I, on the other hand, am going to sit back, pop a root beer and watch ‘cause this is too good to miss.
SPalm
posted 840 days ago
Don’t do it man.
PUT THAT THOUGHT DOWN AND BACK AWAY FROM THE DOOR.
You really have to ask yourself why. What do you want to do with it and how much do you want to spend in dollars and time. For me, I just wanted to do it, and fell into it. I had no expectations or real cost targets. That is probably not a good way to go for most people. I saw it more like the guys who restore an old car. You can’t ask them why or how much. They just want to do it. They spend a bundle and only drive it on Sundays, but I admire them for it. Building it drove my uber practical Dad and my artsy Sister crazy. The first argued that I didn’t need it, and the second argued that anything that it produced would be just look machine made anyway. I am tired of those arguments.
What is the cutting envelope? I haven’t really measured it. The basic size is about 2’ x 4’ because that is what fit in my shop. It can get kind of expensive to keep increasing the size, just like a boat. A lot of newbies want to cut 4×8 sheets, and they soon find out that will cost a lot of money. Remember flex and whip?
My stepper driver card and controller (Mach3) combination uses Windows XP and a parallel port on a PC of at least 1Ghz. I guess that rules out a lot of modern PCs, or you just buy a cheap PCI to parallel port adapter. USB is talked about a lot, but for the DIY it is not there yet. I am pretty sure that a USB to parallel dongle won’t cut it.
The main purpose of a CAM program is to convert DXF, EPS, and other line art type files (for 2D) to a G-code file. The fancier ones also help you pick feeds and speeds along with a simulation. I do this upstairs, copy the G-code file to a flash stick, carry it downstairs and feed it into the machine. A .dwg file is more like a .doc file. It is a design file that contains much more info than is needed. So you export it to DXF from your CAD program. For 3D (think carving) the CAM input file is more like a mesh file. The output is still G-code. Go to Vectric.com and download their demo. It was originally a sign making CAM, but it has a user friendly look and feel and you can get a better idea how this all works.
Steve
gene
2167 posts in 855 days
posted 837 days ago
I had just sent you a PM in regards to another forum question, when I saw this. This is truly fantastic. Great Craftsmanship and detail.
God bless
-- Gene, a Christian in Virginia
Bill
2553 posts in 1133 days
posted 835 days ago
Great job Steve. Keep it up and we will see a new CNC router on the market!
Alexon
1 post in 783 days
posted 783 days ago
Hi, I am Brazilian and living in Brazil! His CNC was fantastica, would pass the measures of CNC (X, Y, Z)
28894 posts in 1372 days
posted 783 days ago
Great job. Nice design.
Russel
2167 posts in 910 days
posted 783 days ago
Wow. A most impressive piece of equipment.
rikkor
11329 posts in 846 days
posted 783 days ago
Holy cow! What a project.
Bill Butler
73 posts in 734 days
posted 698 days ago
I love what you have done and would love to build one myself.
This certainly brings back memories for me as many years ago I was contracted by an electronic equipment fabrication firm to write the software to control/program their printed circuit board scoring machine. The firm used a PCDSP card from Motion Engineering so we didn’t have to write PID algorithms we did have to tune them. Unfortunately the boards ME had were in the 1000’s of dollars so not necessarily suitable for the hobbiest.
I am not familar with G-code. Does the kit you purchased support this out of the box?
23849 posts in 793 days
posted 698 days ago
Steve,
It never ceases to amaze me what comes out of this site. This is absolutely wonderful and I look forward to seeing you put it into action.
Wow!!!!!!!!!
roman
1390 posts in 865 days
posted 698 days ago
People climb mountains because they can, because the mountain is there and I admire those who do.
Most people talk the walk, few walk the talk…........my hat is off to you!
Wheres the vacumn to hold the workpiece down?......how do you hold the work piece down?
-- http://smg.photobucket.com/albums/v96/woodworking/
SPalm
posted 698 days ago
Thanks guys. I need to find time to get back to using it. I am in the middle of a complete shop re-do right now. The shop that is in the pictures now is over twice the size, with new tools (Yea!), and is taking more time than I want just putting it in order. So many things to do, so little time.
Bill,
G-Code is the language that most CNCs use. It is analogous to Postscript or PCL. It is the intermediate command language between a CAD system and the hardware controller. For most systems it is a three step process. So the workflow is kind of like this:
1) Draw something in a CAD system, and save it in DXF format.
2) Take this DXF file and read it into a CAM program. The CAM program will let you pick the size of router bits, determine the feed speed, and figure out the XYZ commands to follow to cut out or carve your part. Many allow simulation to allow you to see if it will all work out. This is all saved in a G-Code file.
3) Take this G-Code file and feed it into the controller. In my case this was another PC running a special program that would control the stepper motors to move around and route out the design. A simple driver board connected this PC to the motors.
As far as I know, the CompuCarve contains all of this in one box. It does not use G-Code but instead its own proprietary version. Many CNC people think this is one of it’s big down falls.
Roman,
Building it was quite a ride. I was obsessed with it, maybe not a good thing :) A Vacuum press hold-down system would be nice. Someday. Right now I have T-tracks mounted in the table. I also have the front vise. I am pretty excited about this vise for mortising and dovetail type stuff. It is pretty unique as far as CNCs go. This use interests me more than ‘CNC carving’ uses.
Steve
Peter O
1068 posts in 846 days
posted 698 days ago
I used to work on a CNC high-def plasma machine, so I can appreciate how much effort went into building this – lots and lots of effort! Your straightforward design and explanations make it seem much simpler than it is.
-- http://www.north40custom.com -- http://north40studios.etsy.com --
DannyBoy
508 posts in 837 days
posted 693 days ago
That’s pretty cool, man.
-- He said wood...http://hickbyassociation.blogspot.com/
jm82435
581 posts in 713 days
posted 689 days ago
The outboard vise is brilliant, I haven’t seen that before but what a great Idea! That is the most beautiful cnc I have ever seen.
-- A thing of beauty is a joy forever...
Mark A. DeCou
1543 posts in 1377 days
posted 304 days ago
It’s been said above before, but this is really a nice blog. Good work, and the machine is impressive. I’m a bit confused over the software side of this project, but the rest of it makes sense to me. Maybe I’m just so out of date that the computer action is overwhelming to me.
M
-- Mark DeCou - American Contemporary Craft Artisan - www.decoustudio.com
Billp
360 posts in 1171 days
posted 183 days ago
Ive read you blog about your adventure building the cnc machine. I love your tanasity and creativeness, it does not matter if you will you it that much or not it was just something that had to be done. Congrats!!!
-- Billp
23684 posts in 548 days
posted 183 days ago
This an amazing CNC I can’t imagine making such a great tool, fantastic job
-- Jim from Heirloom Woodshop, custom furniture ,maker, woodworking school, http://www.heirloomwoodshop.com/
jhatcher
7 posts in 241 days
posted 172 days ago
brings me back to when I made my cnc, looked pretty much the same, except aluminum plate for the Z. I was using the motors and such from hobbycnc which were nice since they came in a bundle. My only drawback was that I was using 2 screws on the Y with only 1 motor and a toothed belt. Worked great for small setups, but then I got big headed and tried a 6’ version and that’s where the problems started.
If you plan on cutting through at any time, I took a sacrificial board and made a g-code to route on all the area with a 3/4 bit to “plane” it, then you have a perfectly parallel surface and can set the depth just a bit below the bottom of the workpiece.
darl
3 posts in 140 days
posted 140 days ago
Great machine! How hard is it to learn the computer aspect of setting up and running one of these? I won’t have trouble with the mechinical aspect of it. Darl
davidf
1 post in 114 days
posted 114 days ago
This machine looks very well designed and built, great job!
A while back I worked on a machine that a company was trying to sell that looks almost exactly like this except made out of metal:
I think you might find it interesting. The metal design uses the same concept for v-bearings, leadscrew, and anti-backlash nuts and how they are all mounted and put together. I think the version in my picture was built around 2006. I ended up using LinuxCNC (EMC2) to control the machine and we could mill/surface 6061 aluminum and abs plastic as well as wood, although feedrate in metal and plastic was fairly low (around 0.5-8 ipm depending on depth of cut). Rapid was around 180ipm.
Evelinda
3 posts in 375 days
posted 66 days ago
GREAT JOB, ever since these cnc bots came out I have been interested in purchasing one but they are really out of my league financially, my hat is off to you. As a female I consider all the time and effort that went into the project and am in awe of such a feat. I enjoy the talent of those that can attempt such projects and follow through from the concept and the finished model. You are very blessed and I enjoyed your postings.
Good Luck with this.
-- Evelinda, Mission TX
