Another Cutting Board Design
Blog entry by SPalm posted 1043 days ago 11988 reads 69 times favorited 26 comments Add to Favorites Watch
I am in the process of building another board and thought I would share my thinking process along with some build pictures. When I came up with the design for the Steps board, I was thinking about how one draws a 3D box on a piece of paper. You draw a large square, and then add small mitered edges to one corner to give the appearance of seeing it slightly from the side. Making these miters out of two different woods adds to the shadows, which adds to the effect. I did this for the Steps board, but I also added a notch so that the boxes would nest into each other.
On my long commute, I was thinking about this and wondered what would happen if I reversed the sizes and used a small box with large miters. Here is a pic of the standard style of box, along with the new version:
And then I started playing with tiling this style to make a board. This really has potential. Kind of like looking into an egg crate. It believe it is only possible with an end grain style board (?). But there is a fairly large miter to contend with.
I played around using the two miter woods to obtain a banded look rather than a shadowed look. Not bad. It starts to look like boxes stacked on top of each other, rather than an egg crate.
Then I tried two different woods for the bands. This seems to increase the stacked boxes concept. I really liked it, Karen did not.
So on to a fourth (actually more than that) design. It was a compromise between the egg crate and the banded design. And it also happens to be the hardest to build.
OK. Design settled, end grain not face grain, on to the build. First step: lots and lots of stock prep. I used maple and cherry for the miters, separated by thin strips of mahogany. Some reclaimed walnut for the dark square. There is a mock assembly on the left hand side of the stack-up. Each strip is 1/2 inch thick, which should yield a board about 12×16 inches.
The next picture jumps ahead a bit. The stack-up layers were glued and lightly sent again through the thickness sander to make sure all eight were the same size. Then I rip cut the miters. This was a bit tricky and a lot scary; they are large and long. I started out rough cutting them on the bandsaw. Then I trimmed them on the tablesaw. Not bad, but not good enough for a showy board. So I did something for the first time and jointed a miter. I tilted the jointer fence towards me and fashioned a push stick. I set the blade depth to absolute minimum and sent them through. I worked amazingly well. Then I glued up the sticks.
As in the Steps board, I lightly jointed the corner of the miter to reestablish the 90 degrees. Then I formed the square on the bandsaw. The thickness sander cleaned them up.
So here is where I am. I stacked the sticks to have a look. So far pretty good. A little misalignment, but I think it is acceptable. The sticks fit together extremely nicely. All my fences were square. Now to crosscut, glue-up, sand, and finish. Things can still go wrong. The sticks are over two inches square, so I am thinking of crosscutting them on the bandsaw. This usually leaves a rough finish (which I can sand out), but a rough edge which I cannot. Maybe a sled on the BS?
I need a break (and I have a real job), but this is kind of exciting. It will try to finish this board and then I will post it to the project section.
Steve
-- -- I'm no rocket surgeon
26 comments so far
12051 posts in 1509 days
#1 posted 1043 days ago
looking good so far ,
waiting for the final on this ,
you have some sweet design works !
edit ,
the last 3 pictures didn’t load till after i commented ,
very nice !
14855 posts in 2386 days
#2 posted 1043 days ago
I think you have too much time on your hands. :-)
Seriously, this is going to be beautiful. I haven’t seen a pattern like this at all before.
View sras's profile
sras
3240 posts in 1297 days
#3 posted 1043 days ago
Very nice pattern – it gives a real sense of depth. Good luck on the rest of the build!
View Eric_S's profile
Eric_S
1522 posts in 1363 days
#4 posted 1043 days ago
Wow. This is going to be an impressive cutting board. Thanks for the post.
-- - Eric Indianapolis, IN
View rowdy's profile
rowdy
370 posts in 1610 days
#5 posted 1043 days ago
Steve, do you know the word masochist? LOL! Any one of those designs would lead to a truly outstanding board that would be an absolute eye catcher. Where do you find the patience? Whew!
-- Rowdy in Kechi, Kansas
View SPalm's profile
SPalm
4108 posts in 2050 days
#6 posted 1043 days ago
Charlie:
One word: Empty Nest Syndrome.
Try it, you might like it.
Eric and Rowdy:
This version is probably a bit too complicated to repeat. We call this type of design morphing “creeping elegance” here at work. But simpler versions have some potential.
87068 posts in 1745 days
#7 posted 1043 days ago
I’m always amazed how these designs come together. Look forward to the rest of the blog. super work.
View newTim's profile
newTim
528 posts in 1774 days
#8 posted 1043 days ago
I’m in.
-- tim hill www.newcalshop.com
View MShort's profile
MShort
1373 posts in 1586 days
#9 posted 1043 days ago
Cool Design !!!!
-- Mike, Missouri --- “A positive life can not happen with a negative mind.” ---
View majeagle1's profile
majeagle1
1382 posts in 1664 days
#10 posted 1043 days ago
Wow, this is simply amazing !!!! Can’t wait to see the finished product.
You mentioned on the first design that you thought it would work both end grain and face grain. Do you think there would be an issue with glue up in doing it face grain? ( I have heard that gluing end grain doesn’t work do well ???)
This one REALLY intrigues me…..........
Beautiful work and great blog.
-- Gene, Majestic Eagle Woodworks, http://majesticeagleww.etsy.com/, http://www.flickr.com/photos/majesticeagle/
SPalm
#11 posted 1043 days ago
Gene,
Hmmm. I am sure that the glued mitered corners would work with face grain. Miters are half face and half end grain. But the other side of the pieces are end grain to face grain, so, good point. It does look like a problem. I am glad that I went with the style that I did :-)
Note: I added a question mark to that point in the blog where I mentioned it.
Thanks for the thought,
Steve
Edit: I am not sure. I should check with other LJs. This style of board is very popular:
http://lumberjocks.com/projects/9183
And I have built several of them. No complaints after several years. Maybe not for furniture, but OK for boards. (??)
View lumberdustjohn's profile
lumberdustjohn
1164 posts in 1334 days
#12 posted 1043 days ago
I like them all.
I also understand the empty nest, same problem here.
Look forward to the finished product.
-- Safety first because someone needs you.
View stefang's profile
stefang
9453 posts in 1502 days
#13 posted 1043 days ago
Great work Steven. This is going to be a sensational board. I can’t wait to see it finished.
-- Mike, American in Norway
34369 posts in 2568 days
#14 posted 1043 days ago
Steve:
Some great design work. Nice looking stuff.
View degoose's profile
degoose
6590 posts in 1522 days
#15 posted 1043 days ago
Taking it one step further…
showing 1 through 15 of 26 comments
