Table Saw is home
Blog entry by Rustic posted 08-27-2008 09:19 PM 835 reads 0 times favorited 2 comments Add to Favorites Watch
Myh table saw made it home in 1 piece. They had to use heat and brute strength to get it off. Bought a new blade for it, a 60 tooth smooth cut Oldham. I also tested a router relief carving. to see pic go to my projects.
Back to makin sawdust yee haaw.
2 comments so far
View lew's profile
lew
11941 posts in 3659 days
#1 posted 08-27-2008 10:23 PM
Check the bearings for oil/grease leakage. If they heated the blade shaft, the heat could have affected the bearing seals. The bearings are “permanently” lubricated and sealed.
View tenontim's profile
tenontim
2131 posts in 3648 days
#2 posted 08-28-2008 02:48 AM
Congrats. Rick, get yourself a 40 tooth blade for ripping lumber. That 60 will be ok for cross cutting, but it’ll load up with chips if you try cutting any 8/4 stuff. You still will have to go slow even with the thinner stuff.
