A glitch in my shop cleanup
Blog entry by Rustic posted 626 days ago 1437 reads 0 times favorited 14 comments Add to Favorites Watch
Hey all,
In the process of redoing my dust collection setup for my shop clean up, I ran into a small glitch. I bought a cyclone top for a 5 gallon bucket, the problem is that my hose and the posts on the cyclone are the exact same size. They are both 2-1/4 inch inner dia. So now I need to find a coupler for it. Ugh I hate these little glitches.
14 comments so far
View chrisstef's profile
chrisstef
5581 posts in 1204 days
#1 posted 626 days ago
When all else fails … duct tape.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View Rustic's profile
Rustic
3007 posts in 1793 days
#2 posted 626 days ago
That make work for the short term. I have found a 2-1/2 inch coupler that make work. But sadly Woodcraft is closed for the evening
34396 posts in 2598 days
#3 posted 626 days ago
That’s what they make duck tape for. It holds the item in the correct position to work.
View Dennisgrosen's profile
Dennisgrosen
10851 posts in 1312 days
#4 posted 626 days ago
you make a square one yourself in wood ….. :-)))
Dennis
View David Grimes's profile
David Grimes
2065 posts in 837 days
#5 posted 626 days ago
Stick to your guns, Rustic. Often it is better to wait and do it the right way.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View helluvawreck's profile
helluvawreck
10924 posts in 1064 days
#6 posted 626 days ago
Get someone to hold the joint together and wrap it several times with duct tape. Then take some solid copper wire, while the person is still holding the joint, and wrap the solid wire around several times on each pipe overlapping the joint and then duct tape once more. If the wire is wrapped tightly it will reinforce the joint.
View tyskkvinna's profile
tyskkvinna
1295 posts in 1183 days
#7 posted 626 days ago
Woodcraft opens in a few hours….. :)
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
Rustic
#8 posted 626 days ago
Finally some one who is on my side thanks David and Moose
Rustic
#9 posted 625 days ago
Bought the new couplings and they STILL don’t fit. I guess I will spend the money and get the right set-up tomorrow
View jockmike2's profile
10635 posts in 2444 days
#10 posted 625 days ago
IF YOU CAN’T FIND THE RIGHT OD, FIND A PIECE THAT WILL FIT THE ID. BEEN THROUGH IT BEFORE MYSELF.
Rustic
#11 posted 625 days ago
Found them at Woodcraft 4 couplings later and it finally fits. Total cost about 35 bucks. vs 79.00 for the dust deputy
Dennisgrosen
#12 posted 624 days ago
good news :-)
Dennis
View lilredweldingrod's profile
lilredweldingrod
2493 posts in 1304 days
#13 posted 624 days ago
I found adapter kits from Ridgid at HD for 7-8 bucks.
View Jim Jakosh's profile
Jim Jakosh
7651 posts in 1303 days
#14 posted 623 days ago
I could have turned you one when I got home!............Jim
I make them out of PVC pipe all the time.
-- Jim Jakosh.....Practical Wood Products...........Learn something new every day!!
