Got an excuse to buy a Riser Block..
Blog entry by Rick Boyett posted 36 days ago 301 reads 1 time favorited 8 comments Add to Favorites Watch
A couple of months ago, I bought this bandsaw off Craigslist. It’s a great little Grizzly BS.
A couple of weeks ago I bought about 50 bd ft of Black Walnut from a fella at First Monday Trade Days in Canton, TX for only $2.00 a bd ft. (killer deal).
I think I forgot how big the opening is for my BS. Looks like I’ll be buying a riser block and new BS blades now.
I’m going to use this lumber to build a baby crib..
Grizzly Bandsaw
8 comments so far
View Julian's profile
Julian
687 posts in 418 days
posted 36 days ago
Have fun with that walnut! Nice looking stuff you have there, and what better reason to upgrade your saw.
-- Julian, Park Forest, IL
View davidroberts's profile
davidroberts
240 posts in 378 days
posted 36 days ago
Really great find. Do you go to Canton often. I went a lot as a teenager, but not for wookworking stuff. Do they have a selection of old tools, lumber, etc?
-- david roberts, houston area, "A little knowledge is a dangerous thing, but that has never been a problem for me."
View SEE's profile
SEE
61 posts in 60 days
posted 36 days ago
That’s a fine BS that you have and a great score on the walnut. Congratulations on both purchases! Your BS looks like it’s brand spanking new!
I have two of those saws. One is is a G0555X that I bought new with a riser block and the other one is like yours, the G0555. And, like you, I bought my G0555 from CL.
I’ve had very good service out of both saws. The X version I use for resawing only. The one from CL is set up for curved work.
Have you decided which blade(s) to buy for your saw after you get the riser block installed? I’ve been very pleased with the Timber Wolf blades that I ordered directly from Suffolk Machinery. They usually have a deal going where you buy 3 and get one free.
For resawing I recommend the 1/2” and 3/4” 3TPI with Positive Claw. I started out with the 3/4” blade. More recently, on a tip from a fellow woodworker, I switched to the 1/2” blade. It seems to work a little more to my liking. But, they’re both great resaw blades.
You probably already know this but just in case you don’t, you’ll want a good taller resaw fence for the tall stock. The one that Grizzly sells is an excellent fence, in my opinion. Many folks make very fine shop built fences for resawing.
If your saw is properly set up with a good blade, properly tensioned, you should have no drift at all. When I first received the one that I bought new from Grizzly I had to make a minor adjustment to eliminate the drift. It’s a simple fix. In the event that you may be experiencing drift with your BS, here’s the simple fix that I learned:
Remove the table from the saw. Then, using a shim of a known thickness (I used 1/8”), make SURE that the lower blade guide assembly is perfectly parallel to the the trunion support that’s mounted on the top of the lower arm of the saw. There’s some play in that lower blade guide assembly which allows you to align it perfectly. Mine arrived slightly out of parallel from the factory, causing drift. When I solved that minor problem, no more drift.
One more suggestion for resawing the taller stock. Be sure to use a stacked featherboard or some similar device to keep the stock tight against the full height of the fence. I also prefer to cut my boards into manageable lengths for the particular project before resawing.
Enjoy your saw and your great score on the walnut!
Best Regards,
-- Build for the joy of it!
View Rick Boyett's profile
Rick Boyett
41 posts in 105 days
posted 36 days ago
@SEE
Thanks for the advice. I was planning on making a taller fence that would fit over the Grizzly supplied one. Thanks for the blade advice too.
Would you believe that I got that BS for $200? Not on that, but the fella was only using it to trim pen blanks. The only thing I had to do was clean up the table and protect it with some boeshield.
@davidroberts
The wife drags me to Canton every other month or so. There are always a few guys selling shorts, turning blanks, or cedar, but this was the first time I found anyone selling such large sizes of lumber. It didn’t take much to get him to come down to $2 bd ft. I also bought several turning blanks from him.
View stefang's profile (online now)
stefang
1643 posts in 227 days
posted 36 days ago
Look like a great score on the wood and the bandsaw. I would also mention to make sure your blade is really well centered on the top wheel, also to prevent blade drift. It can look centered from the angle you are forced to view it from, but can still be quite a bit off center.
-- Mike, American in Norway
16598 posts in 469 days
posted 36 days ago
Nice deal happy resawing
View dbhost's profile
dbhost
599 posts in 124 days
posted 34 days ago
Timberwolf and Woodslicer both make good resawing blades. I have Timberwolves, and they make my little HF bandsaw really cut like a champ!
-- Trying to follow the example of the master.
25795 posts in 1293 days
posted 34 days ago
Great score on the wood and saw. Have fun.
