Unisaw 1963 #2: Ready for Paint
Blog entry by RCT posted 09-05-2012 01:14 PM 1990 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 1: She Spins on her own Part 2 of Unisaw 1963 series Part 3: White parts »
Here are some pics of the saw after days of hand wire brushing, power wire brushing, hand and power sanding, scotch bright cleaning and degreasing. With a shot of the base for a reminder of how bad it was. I have not gotten up the gusto to start working on the base yet. So far I have determined that the switch will need to be replaced and repositioned, the motor and arbor bearings amazingly seem in good shape no strange sounds or wobbles. The hand-wheel is just in bad shape this is how it looks after 3 days in the anti rust liquid. I’ll be spending some time with it today
-- "Ya but what does he know anyhow?"
5 comments so far
View RedMac's profile
RedMac
19 posts in 2501 days
#1 posted 09-05-2012 01:37 PM
RCT – looking good.
What are you using and how are you applying paint? I am restoring an older jointer and I am trying to understand my options for finishes.
Thanks and good luck.
View Adam Baird's profile
Adam Baird
67 posts in 2148 days
#2 posted 09-05-2012 02:20 PM
I’m also in the middle of a jointer refurb, and I’m almost ready for paint. I’d be curious to know your finishing plans.
-- Adam from Indiana - http://www.WoodenUnion.com
View MedicKen's profile
MedicKen
1615 posts in 3491 days
#3 posted 09-05-2012 04:15 PM
RedMac…...I have been using the Sherwin Williams direct to metal paint. Oil based with a very high solids and nice industrial paint. Application can be either brush/roller or spray. I opted to spray with an HVLP system and the results are very good.
If you want a close match to the original Delta color the Rustoleum smoke grey in rattle cans is nice. The only problem with the rattle can is the coverage. The spray cans give a very light coat and multiple coats are needed for adequate protection. I have used both but prefer the Sherwin Williams.
View RCT's profile
RCT
89 posts in 3780 days
#4 posted 09-05-2012 10:24 PM
Well I did not get to the prep work today. Worked on the other saw’s motor. I will be using spray cans but I have to mask off all of the clear metal areas first. I’m going to be using Rustoleum for color but not delta grey. I worked on Navy ships for to long to still appreciate grey.
View NormG's profile
NormG
6156 posts in 3033 days
#5 posted 09-07-2012 01:16 AM
Keep us up to date please on your progress
-- Norman - I never never make a mistake, I just change the design.
