Hand Tools Cabinet #2: Chisels on the Left, Markings on the right
Blog entry by PurpLev posted 289 days ago 1295 reads 2 times favorited 11 comments Add to Favorites Watch
« Part 1: It all begins with a box Part 2 of Hand Tools Cabinet series Part 3: All aboard the Planes »
Let me start by saying that the first part of this blog although posted earlier today, was actually made about a year ago, I just posted it today as a preceding part to the one you’re reading now… tried not to double post and ‘push’ other’s from the blog front page, so I waited half a day between 2 posts, although both were made ready at the same time.
to continue the story were I left off, what I found most difficult with setting up the box was the box joints, those are LARGE box joints in 3/4 material. my first approach was to use the router table with a 3/4” straight bit, but that proved to cause lots and lots of tear outs (even with a backer board) it was hideous! so I opted to go for the table saw instead. I did not have a dado blade at the time, so what I had to do was cut both edges of the finger cutout piece, then take it to the router table, and clean out the material between the 2 edge defining cuts. this procedure took a long time to finish, and was very hard to follow as each cut on the table saw had to be precisely on the edge marks, and the router table cleanout cut had to be precisely between those 2 initial cuts (basically manual cutting the finger joints one at a time… no repetitions much…no automation). I have since gotten a dado blade, and constructed a fingerjoint jig for my table saw that makes things much easier!
Here is the cabinet above my work bench, easy access to hand tools where and when I need them most. notice that when it’s closed it’s pretty deep, and seems like it’s in the way, but when it opens up it takes 1/2 the depth as the doors are very deep:
closed cabinet
So,
the next step after having a general ‘box’ was to put it to use and start organizing it.
When I had originally made the box, I routed the back pieces for the doors with horizontal t-slots all across the panels, I figured this would allow me to custom design and setup different parts to hold tools in various positions and places- this will also leave me the option to re-organize and change the layout of my tools on the doors without having to drill the doors later on. this was tedious, took a long time to route, and leaves all the slots visible on the doors – BUT – since I like modular capabilities, I’m ok with that, and so far, it has proved to be functional for me.
Here is the current stage of the doors. The chisel set on the left is finished, and there is a second setup for chisels on top of it that is currently a bit messy just cause I still have a few things with no permanent place, and I do what I can with what I’ve got. on the right door I’ve mounted my 12” and 6” combination squares in a way that their shape (45 angle) and ruler keep them locked in. Also I’ve got my (so far just 1) hand saws on that side. The middle has some drawers made with fingerjoints – this time I used my dado blade, and the fingerjoint jig that I made (very basic jig, just a backer tall board that attaches to my miter gauge and has a slot for the blade, and a slot for a finger) – while making these drawers I accidently made my Incra 1000SE into an Incta 998... (check the blog – it also shows the finger joint jig). Also in the main cabinet I will be hanging my hand planes, right now they are just standing there, but I will set them up with individual shelves (already have the design… just need the time to make it):
open cabinet
As you can see, the cabinet opens wide, and decreases some of it’s depth, providing easy access to almost any tool you’ll need to work with at the bench. while keeping the cabinet closed, it keeps all the tools away from dust, extra moisture (esp. if you seal the cabinet properly…), etc.
next would be drawers slides, and organizing and putting those drawers to use, and setting shelves for the planes.
one step at a time… the way I see it, everytime I’m working on a project, I’ll add another step to the cabinet. no rush, I believe this cabinet will take many steps, and many changes till it’s just how I want it.
EDIT: Added following photos of mounting possibilities with 1/4” bolts, and the T-slots:
open cabinet
open cabinet
open cabinet
11 comments so far
View kolwdwrkr's profile
kolwdwrkr
2249 posts in 483 days
posted 289 days ago
This looks like it’s going to be a great addition to the shop. Nice work so far.
View Tom Adamski's profile
Tom Adamski
309 posts in 664 days
posted 289 days ago
Very impressive… I like the idea of the slots for the inside of the doors. I have been planning to build a cabinet but have held off because I was not sure of the layout. With the slots, everything can be modular and moveable. What are the dimensions?
Thanks,
Tom
-- Anybody can become a woodworker, but only a Craftsman can hide his mistakes.
View wood_wench's profile
wood_wench
79 posts in 324 days
posted 289 days ago
This has got to be great to use in the shop – you did a nice design job in allowing yourself some real flex in space usage on the interior walls.
By the way I’m really jealous – I have an Incra 1000 but I don’t have a Incra 998. yet!
View 3fingerpat's profile
3fingerpat
906 posts in 561 days
posted 289 days ago
Ah yes, brings back memories of when I built my hand tool cabinet. What type of hand plane storage are you planning on? Horizontal or vertical? I found out that once you fill it up, its time to start building the next one ;o)
Good luck and thanks for sharing.
View Will Mego's profile
Will Mego
204 posts in 606 days
posted 289 days ago
I’d recommend Jim Tolpin’s “The toolbox book”, it’s got sections devoted to some amazing wall hung tool cabinets, along with every other kind of tool storage…and toolboxes, of course.
-- "That which has in itself the greatest use, possesses the greatest beauty." - Unknown Shaker
3710 posts in 873 days
posted 289 days ago
H PurpLev;
I started a similar cabinet about ten years ago, but never got around to finishing it. I got side tracked by building the shop.
And now, I don’t have room for it, but I do still have plenty of need for it.
Maybe I should rearrange some space a bit.
Great job.
20603 posts in 715 days
posted 289 days ago
This is a wonderful idea. It allows you to store a number of tools in a relatively small footprint and keeps them organized.
View cabinetmaster's profile
cabinetmaster
8497 posts in 451 days
posted 289 days ago
Great looking cabinet and it is a space saver.
Beginningwoodworker
4132 posts in 566 days
posted 289 days ago
Nice hand tool cabinet.
-- CJIII Future cabinetmaker
View ShannonRogers's profile
ShannonRogers
370 posts in 681 days
posted 289 days ago
Great work, I too really like the slots in the door to allow for a modular storage approach. This is a surprisingly hard project because we just don’t know what tools we may acquire in the future and want to have flexibility to keep them all safe and organized. Nice job in tackling that.
-- Check out my blog and podcast "The Renaissance Woodworker" at www.rogersfinewoodworking.com/blog
25792 posts in 1294 days
posted 280 days ago
A great looking Cabinet. I’m helping a friend veneer the doors on the one that he is making.
