Woodworker Chronicles #3: Not Another Sharpening Post.... - YES!
Blog entry by PurpLev posted 08-02-2013 04:33 AM 2483 reads 0 times favorited 21 comments Add to Favorites Watch
« Part 2: emBRACE the BOREdom Part 3 of Woodworker Chronicles series no next part
With everyone getting stuck up and all sensitive about sharpening and what not lately I figured what better time to have yet another sharpening related post – so here it is – my way – at least nowadays (it keeps evolving as the years go by and getting better and better for me).
I keep hearing about the marvels of water and oil stones all the time, and always wanted to “be there with the best”, so at some point I got a couple of arkansas stones – a hard , and a black which according to the specs should have taken me from my diamond stones shine to a higher level only heard about in legends… unfortunately it just didn’t happen to me, and the results I am getting from these are subpar to my green super-fine diamond stone which gives me a much higher shine. maybe its because I’m not using “proper” honing oil? it’s possible… but I digress. My point being that I simply went back to my tried and trued method of giving me a super sharp edge.
My setup involves 2 steps:
Step 1: Flattening the Back with (3) Diamond stones
I got this set of DMT diamond stones from Rockler when I was in my early years of woodworking as a rough shaper for edge tools, but for some reason I find that I don’t have a need to go beyond these as “rough” as they may be:
I go through the 3 stones until I get mirror finish on the backs, and then move on to step 2 (who would have thought). as some would say – I am not anal about the backs – which I will get to later on this post showing what I mean, and showing the reason…
Step 2: Setting the bevel and polishing it up using Slow wet grinder
I picked this Scheppach grinder up on CL some years ago for a good price, but even new (same as the grizzly) it doesn’t break the bank, and has been performing great everytime I use it:
It’s easy to use, does a good job, grinds cool and cannot screw up the blades. Once the bevel is set and the bevel and back meet at a proper edge, I switch to the polishing wheel freehand (although you can swap the toolrest and use that as well) and let the bevel ride on the wheel from it’s heel (so that if anything gets rounded – it’s the non crucial part of the bevel) and bring the blade up to have the entire bevel ride on the wheel to give it a nice mirror finish.
at that point – I take the blade back to the highest grit diamond stone, and give it a light treatment on the back to remove any burrs from the grinder.
and I’m done. can shave hairs off, and slice end grain – makes me happy.
can I do better? I’m sure I can
But this is fast, efficient, and I don’t have the feeling that I need to do better, so I leave it at that.
Now… why did I come to this?
I know a woodworker that goes through some health issues, and decided to donate my set of German chisels to him to help bring up the moral. that meant I am chiselsless. as life would have it, the same day, someone posted a set of chisels for sale, which I promptly went for. the chisels arrived today quickly and well packed. Unfortunately I believe that someone tried to sharpen them but possibly didn’t go about it properly.
This is pretty much what prompted me to post as someone posted a day or 2 ago about how not anal he is about the backs of chisels which I didn’t realize why he posted it as I don’t know anyone who IS anal about the backs of chisels, and most anyone I know including myself only flattens the front of the back (confused much?), but looking at these chisels, it seems like someone actually went through the trouble of trying to flatten – the entire back of the blade.
The problem with doing so (unless you are using a surface grinder), is that it means you will have to remove ALOT of material which not only will take forever, but also requires a lot of energy invested into it, and worst – it adds quite a bit of chance to round over the backs at the edges because there is much friction between the sharpening medium and the metal which can cause it to lift, or twist out of flat. which is what I assume happened here. the entire backs received a flattening treatment but the edges were all rounded off making it almost impossible to properly get a sharp edge out of these.
I flattened the front 1” or so of each chisel and you can see the “previous” scratch marks visible on the entire back, the “new” scratch marks I made trying to flatten only the front, and the sliver of previous scratch marks on the edge of the back as it was rounded over and is now a “low spot” which makes it almost impractical to flatten the back of the chisel where it matters – at the edge:
There are a couple of ways to address this:
  1. the obvious – grind the front of the blade back to remove the rounded over area completely – reestablish the bevel from scratch
  2. The rule trick – use a thin metal rule to raise the blade at the other end so that it is slightly tilted towards the edge. you will not get a “pure” flat back, but this will help by flattening ONLY the leading edge of the blade which reduces the amount of metal you are removing.
  3. elbow grease – keep on flattening the back until you level it off with the low spot (rounded over edge).
I chose a combination of #3 and #1. I gave the backs a bit of an extra work to get down and closer to the low spots on the fronts, and then reground the bevels which I believe were originally set at 20 degrees to 25 degrees and ground them back a bit to remove that front lowered edge.
2 hours later, I had all 7 chisels razor sharp and ready for work.
here you can see the backs where it’s pretty visible how far back I flattened them as opposed to the original attempt to flatten them completely:
the only area that matters – is near the cutting edge, the rest of the back can be “somewhat flat” but it isn’t critical to have it completely flat.
the bevels (I did grind the 1” chisel at 35 degree, and then decided to grind the rest at 25… I will need to redo it’s bevel at some point for more paring operations):
and the cutting edge on the bevel side where you can see that the majority of the bevel is left “rough” as it doesn’t do the actual cutting and does not need to be all that polished. just like the back side, it’s only the edge that really needs to be flat and polished:
So that’s my take on anal and lenient. be mindful of what’s important, and don’t sweat the rest – same with all cutting tools, and same with hand plane soles – they don’t all have to be completely flat throughout end to end. only the critical parts/areas need be flat and sharpened (in blades) to the best of your ability (the more the better of course).
Hope this was helpful as a lesson, or tip, or an eye opener to some of you, or at least entertaining to others :)
21 comments so far
View realcowtown_eric's profile
608 posts in 1872 days
#1 posted 08-02-2013 05:03 AM
They look way too blunt for me!
Are you sure yer measuring the 35 degrees yer aiming for correctly
Yer blade angle looks closer to 55 degrees!
-- Real_cowtown_eric
View Woodwrecker's profile
4132 posts in 3511 days
#2 posted 08-02-2013 05:13 AM
If it works for you Sharon, that’s all that matters.
Your results speak for themselves.
I too have a system that I am comfortable with, and that mean more time woodworking and less time fussing.
-- Eric, central Florida / Utor praemia operibus duris
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2792 days
#3 posted 08-02-2013 08:40 AM
Looks a sound way of working, you will know by the feel
There is no right way, there is the way that works for you
I learnt very young, an oil stone and a strop nothing fancy
I can see my teeth in the mirror back and they cut wood
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View Mark Colan's profile
Mark Colan
210 posts in 2781 days
#4 posted 08-02-2013 10:59 AM
And what about planes? That wheel does not look wide enough to handle the blades of those nice planes you have.
BTW I picked up some planes recently, used: #5 jack, #7 jointer, #3 smoother, and a small trimming plane, about $200 total at a used tool shop in Maine. You helped me sharpen my block plane some months back, and now it’s time for me to learn to sharpen my own.
-- Mark, hack amateur woodworker, Medford (greater Boston) MA
View PurpLev's profile
8534 posts in 3584 days
#5 posted 08-02-2013 01:38 PM
Yup – as long as it works, we all find out own ways of doing things. this one is my current ways.
Eric (the real cowtown one)- I have yet to be able to shave hair and end grain with a blunt tool, but if you think that’s possible – I’ll be more than happy to know how. the angles are just fine, maybe the photo is playing tricks on you.
the proof is in the pudding as they say (and I had pudding last night).
Mark – nice to see you active. the plane irons are indeed wider than the grinder wheel (they are wider than almost all grinder wheels). so you need to move the iron left right to address it’s entire width. in fact you have to do the same motion with chisel irons as well or you would end up grinding a groove in your wheel which is a no-no.
16273 posts in 4154 days
#6 posted 08-02-2013 07:59 PM
I really NEED to care more about sharpening, but, dammit, I just can’t make myself. Heck, for a long time I thought you were always supposed to whack a chisel with a hammer to make it cut something. :-)
#7 posted 08-02-2013 08:01 PM
wait a minute….. you mean you DON’T?!?
... oh boy…
35108 posts in 4336 days
#8 posted 08-03-2013 12:39 AM
Why does every tool store sell Mallets if your not suppose to whack the chisel?
Nice write-up.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware soon moving to Virginia †
View Mauricio's profile
7144 posts in 3087 days
#9 posted 08-03-2013 03:36 PM
I love a good sharpening discussion! Great wright up.
I’m also a big fan of the diamond stones. But I’m surprised you can get a mirror polish with them. Maybe my EZE Laps need to break in a little more.
#10 posted 08-04-2013 12:58 AM
maybe “mirror finish” isn’t the right term for me to have used. while I can see reflection, I can also see the scratch marks – so it’s not perfect. I can get a better “mirror” surface if I go to 2000grit sand paper (which I used to do in the past) but I just don’t notice much of a difference in the cut when actually using the chisels – so my bottom line is to sharpen them until I get a good cut – not necessarily when I can use them as a rear view mirror.
Mark Colan
#11 posted 08-06-2013 09:21 PM
Hey PurpLev and anyone else near Cambridge MA:
Cambridge Center for Adult Education has a “Sharpening Workshop” this Saturday, Aug 10, from 10-4. It costs $130. You bring in a new cabinet scraper and a new chisel, and the sharpening materials are provided.
Dan Paret is a local artisan woodworker who has been focused on hand tools for years, so I imagine that he knows a fair bit about sharpening. I’ll be there.
You can sign up on their Web site.
View mafe's profile
11638 posts in 3025 days
#12 posted 08-08-2013 01:26 PM
Nothing like finding your method of sharpening, sharpening has not only to give us sharp tools, I think it is just as important that we like the process, then we do it more often and only then do we get the true joy of woodworking.
Looks sharp and fine to me.
Best thoughts,
#13 posted 08-08-2013 01:43 PM
Thanks Mads,
I agree – it has to “work” for us too and not just for the edge tools. I think this is why we see so many woodworkers using (more of less) slightly different approaches when it comes to sharpening, and all work.
and yes, it’s pretty sharp ;)
View mafe's profile
#14 posted 08-08-2013 02:01 PM
Mark Colan
#15 posted 08-08-2013 02:36 PM
Again for Boston-area woodworkers, Woodcraft in Woburn is having a demo on sharpening this Saturday at 1pm. Stores in other areas may have this demo on other days.
